On my linux machine ....
I am trying to burn the bootloader for an 328p bare board. I am using an arduino uno board as the bootloader loader.
I can load the sketch arduinoISP fine on the uno board. When I try an burn the bootloader onto the bare 328P I get
the error shown below.
My circuit is the same as in the tutorial https://www.arduino.cc/en/Tutorial/ArduinoToBreadboard
On my windows machine...
I can plug the usb cable into my windows machine and it will burn the bootloader onto the bare 328p succesfully.
I spent a couple of days trying to find the problem, then finally trying my windows machine where it worked. I could
also then connect my ftdi and down load a blink sketch.
Any help is appreciated.
Here is the output of ide window:
Arduino: 1.8.10 (Linux), Board: "ATmega328 on a breadboard (8 MHz internal clock)"
/home/jrm/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude
-C/home/jrm/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf
-v -patmega328p -carduino -P/dev/ttyACM1 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xE2:m
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/jrm/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf"
User configuration file is "/home/jrm/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM1
Using Programmer : arduino
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
Hardware Version: 4238814
Firmware Version: 41305744.0
Topcard : STK502
Vtarget : 1.8 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done. Thank you.
Error while burning bootloader.
