can not configure wifi.
Hello,
I can not configure the the wifi on my yun. I can connect to the generated signal just fine. However, when i attempt to access http://192.168.240.1/ or arduino.local i receive a blank page in chrome and an error message saying access forbidden in IE (only for the IP address, arduino.local just gives blank pages). I have spent the past few hours leafing through various posts on the topic and i have finally given up. None of the previous posts have resolved the issue. I do have bonjour print services installed and udp 5353 is open. It might be worth knowing that i work for a large corporation so I am hoping that this is not a corporate security issue. With all that being said, i could use some help here.
Thanks
Please, upload the YunSerialTerminal sketch that you can find in the Arduino IDE Examples. After uploading the sketch, open the serial monitor and press the YUN_RST button.
Paste the output of the serial monitor here
My message vastly exceeds the allowable number of characters and apparently i can only post once every 10 minutes. Here is chunk number one. Let me know if this is not what you were expecting
U-Boot 1.1.4-dirty (Apr 10 2014 - 15:12:15)
Arduino Yun (ar9331) U-boot
DRAM: 64 MB
Top of RAM usable for U-Boot at: 84000000
Reserving 142k for U-Boot at: 83fdc000
Reserving 192k for malloc() at: 83fac000
Reserving 44 Bytes for Board Info at: 83fabfd4
Reserving 36 Bytes for Global Data at: 83fabfb0
Reserving 128k for boot params() at: 83f8bfb0
Stack Pointer at: 83f8bf98
Now running in RAM - U-Boot at: 83fdc000
Flash Manuf Id 0xef, DeviceId0 0x40, DeviceId1 0x18
flash size 16777216, sector count = 256
Flash: 16 MB
Using default environment
In: serial
Out: serial
Err: serial
Net: ag7240_enet_initialize…
No valid address in Flash. Using fixed address
: cfg1 0x5 cfg2 0x7114
eth0: 00:03:7f:09:0b:ad
eth0 up
: cfg1 0xf cfg2 0x7214
eth1: 00:03:7f:09:0b:ad
athrs26_reg_init_lan
ATHRS26: resetting s26
ATHRS26: s26 reset done
eth1 up
eth0, eth1
Hit any key to stop autoboot: 4 3 2 1 0
Booting image at 9fea0000 …
Image Name: MIPS OpenWrt Linux-3.3.8
Created: 2014-04-17 8:11:04 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 1185367 Bytes = 1.1 MB
Load Address: 80060000
Entry Point: 80060000
Verifying Checksum at 0x9fea0040 …OK
Uncompressing Kernel Image … OK
No initrd
Transferring control to Linux (at address 80060000) …
Giving linux memsize in bytes, 67108864
Starting kernel …
[ 0.000000] Linux version 3.3.8 (jenkins@jenkins) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #1 Fri Apr 11 07:16:38 CEST 2014
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Atheros AR9330 rev 1
[ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 → 0x00004000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000000 → 0x00004000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: board=Yun console=ttyATH0,250000 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env)ro,14656k(rootfs),1280k(kernel),64k(nvram),64k(art),15936k@0x50000(firmware) rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 60936k/65536k available (2565k kernel code, 4600k reserved, 650k data, 180k init, 0k highmem)
[ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.000000] Calibrating delay loop… 265.42 BogoMIPS (lpj=1327104)
[ 0.080000] pid_max: default: 32768 minimum: 301
[ 0.080000] Mount-cache hash table entries: 512
[ 0.080000] NET: Registered protocol family 16
[ 0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
[ 0.090000] MIPS: machine is Arduino Yun
[ 0.530000] Setting DogStick2 GPIO
[ 0.550000] bio: create slab at 0
[ 0.550000] SCSI subsystem initialized
[ 0.560000] usbcore: registered new interface driver usbfs
[ 0.560000] usbcore: registered new interface driver hub
[ 0.560000] usbcore: registered new device driver usb
[ 0.570000] Switching to clocksource MIPS
[ 0.570000] NET: Registered protocol family 2
[ 0.570000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.580000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.580000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.580000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.580000] TCP reno registered
[ 0.580000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.590000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.590000] NET: Registered protocol family 1
[ 0.610000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.610000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.620000] msgmni has been set to 119
[ 0.620000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[ 0.620000] io scheduler noop registered
[ 0.630000] io scheduler deadline registered (default)
[ 0.630000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.640000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) i{ a AR933X UART
[ 0.640000] console [ttyATH0] enabled, bootconsole disabled
[ 0.650000] m25p80 spi0.0: found w25q128, expected m25p80
[ 0.650000] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.650000] 7 cmdlinepart partitions found on MTD device spi0.0
[ 0.660000] Creating 7 MTD partitions on “spi0.0”:
[ 0.660000] 0x000000000000-0x000000040000 : “u-boot”
[ 0.660000] 0x000000040000-0x000000050000 : “u-boot-env”
[ 0.670000] 0x000000050000-0x000000ea0000 : “rootfs”
[ 0.670000] mtd: partition “rootfs” set to be root filesystem
chunk two
[ 0.670000] mtd: partition “rootfs_data” created automatically, ofs=7A0000, len=700000
[ 0.680000] 0x0000007a0000-0x000000ea0000 : “rootfs_data”
[ 0.680000] 0x000000ea0000-0x000000fe0000 : “kernel”
[ 0.680000] 0x000000fe0000-0x000000ff0000 : “nvram”
[ 0.690000] 0x000000ff0000-0x000001000000 : “art”
[ 0.690000] 0x000000050000-0x000000fe0000 : “firmware”
[ 0.710000] ag71xx_mdio: probed
[ 0.720000] eth0: Atheros AG71xx at 0xba000000, irq 5
[ 1.270000] eth0: Found an AR7240/AR9330 built-in switch
[ 2.300000] eth1: Atheros AG71xx at 0xb9000000, irq 4
[ 2.850000] ag71xx ag71xx.0: eth1: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
[ 2.850000] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 2.850000] ehci-platform ehci-platform: Generic Platform EHCI Controller
[ 2.860000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[ 2.890000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[ 2.910000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[ 2.910000] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.910000] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.910000] usb usb1: Product: Generic Platform EHCI Controller
[ 2.920000] usb usb1: Manufacturer: Linux 3.3.8 ehci_hcd
[ 2.920000] usb usb1: SerialNumber: ehci-platform
[ 2.920000] hub 1-0:1.0: USB hub found
[ 2.920000] hub 1-0:1.0: 1 port detected
[ 2.930000] Initializing USB Mass Storage driver…
[ 2.930000] usbcore: registered new interface driver usb-storage
[ 2.930000] USB Mass Storage support registered.
[ 2.930000] input: gpio-keys-polled as /devices/platform/gpio-keys-polled/input/input0
[ 2.940000] sdhci: Secure Digital Host Controller Interface driver
[ 2.940000] sdhci: Copyright(c) Pierre Ossman
[ 2.940000] usbcore: registered new interface driver ushc
[ 2.940000] TCP cubic registered
[ 2.950000] NET: Registered protocol family 17
[ 2.950000] Bridge firewalling registered
[ 2.950000] 8021q: 802.1Q VLAN Support v1.8
[ 2.960000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[ 2.960000] Freeing unused kernel memory: 180k freed
[ 3.250000] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 3.440000] usb 1-1: New USB device found, idVendor=058f, idProduct=6254
[ 3.440000] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.440000] usb 1-1: Product: USB2.0Hub
[ 3.570000] hub 1-1:1.0: USB hub found
[ 3.570000] hub 1-1:1.0: 4 ports detected
[ 3.920000] usb 1-1.4: new high-speed USB device number 3 using ehci-platform
[ 4.050000] usb 1-1.4: New USB device found, idVendor=058f, idProduct=6366
[ 4.060000] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.060000] usb 1-1.4: Product: Mass Storage Device
[ 4.060000] usb 1-1.4: Manufacturer: Generic
[ 4.060000] usb 1-1.4: SerialNumber: 058F0O1111B1
[ 4.100000] scsi0 : usb-storage 1-1.4:1.0
[ 5.030000] Error: Driver ‘gpio-keys-polled’ is already registered, aborting…
[ 5.100000] scsi 0:0:0:0: Direct-Access Multi Flash Reader 1.00 PQ: 0 ANSI: 0
  • preinit -
    Press the [f] key and hit [enter] to enter failsafe mode
  • regular preinit -
    [ 9.570000] JFFS2 notice: (527) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (1 unchecked, 0 orphan) and 13 of xref (0 dead, 2 orphan) found.
    [ 10.740000] sd 0:0:0:0: [sda] Attached SCSI removable disk
    switching to jffs2
  • init -
Please press Enter to activate this console. [ 38.140000] Loading modules backported from Linux version master-2014-01-23-0-g62c147d
[ 38.140000] Backport generated by backports.git backports-20140124-0-g1256d3e
[ 38.180000] cfg80211: Calling CRDA to update world regulatory domain
[ 38.180000] cfg80211: World regulatory domain updated:
[ 38.180000] cfg80211: DFS Master region: unset
[ 38.180000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 38.190000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 38.190000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 38.190000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 38.200000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (300 mBi, 2000 mBm)
[ 38.200000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (300 mBi, 2000 mBm)
[ 38.200000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 39.170000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[ 39.170000] cfg80211: Calling CRDA for country: US
[ 39.180000] cfg80211: Regulatory domain changed to country: US
[ 39.180000] cfg80211: DFS Master region: FCC
[ 39.180000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 39.180000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
[ 39.190000] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (300 mBi, 1700 mBm)
[ 39.190000] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz), (300 mBi, 2400 mBm)
[ 39.190000] cfg80211: (5490000 KHz - 5600000 KHz @ 80000 KHz), (300 mBi, 2400 mBm)
[ 39.200000] cfg80211: (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2400 mBm)
[ 39.200000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (300 mBi, 3000 mBm)
[ 39.210000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 39.620000] NTFS driver 2.1.30 [Flags: R/O MODULE].
[ 39.660000] Error: Driver ‘gpio-keys-polled’ is already registered, aborting…
[ 39.790000] PPP generic driver version 2.4.2
[ 39.840000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 39.960000] NET: Registered protocol family 24
[ 40.000000] nf_conntrack version 0.5.0 (954 buckets, 3816 max)
[ 40.430000] i2c /dev entries driver
[ 40.470000] Linux video capture interface: v2.00
[ 40.590000] fuse init (API version 7.18)
