Can not compile for ESP8266 wifi module
Hello, I have followed many tutorials on the net for learning to use the ESP8266 wifi module.
But I would now upload the webserver sketch into by using Arduino 1.6.5 with the "GeneriESP8266 board" and teh esptool too.
I have installed the ESP8266 library but I can compil the example webserver sketch and I don't know why.
If somebody could help me, it would very nice.
espfail.txt (1.38 KB)
Most people would be OK with that.
Some more details would be useful.
No, it was a mistake; I can NOT compile !
Sorry, I have to go to the beach, I will give more details later but the two jointed pieces are details.
While you are at the beach, I'll look for a picture of an answer. Or not.
A link to the library and ALL of your code AS TEXT is the next order of business.
There is the link of the library installed by the arduino IDE:
http://arduino.esp8266.com/stable/package_esp8266com_index.json
and the same error reported:
Arduino : 1.6.5 (Windows XP), Carte : "Generic ESP8266 board"
Les options de compilation ont été modifiées, tout sera recompilé
C:\Program Files\Arduino\hardware\esp8266com\esp8266\libraries\ESP8266WebServer\src\Parsing.cpp:30:56: error: no 'bool ESP8266WebServer::_parseRequest(WiFiClient&)' member function declared in class 'ESP8266WebServer'
 bool ESP8266WebServer::_parseRequest(WiFiClient& client) {
C:\Program Files\Arduino\hardware\esp8266com\esp8266\libraries\ESP8266WebServer\src\Parsing.cpp:208:50: error: no 'void ESP8266WebServer::_uploadWriteByte(uint8_t)' member function declared in class 'ESP8266WebServer'
 void ESP8266WebServer::_uploadWriteByte(uint8_t b){
C:\Program Files\Arduino\hardware\esp8266com\esp8266\libraries\ESP8266WebServer\src\Parsing.cpp:217:84: error: no 'void ESP8266WebServer::_parseForm(WiFiClient&, String, uint32_t)' member function declared in class 'ESP8266WebServer'
 void ESP8266WebServer::_parseForm(WiFiClient& client, String boundary, uint32_t len){
Erreur lors de la compilation.
  Ce rapport contiendrait plus d'informations si l'option
  "Montrer les informations de sortie pendant la compilation"
  était activée dans Fichier > Préférences.
The errors are because the *** functiuns are not declared.
Isn't because there is no parse.h in the parse.cpp folder ?
Looks like you have an ESP8266 core installed in the Program Files\Arduino\hardware folder when it should be in the C:\Users\username\AppData\Roaming\Arduino15\packages folder. Try removing the old core.
I have the same files at Programfiles\xxx than c:\documents and setting\administrateur\ as you can on the picture:
and I still have the same problem...
Did you follow the installation instructions here:
