Can not get Stack Trace Decoder to load
I tried putting the damn EspExceptionDecoder.java in the appdata folder, the program files folder, and documents folder. It doesn't show up under tools. It was working before I upgraded to 1.8.8.
Any clues as to what might be wrong?
Directory of C:\Users\matt\My Documents\arduino\tools
019-03-02  15:02    <DIR>          .
019-03-02  15:02    <DIR>          ..
019-03-02  15:02    <DIR>          EspExceptionDecoder
019-02-05  18:40            19,979 EspExceptionDecoder.java
019-03-02  14:56    <DIR>          src
              1 File(s)         19,979 bytes
              4 Dir(s)  138,391,076,864 bytes free
 Directory of C:\Program Files (x86)\Arduino\tools
2019-02-05  18:40    <DIR>          .
2019-02-05  18:40    <DIR>          ..
2019-02-05  18:49    <DIR>          espExceptionDecoder
2018-12-06  06:24             5,437 howto.txt
2019-02-05  05:02    <DIR>          Mangler
2019-02-05  05:02    <DIR>          WiFi101
               1 File(s)          5,437 bytes
               5 Dir(s)  138,390,945,792 bytes free
Also reported at:
I see you've gone with the "shotgun" installation method, strewing files around your hard drive. The best way forward will be to delete all that and start with a fresh installation.
I'll provide instructions:
  1. Delete the folder at the following path:
    C:\Program Files (x86)\Arduino\tools\espExceptionDecoder
  2. Delete the folder at the following path:
    C:\Users\matt\My Documents\arduino\tools\EspExceptionDecoder
  3. Delete the folder at the following path:
    C:\Users\matt\My Documents\arduino\tools\EspExceptionDecoder.java
  4. Start Arduino IDE.
  5. Select File > Preferences from the Arduino IDE menus.
    The "Preferences" dialog will open.
  6. Take note of the path shown in the "Sketchbook location" field of the "Preferences" dialog.
  7. Click the "Cancel" button in the "Preferences" dialog.
  8. Select File > Quit from the Arduino IDE menus.
  9. Create a folder named tools under the folder at the path you noted from the "Sketchbook location" preference.
  10. Download the compiled latest release of the tool:
    https://github.com/me-no-dev/EspExceptionDecoder/releases/download/1.1.0/EspExceptionDecoder-1.1.0.zip
  11. Unzip the downloaded file.
  12. Copy the unzipped folder to the tools folder you created
The folder structure of a correct installation looks like this:
<sketchbook location>
|_tools
   |_EspExceptionDecoder
      |_tool
         |_EspExceptionDecoder.jar
Thank you. Now it loads.
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
