SurferTim:
Take a look at the code in this thread:
How to get the client(s)of an Arduino ethernet server? - #2 by SurferTim - Networking, Protocols, and Devices - Arduino Forum
It is a simple telnet type connection that works both ways. It is by no means complete, just a test. But it should give you an idea how it works. Feel free to modify it to your heart's content.
edit: That code above is a bit lacking. Try this. It is a bit better for two way comm. Change the network settings to yours. It will timeout the connected client if there is no input for about a minute.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip( 192,168,2,2 );
IPAddress gateway( 192,168,2,1 );
IPAddress subnet( 255,255,255,0 );
EthernetServer server(23);
int loopCount = 0;
boolean isStopped;
pinMode(4,OUTPUT);
digitalWrite(4,HIGH);
Ethernet.begin(mac, ip, gateway, gateway, subnet);
delay(2000);
server.begin();
Serial.println("Ready");
if(client)
Serial.println("Client connected");
client.flush();
isStopped = false;
loopCount = 0;
char c;
client.println("Hello");
while(Serial.available()) Serial.read();
while (client.connected())
while(client.available())
c = client.read();
if(c == 'x')
client.stop();
Serial.println("stop - user request");
isStopped = true;
else Serial.write(c);
loopCount = 0;
delay(10);
loopCount++;
if(loopCount > 10000)
client.stop();
Serial.println("stop - timeout");
isStopped = true;
c =Serial.read();
client.write(c);
Serial.write(c);
if(!isStopped)
client.stop();
Serial.println("stop - disconnect");
Serial.println("disconnected");
Hello SurferTim, oh yeah I just tested the code you gave me:
The result is my Netbook (say it PC2 --> client) can respond in telnet "Hello"
But the problem in my Notebook (say it PC1 --> server) can not open the serial monitor, what's wrong then yah?
it show red warning:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at javax.swing.BoxLayout.preferredLayoutSize(BoxLayout.java:282)
at java.awt.Container.preferredSize(Container.java:1599)
at java.awt.Container.getPreferredSize(Container.java:1584)
at javax.swing.JComponent.getPreferredSize(JComponent.java:1636)
at java.awt.BorderLayout.layoutContainer(BorderLayout.java:804)
at java.awt.Container.layout(Container.java:1421)
at java.awt.Container.doLayout(Container.java:1410)
at java.awt.Container.validateTree(Container.java:1507)
at java.awt.Container.validateTree(Container.java:1513)
at java.awt.Container.validate(Container.java:1480)
at java.awt.Window.show(Window.java:860)
at java.awt.Component.show(Component.java:1563)
at java.awt.Component.setVisible(Component.java:1515)
at java.awt.Window.setVisible(Window.java:841)
at processing.app.Editor.handleSerial(Editor.java:2416)
at processing.app.Editor$18.actionPerformed(Editor.java:671)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1225)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:1266)
at java.awt.Component.processMouseEvent(Component.java:6263)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6028)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4574)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
