mucip
June 17, 2022, 9:18am
1
In wihich situation, char array can not be convert to String?
I get the SIM return message and compare a string by below code:
String gelenSimCevap = String(simCevap);
But becaue of unknown reason I can not compare the below condition?
if (gelenSimCevap.indexOf("1,0,0,0") != -1){
I am sure simCevap is "1,0,0,0". But when I convert it to
gelenSimCevap is equal to "", empty?!
What may it be the reason?
Regards,
Mucip:)
Maybe the problem is somewhere in the code you didn't post.
mucip
June 17, 2022, 9:36am
4
I use Adafruit FONA library and get the AT command result by below code:
char simCevap[100];
if (fona.sendCheckReplyText("AT+CLCC", simCevap)) {
Serial.print("Sim Cevap: ");
Serial.println(simCevap);
Normally return is:
Sim Cevap: 1,0,3,0,0,"+905321547374",145,""
And when I hang up the phone then result is:
Sim Cevap: 1,0,0,0,0,"+905321547374",145,""
I want the control if the other party hang up the phone? And send voice file to it.
if (gelenSimCevap.indexOf("1,0,0,0") != -1) {
fona.sendCheckReply(F("AT+DTAM=2"), ok_reply)
fona.sendCheckReply(F("AT+CREC=4,1,0,100"), ok_reply)
Regards,
Mucip:)
mucip
June 17, 2022, 9:37am
5
Please check my next post.
Regards,
Mucip:)
kolaha
June 17, 2022, 10:34am
6
char simCevap[100];
char Req[7]={0};
for (byte i = 0; i < 7; i++)Req[i] = simCevap[i];
if (strcmp(Req, "1,0,0,0") == 0) {
mucip
June 17, 2022, 6:00pm
7
It shouldn't be const char Req[7]. Should it be?
Regards,
Mucip:)
mucip
June 17, 2022, 7:28pm
8
Same problem! It looks like it get some values from remaining buffer and put in Reg value!.
Arduino ram value usage is %87. İs this problem come from this?
Regards,
Mucip:)
On AVR's expecially, C++ Strings SUCK RAM and cycles for what? So talent-free Morons can concatenate with a + and have other More-Like-BASIC/PASCAL syntax while black-boxing text from the coder.
As far as text and text manipulation, plain old C is SUPERIOR to C++ String Objects.
If you dig, that's what you'll find.
mucip
June 17, 2022, 7:59pm
11
Req variable is just created. Normally in the begining it must be empty/NULL/"".
But after your for loop and println(Req)
Return value is:
Sim Metin Req: 1,0,2,0,0,547374;
Wher did it find ,547374; value, I did not understand?!
Regards,
Mucip:)
kolaha
June 17, 2022, 8:37pm
12
const char Def1[]={"1,0,0,0"};
char simCevap[100] = {
"0,0,0,0,0,0,0"
char Req[7] = {0};
Serial.print("Req: ");
Serial.println(Req);
if (strcmp(Req, Def1) == 0)Serial.println("yes\n");
else Serial.println("no\n");
simCevap[0] = '1';
if (strcmp(Req, Def1))Serial.println("no\n");
else Serial.println("yes\n");
void loop() {}
mucip
June 18, 2022, 11:18am
13
I disapointed unfortunatelly?!
I could not convert char to String noway!
Where this stupid string come from?!
I'm searching in my room if anyone make me hidden camera joke?!...
Really strange!
Regards,
Mucip:)i
mucip
June 18, 2022, 11:30am
14
Maybe there is unwanted charecters in SimCevap which is return from SIM800.
How can I check if all the charecters in SimCevap are printable or correct?
I am sure it must be some unexpected chars in SimCevap?!
Regards,
Mucip:)
kolaha
June 18, 2022, 11:37am
15
char simCevap[100];
fona.sendCheckReplyText("AT+CLCC", simCevap);
for (i = 0; i < 100; i++) {
Serial.print(i);
Serial.print('\t');
Serial.println(simCevap[i],DEC);
mucip
June 18, 2022, 4:29pm
16
Everything looks OK. Very strange?!
Well, why I can not convert this char to string than?!
Tekrar sayısı: 6
---> AT+CLCC
<--- +CLCC: 1,0,0,0,0,"+905321547374",145,""
0 49
1 44
2 48
3 44
4 48
5 44
6 48
7 44
8 48
9 44
10 34
11 43
12 57
13 48
14 53
15 51
16 50
17 49
18 53
19 52
20 55
21 51
22 55
23 52
24 34
25 44
26 49
27 52
28 53
29 44
30 34
31 34
32 0
33 0
34 0
35 0
36 0
37 0
38 0
39 0
40 0
41 0
42 0
43 0
44 0
45 0
46 0
47 0
48 0
49 0
Sim Metin Cevap:
Sim Metin Req: 1,0,0,0,0,547374;
Def1: 1,0,0,0
Req Metin: 1,0,0,0,0,547374;
Def1 Metin:
Cevap bekleniyor!
Regards,
Mucip:)
kolaha
June 18, 2022, 4:43pm
17
char simCevap[50];
const char Line1[7] = {49, 44, 48, 44, 48, 44, 48};
Serial.print("SimCevap:");
char Req[7] = {0};
Serial.println(Line1);
if (strcmp(Req, Line1) == 0) {
Serial.println("OK");
mucip
June 18, 2022, 4:51pm
18
Yes, we can get the result with this code maybe. But we still don't know why we can not convert this char into String?!
This is the main question unfortunatelly and still alive...
Regards,
Mucip:)
kolaha
June 18, 2022, 5:49pm
19
mucip:
char into String
yes we can.
String LettersDef = "1234567890";
char Symbols[10] = {"1234567890"};
String Letters = Symbols;
Serial.println(Letters);
if ( LettersDef == Letters) Serial.println("OK");
else Serial.println("not OK");
Letters = Letters.substring(0, 10);
Serial.println(LettersDef);
check this one and compare
char Symbols[10] = {49,50,51,52,53,54,55,56,57,48};
mucip
June 18, 2022, 6:20pm
20
But all these codes can not explain why we can not get success below code?
fona.sendCheckReplyText("AT+CLCC", simCevap) //In here, send AT Command to SIM and get result in simCevap
String gelenSimCevap = String(simCevap); //We want to convert simCevap (Char value) into gelenSimCevap (This is String)
String comparedString = "1,0,0,0" ; //This is what we need to check value
if(gelenSimCevap.indexOf(comparedString ) != -1){
makeAnotherJob();
}else{
//Still wait for hang up phone?
I can get the char no problem:
Serial.println(simCevap); //Result is 1,0,3,0,0,"+905321547374",145,""
but later,
Serial.println(gelenSimCevap ); //Result is nothing... :frowning:
Very strange?!
Regards,
Mucip:)
