Can not get RAMBo board to show up in "tools"
I have downloaded the "addons" and put the "RAMBo" folder in "hardware" and the "U8glib" folder into the "libraries" folder. Still no "RAMBo" board under "tools", "boards"
I want to use the LCD screen with the RAMBo on my 3D printer.
Can anyone help please?
tia
Wayne
To help you I will need some more information.
Can you please post a link of where you downloaded the RAMbo "addons" and let me know what version of the IDE you are using.
It is not so simple in the newer 1.5+ IDE’s with the new board manager. You can still manually add a board, but merging the directories by hand in the hardware folder is a bit of a hassle.
I have attached a zip file that you can unzip into the Arduino hardware directory, it will add a Rambo subdirectory and associated files … can’t remember exactly where I got all this, but it does add the Rambo board to the Arduino IDE in version 1.6.3 for me.
Not necessary to change any of other directories …
arduino hardware rambo.zip (23.2 KB)
fldietrich: It is not so simple in the newer 1.5+ IDE's with the new board manager. You can still manually add a board, but merging the directories by hand in the hardware folder is a bit of a hassle.
I have attached a zip file that you can unzip into the Arduino hardware directory, it will add a Rambo subdirectory and associated files ... can't remember exactly where I got all this, but it does add the Rambo board to the Arduino IDE in version 1.6.3 for me.
Not necessary to change any of other directories ....
Wow that worked! Thank you!
But I still have no LCD screen working, I went through all this http://reprap.org/wiki/RamboLCD too.
The screen is lit up, but just displays squares.
Any ideas?
Thanks again, Wayne
You need to set correct screen type in Configuration.h file in mine its line 414 ... uncomment that one and comment out the other one. Plus make sure all is plugged in correctly!
fldietrich: You need to set correct screen type in Configuration.h file in mine its line 414 ... uncomment that one and comment out the other one. Plus make sure all is plugged in correctly!
Humm, which lines? Any of these:
// The MaKr3d Makr-Panel with graphic controller and SD support // http://reprap.org/wiki/MaKr3d_MaKrPanel //#define MAKRPANEL
// The RepRapDiscount Smart Controller (white PCB) // http://reprap.org/wiki/RepRapDiscount_Smart_Controller //#define REPRAP_DISCOUNT_SMART_CONTROLLER
// The GADGETS3D G3D LCD/SD Controller (blue PCB) // http://reprap.org/wiki/RAMPS_1.3/1.4_GADGETS3D_Shield_with_Panel //#define G3D_PANEL
// The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PCB) // http://reprap.org/wiki/RepRapDiscount_Full_Graphic_Smart_Controller // // ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: http://code.google.com/p/u8glib/wiki/u8glib //#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// The RepRapWorld REPRAPWORLD_KEYPAD v1.1 // http://reprapworld.com/?products_details&products_id=202&cPath=1591_1626 //#define REPRAPWORLD_KEYPAD //#define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0 // how much should be moved when a key is pressed, eg 10.0 means 10mm per click
// The Elefu RA Board Control Panel // http://www.elefu.com/index.php?route=product/product&product_id=53 // REMEMBER TO INSTALL LiquidCrystal_I2C.h in your ARDUINO library folder: https://github.com/kiyoshigawa/LiquidCrystal_I2C //#define RA_CONTROL_PANEL
I have the 3D printer Reprap Smart Controller Reprap Ramps V1.4 LCD2004 Board module
I tried two of them, but no luck: //#define REPRAP_DISCOUNT_SMART_CONTROLLER and //#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
Thanks again Wayne
Sweet, I now have the screen working!
But, lol
Now I have a new set of things to figure out. It says it is 464/0 Err: MAXTEMP and no bed temp, but at least I am making progress!
Thanks for the help, now back to reading and looking and searching for fixes ;-P
Wayne
Great! Seems you may have thermistor wires plugged in wrong places? Remember to pay special attention to getting the first layer down right ....
fldietrich: Great! Seems you may have thermistor wires plugged in wrong places? Remember to pay special attention to getting the first layer down right ....
Can you help me with one last thing please? I have everything working now, but LOL
When I print it extrudes way too much plastic, it is like it is trying to push 3 mm filament instead of 1.75???
A flow rate of 20 seems to work, looking for a place to change it in firmware.
Plus my parts a too thick, the Z axis is enlarged.
My extruder must be set different than what it is expecting?
I have looked in the firmware and changed a couple things but they made no change. There must be a setting somewhere to change this?
Thank you again,
wkinne
I got it!
I learned so much it is crazy, but now my cheap Prusa i3 that came with a junk MKS Base V1.1 board is making perfect parts under the control of my new RAMBo controller.
I bought two Prusa i3's and both controllers died within three months >:(
Now to upgrade the second one :confused:
Thank you for your help, wkinne
