Can not compile Nano33IoT
Hi All,
I bought a Nano33IoT board. When i try to compile the board using the arduino software, the error comes up showing:
/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld: cannot find -larm_cortexM0l_math
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino NANO 33 IoT.
That I can not compile the board at all.
Any ideas of why this happening? Appreciate it!
Hi @shengwuli
Do you need the MATLAB/Simulink Arduino integration?
I have a suspicion that the problem is related to that, so if you no longer need it then I would recommend that you use the unmodified version of the Arduino IDE. But of course if you still need the MATLAB integration then that will not be an acceptable workaround.
I'm going to ask you to provide some additional information that might allow us to determine the cause of the problem.
Please do this:
  1. Select File > Preferences from the Arduino IDE's menus.
  2. Check the box next to "Show verbose output during: [] compilation".
  3. Click the OK button.
  4. Select Sketch > Verify/Compile from the Arduino IDE's menus.
  5. After the compilation fails you'll see a button on the right side of the orange bar in the Arduino IDE: Copy error messages. Click that button.
    This copies the full output to the clipboard.
  6. Open a forum reply here by clicking the Reply button.
  7. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  8. Press Ctrl+V.
    This will paste the compilation output into the code block.
  9. Move the cursor outside of the code tags before you add any additional text to your reply.
  10. Click the Reply button to post the output.
Hi in0,
Here is all the error codes from the list.
Arduino: 1.8.19 (Mac OS X), Board: "Arduino NANO 33 IoT"
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/shengwuli/Documents/Arduino/libraries -fqbn=arduino:samd:nano_33_iot -vid-pid=2341_8057 -ide-version=10819 -build-path /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239 -warnings=none -build-cache /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_cache_457063 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.arduinoOTA.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.bossac.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs=runtime.tools.CMSIS-Atmel.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs=runtime.tools.openocd.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs=runtime.tools.CMSIS.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0 -verbose /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/untitled573357495.tmp/sketch_dec28a/sketch_dec28a.ino
/Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -hardware /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -tools /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/shengwuli/Documents/Arduino/libraries -fqbn=arduino:samd:nano_33_iot -vid-pid=2341_8057 -ide-version=10819 -build-path /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239 -warnings=none -build-cache /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_cache_457063 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.arduinoOTA.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.bossac.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/bossac/1.7.0-arduino3 -prefs=runtime.tools.CMSIS-Atmel.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs=runtime.tools.openocd.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs=runtime.tools.CMSIS.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0 -verbose /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/untitled573357495.tmp/sketch_dec28a/sketch_dec28a.ino
Using board 'nano_33_iot' from platform in folder: /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12
Using core 'arduino' from platform in folder: /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12
Detecting libraries used...
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/sketch/sketch_dec28a.ino.cpp -o /dev/null
Generating function prototypes...
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/sketch/sketch_dec28a.ino.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/preproc/ctags_target_for_gcc_minus_e.cpp
/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/sketch/sketch_dec28a.ino.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/sketch/sketch_dec28a.ino.cpp.o
Compiling libraries...
Compiling core...
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot/variant.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/variant.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -x assembler-with-cpp -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/pulse_asm.S -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/pulse_asm.S.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/delay.c -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/delay.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/wiring.c -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/wiring.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/WInterrupts.c -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/WInterrupts.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/wiring_analog.c -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/wiring_analog.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/hooks.c -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/hooks.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/pulse.c -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/pulse.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/wiring_digital.c -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/wiring_digital.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/itoa.c -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/itoa.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/startup.c -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/startup.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/cortex_handlers.c -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/cortex_handlers.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/wiring_private.c -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/wiring_private.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/wiring_shift.c -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/wiring_shift.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/USB/samd21_host.c -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/USB/samd21_host.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-gcc -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/compact/dtostrf.c -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/compact/dtostrf.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/Reset.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/Reset.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/abi.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/abi.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/USB/USBCore.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/USB/USBCore.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/new.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/new.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/SERCOM.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/SERCOM.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/Tone.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/Tone.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/USB/CDC.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/USB/CDC.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/Uart.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/Uart.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/WMath.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/WMath.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/main.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/main.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/Common.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/api/Common.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/IPAddress.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/api/IPAddress.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/PluggableUSB.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/api/PluggableUSB.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/Print.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/api/Print.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/Stream.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/api/Stream.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10819 -DARDUINO_SAMD_NANO_33_IOT -DARDUINO_ARCH_SAMD -DCRYSTALLESS -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x8057 -DUSBCON "-DUSB_MANUFACTURER=\"Arduino LLC\"" "-DUSB_PRODUCT=\"Arduino NANO 33 IoT\"" -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS-Atmel/1.2.0/CMSIS/Device/ATMEL/ -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/deprecated-avr-comp -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino -I/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot /Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/cores/arduino/api/String.cpp -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/api/String.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/pulse_asm.S.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/USB/samd21_host.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/WInterrupts.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/compact/dtostrf.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/cortex_handlers.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/delay.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/hooks.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/itoa.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/pulse.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/startup.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/wiring.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/wiring_analog.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/wiring_digital.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/wiring_private.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/wiring_shift.c.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/Reset.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/SERCOM.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/Tone.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/USB/CDC.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/USB/USBCore.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/Uart.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/WMath.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/abi.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/api/Common.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/api/IPAddress.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/api/PluggableUSB.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/api/Print.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/api/Stream.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/api/String.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/main.cpp.o
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar rcs /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/new.cpp.o
Archiving built core (caching) in: /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_cache_457063/core/core_arduino_samd_nano_33_iot_e8728a4e9bafbf589562605ecc5f2736.a
Linking everything together...
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -L/var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239 -Os -Wl,--gc-sections -save-temps -T/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/hardware/samd/1.8.12/variants/nano_33_iot/linker_scripts/gcc/flash_with_bootloader.ld -Wl,-Map,/var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/sketch_dec28a.ino.map --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/sketch_dec28a.ino.elf /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/sketch/sketch_dec28a.ino.cpp.o /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/variant.cpp.o -Wl,--start-group -L/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/CMSIS/4.5.0/CMSIS/Lib/GCC/ -larm_cortexM0l_math -lm /var/folders/kd/3nw7hytn7pq542lw0dv_35tc0000gn/T/arduino_build_862239/core/core.a -Wl,--end-group
/Users/shengwuli/Documents/MATLAB/SupportPackages/R2021b/3P.instrset/arduinoide.instrset/idepkgs/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld: cannot find -lstdc++_nano
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino NANO 33 IoT.
