Can not receive CAN DATA from Arduino UNO with MCP2515 Module.
Have you tried sending an OBD-II PID request? I'd try at 250k first. It could just be that the port has a CAN bus dedicated for OBD-II and nothing is broadcast over it. Outside of that I would investigate your hardware. The fact that reversing the polarity caused an issue tells me the port is active in some sense.
coryjfowler: Have you tried sending an OBD-II PID request? I'd try at 250k first. It could just be that the port has a CAN bus dedicated for OBD-II and nothing is broadcast over it. Outside of that I would investigate your hardware. The fact that reversing the polarity caused an issue tells me the port is active in some sense.
That could very well be possible. I haven't tried sending an ODB-II PID. Forgive me if it's a stupid question, but how do I do this with the Arduino and MCP2515? I'm only familiar with sending serial commands via an ELM327.
You can give this a whirl, it will probably be the weekend before I can load it on one of my boards and throw it at my car.
/* CAN OBD & UDS Simple PID Request
 *  Currently requests PID 0x00 at a 1 second interval and
 *  displays all received CAN traffic to the terminal at 115200.
 *  Written By: Cory J. Fowler  April 5th, 2017
 *  (Disclaimer: Standard IDs are currently UNTESTED against a vehicle)
#include
#include
#define standard 0
// 7E0/8 = Engine ECM
// 7E1/9 = Transmission ECM
#if standard == 1
  #define LISTEN_ID 0x7EA
  #define REPLY_ID 0x7E0
  #define FUNCTIONAL_ID 0x7DF
#else
  #define LISTEN_ID 0x98DAF101
  #define REPLY_ID 0x98DA01F1
  #define FUNCTIONAL_ID 0x98DB33F1
#endif
// CAN TX Variables
unsigned long prevTx = 0;
unsigned int invlTx = 1000;
byte txData[] = {0x02,0x01,0x00,0x55,0x55,0x55,0x55,0x55};
// CAN RX Variables
unsigned long rxID;
byte dlc;
byte rxBuf[8];
char msgString[128];                        // Array to store serial string
// CAN Interrupt and Chip Select Pins
#define CAN0_INT 2                              /* Set INT to pin 2 (This rarely changes)   */
MCP_CAN CAN0(9);                                /* Set CS to pin 9 (Old shields use pin 10) */
void setup(){
  while(!Serial);
  // Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
  if(CAN0.begin(MCP_STDEXT, CAN_500KBPS, MCP_16MHZ) == CAN_OK)
    Serial.println("MCP2515 Initialized Successfully!");
  else{
    Serial.println("Error Initializing MCP2515... Permanent failure!  Check your code & connections");
    while(1);
//  // Allow all Standard IDs
//  CAN0.init_Mask(0,0x00000000);                // Init first mask...
//  CAN0.init_Filt(0,0x00000000);                // Init first filter...
//  CAN0.init_Filt(1,0x00000000);                // Init second filter...
//  // Allow all Extended IDs
//  CAN0.init_Mask(1,0x80000000);                // Init second mask...
//  CAN0.init_Filt(2,0x80000000);                // Init third filter...
//  CAN0.init_Filt(3,0x80000000);                // Init fouth filter...
//  CAN0.init_Filt(4,0x80000000);                // Init fifth filter...
//  CAN0.init_Filt(5,0x80000000);                // Init sixth filter...
#if standard == 1
  // Standard ID Filters
  CAN0.init_Mask(0,0x7F00000);                // Init first mask...
  CAN0.init_Filt(0,0x7DF0000);                // Init first filter...
  CAN0.init_Filt(1,0x7E10000);                // Init second filter...
  CAN0.init_Mask(1,0x7F00000);                // Init second mask...
  CAN0.init_Filt(2,0x7DF0000);                // Init third filter...
  CAN0.init_Filt(3,0x7E10000);                // Init fouth filter...
  CAN0.init_Filt(4,0x7DF0000);                // Init fifth filter...
  CAN0.init_Filt(5,0x7E10000);                // Init sixth filter...
#else
  // Extended ID Filters
  CAN0.init_Mask(0,0x90FF0000);                // Init first mask...
  CAN0.init_Filt(0,0x90DA0000);                // Init first filter...
  CAN0.init_Filt(1,0x90DB0000);                // Init second filter...
  CAN0.init_Mask(1,0x90FF0000);                // Init second mask...
  CAN0.init_Filt(2,0x90DA0000);                // Init third filter...
  CAN0.init_Filt(3,0x90DB0000);                // Init fouth filter...
  CAN0.init_Filt(4,0x90DA0000);                // Init fifth filter...
  CAN0.init_Filt(5,0x90DB0000);                // Init sixth filter...
#endif
  CAN0.setMode(MCP_NORMAL);                      // Set operation mode to normal so the MCP2515 sends acks to received data.
  // Having problems?  ======================================================
  // If you are not receiving any messages, uncomment the setMode line below
  // to test the wiring between the Ardunio and the protocol controller.
  // The message that this sketch sends should be instantly received.
  //CAN0.setMode(MCP_LOOPBACK);
  pinMode(CAN0_INT, INPUT);                          // Configuring pin for /INT input
  Serial.println("Simple CAN OBD-II PID Request");
void loop(){
  if(!digitalRead(CAN0_INT)){                         // If CAN0_INT pin is low, read receive buffer
    CAN0.readMsgBuf(&rxID, &dlc, rxBuf);             // Get CAN data
    // Display received CAN data as we receive it.
    if((rxID & 0x80000000) == 0x80000000)     // Determine if ID is standard (11 bits) or extended (29 bits)
      sprintf(msgString, "Extended ID: 0x%.8lX  DLC: %1d  Data:", (rxID & 0x1FFFFFFF), dlc);
      sprintf(msgString, "Standard ID: 0x%.3lX       DLC: %1d  Data:", rxID, dlc);
    Serial.print(msgString);
    if((rxID & 0x40000000) == 0x40000000){    // Determine if message is a remote request frame.
      sprintf(msgString, " REMOTE REQUEST FRAME");
      for(byte i = 0; i= invlTx){
    prevTx = millis();
    if(CAN0.sendMsgBuf(FUNCTIONAL_ID, 8, txData) == CAN_OK){
      Serial.println("Message Sent Successfully!");
      Serial.println("Error Sending Message...");
Edit 20170514: Tested and fixed some bugs. I can confirm that extended ID mode (#define standard 0) works with my vehicle and I unfortunately do not have access to a vehicle that operates in standard ID mode to confirm with.
Thanks a lot. I've tried your code (just changed 16MHz -> 8MHz, INT on pin 9 -> pin 10).
However, I'm not getting any output other than just the setup of the module. My knowledge in this field is very limited, but could the 8MHz crystal be the problem? Maybe some of the values in the timing registers for 8MHz?
Entering Configuration Mode Successful!
Setting Baudrate Successful!
Starting to Set Mask!
Setting Mask Successful!
Starting to Set Filter!
Setting Filter Successfull!
I have tested some of the more common 8MHz baud rate configuration register settings against a Peak adapter and a Vector VN1610, so I trust those to be good.
I edited the send function to give some indication about when a message was sent or if there was an error while sending. If there is no error while sending and your car doesn't exhibit any signs we are corrupting signals (like when the CAN line polarity was reversed), it should be safe to assume the baudrate of 250k is correct. In that case, try changing the 1 in "#define standard 1" to a 0 to try OBD-II with extended IDs. Otherwise, try it again, but only changing the baudrate to 500k.
If you get send errors at both 250k and 500k, change "CAN0.setMode(MCP_NORMAL);" to "CAN0.setMode(MCP_LOOPBACK);". You should see the one packet we transmit come right back and display on the screen. This will confirm your protocol controller is functioning as it should and that it is correctly wired to the Arduino.
If you do not see a received message, check your INT pin connection and the definition for it in the sketch.
If you see the received message while in loop back, I would check the connection between the protocol controller and the transceiver making sure that there is continuity between the ICs and that there are not shorts to ground, power, or another signal.
coryjfowler:
Ok, it was just a thought, because 16MHz seem to be ‘standard’.
coryjfowler:
I edited the send function to give some indication about when a message was sent or if there was an error while sending. If there is no error while sending and your car doesn’t exhibit any signs we are corrupting signals (like when the CAN line polarity was reversed), it should be safe to assume the baudrate of 250k is correct. In that case, try changing the 1 in “#define standard 1” to a 0 to try OBD-II with extended IDs. Otherwise, try it again, but only changing the baudrate to 500k.
I got the error message, both with 250k and 500k. I got the error message both when connected to the car, and when not connected to a CAN bus at all.
I measured the voltage with a multimeter on the ODBII port in the car, and when not connected to my project, the voltages are DC 2.56V both on H and L.
coryjfowler:
If you get send errors at both 250k and 500k, change “CAN0.setMode(MCP_NORMAL);” to “CAN0.setMode(MCP_LOOPBACK);”. You should see the one packet we transmit come right back and display on the screen. This will confirm your protocol controller is functioning as it should and that it is correctly wired to the Arduino.
I actually see the received message in loopback, so that seems to work. I have also checked the PCB for continuity between the MCP2515 and the TJA1050. Also, the VCC and GND connections seem to be working properly. I’m wondering however if maybe the VCC for the transceiver chip is too low, as I’m measuring 4.01V over the VCC and GND. The datasheet says 4.75V minimum. But maybe it is just normal to measure a lower voltage when the IC is running?
Yes, I would say that voltage definitely needs fixed. It should be much closer to 5.0 than that.
The (first) module I used may actually be faulty. I have acquired a second module, which gives normal values on the VCC voltages and I actually am receiving messages now!
However, with your code, I'm receiving messages, but the sending of the message keeps failing, like below. The CAN_receive example gives me just the Standard ID messages, so that seems to work now.
Standard ID: 0x2F5       DLC: 3  Data: 0x5E 0x00 0x80
Standard ID: 0x2F5       DLC: 3  Data: 0x4F 0x00 0x80
Standard ID: 0x488       DLC: 8  Data: 0x3D 0x00 0x70 0x00 0x1E 0x3C 0xFF 0x3D
Standard ID: 0x612       DLC: 5  Data: 0x73 0x20 0x01 0x36 0x00
Standard ID: 0x38D       DLC: 7  Data: 0x00 0x00 0x00 0x00 0xAF 0xD1 0x00
Standard ID: 0x432       DLC: 6  Data: 0x81 0x59 0x48 0xFE 0x00 0x00
Standard ID: 0x348       DLC: 8  Data: 0x00 0x4F 0x2D 0x44 0xC0 0x01 0x00 0x40
Standard ID: 0x412       DLC: 8  Data: 0x18 0x00 0x00 0x00 0x00 0x3C 0x0A 0x00
Standard ID: 0x072       DLC: 5  Data: 0x02 0x00 0x00 0x00 0x00
Standard ID: 0x208       DLC: 8  Data: 0x00 0x00 0x21 0x00 0x0C 0xFF 0xFF 0x4F
Standard ID: 0x2F5       DLC: 3  Data: 0xC7 0x00 0x80
Standard ID: 0x2F5       DLC: 3  Data: 0x03 0x00 0x80
Standard ID: 0x2F5       DLC: 3  Data: 0x7C 0x00 0x80
Standard ID: 0x2F5       DLC: 3  Data: 0x6D 0x00 0x80
Standard ID: 0x30D       DLC: 8  Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Standard ID: 0x38D       DLC: 7  Data: 0x00 0x00 0x00 0x00 0xAF 0x1D 0x00
Standard ID: 0x592       DLC: 3  Data: 0x00 0x00 0x00
Does it send okay in loopback mode? I'd fault the module again if so, since it sounds like the TX CAN connection between the protocol controller and the transceiver might be open or shorted to something.
Glad to see that you're seeing messages from your vehicle though.
I have been working on it a bit more, but I am getting such strange results.
coryjfowler: Does it send okay in loopback mode? I'd fault the module again if so, since it sounds like the TX CAN connection between the protocol controller and the transceiver might be open or shorted to something.
Sending of the message in loopback mode does actually work. But it is also working when I just connect two modules with terminators. A 'local' CAN bus with two modules and two arduinos does seem to work just fine. I can send and receive messages on both modules. The voltages on the modules also seem in order.
Radio and steering wheel controls As mentioned above, I finally got messages on the ODB2 port. However, they don't contain the data I'm looking for, namely the steering wheel controls for the radio (as my project is trying to use the steering wheel buttons to control some media players in the car).
To my understanding, the steering wheel controls work via CAN bus. This can also be seen when looking for commercially available adapters and in this specification of peugeot CAN bus messages.
So I tried connecting a module to the CAN bus wires of the radio (per this schematic, for example). But this gave some strange results;
  • First, I measured the voltages of these wires, and they are actually the other way around from the schematics. Connecting by the schematics resulted in random dashboard errors. Connecting the other way around gave no errors, but also not one message. I tried different baud rates, 125k, 250k and 500k
  • The voltage difference in the radio CAN bus wires is much higher than on the ODB2 port. On the radio I'm measuring 4.58V vs 0.34V. On the ODB2 port I'm measuring 3.13V vs 2.36V. So apparently this is not the same CAN bus.
I'm actually quite lost now on what is happening here, and how to proceed :confused:
PS. Sorry to the original poster for 'hijacking' your topic a bit :cold_sweat:
reynard80: So I tried connecting a module to the CAN bus wires of the radio (per this schematic, for example). But this gave some strange results;
Did those wires appear to be twisted together by chance? That's usually a good indicator of some type of digital bus. Also, its not unheard of for extra CAN buses to be populated on the OBD-II manufacture's discretion pins. My old Escape had two and my new Jeep has three on the port. (I found them via trial and error.)
At this point, I'd say you'd need an oscilloscope to see what is actually going on between your car and the CAN module. Something just isn't right and its interesting that they work fine together, but not with your car.
I have managed to get hold of the electrical schemas of the car and this explains a lot. There are indeed multiple CAN buses in the car. The radio is on a seperate comfort CAN bus, which runs on 125kbps. So that explains quite a bit.
I've also read a bit more into CAN bus specifications and this clears things up quite a bit. The radio CAN bus signals actually are typical for a Low speed or Fault tolerant CAN bus. High speed transceivers are not compatible with such a bus, so I'll have to find a suitable fault tolerant CAN bus transceiver. Maybe build my own PCB.
Wikipedia: Low speed/Fault tolerant CAN signaling drives the CAN high wire towards 5V and the CAN low wire towards 0V when transmitting a dominant (0), and does not drive either wire when transmitting a recessive (1). The dominant differential voltage must be greater than 2.3V (with a 5V Vcc) and the recessive differential voltage must be less than 0.6V The termination resistors passively return the CAN low wire to RTH where RTH is a minimum of 4.7V (Vcc-0.3V where Vcc is 5V nominal) and the CAN high wire to RTL where RTL is a maximum of 0.3V. Both wires must be able to handle -27 to 40V without damage. |500x190
High speed transceivers are not compatible with such a bus, so I'll have to find a suitable fault tolerant CAN bus transceiver. Maybe build my own PCB. My question now is, will the MCP2515 controller and library work with such a transceiver?
reynard80: My question now is, will the MCP2515 controller and library work with such a transceiver?
The transceiver and physical bus are independent of the protocol controller and the library wouldn't even notice the difference.
From a quick look, it appears that all low-speed transceivers are larger than a SOIC8 package due to the extra pins required for the termination resistors among other features, so a board would need to be made for this. Looking at how each device is terminated, it seems to me that a good confirmation of your thought about the bus being low-speed fault-tolerant would be to disconnect the battery and measure the resistance between the CAN High and CAN Low of that bus to see if it reads around 60 ohms or not. From what I'm seeing, I would expect a higher resistance or an open to be read when they are unpowered, but I could be wrong as I've not messed with this physical specification yet. Its also worthy to note that a low-speed fault-tolerant bus is designed for a specific number of nodes in mind since each device has a termination resistance. Hopefully the vendor thought about future proofing and the total line resistance is greater than 100 ohms allowing for an additional device or so.
Now I'm suddenly skeptical about my Jeep's 125k bus even though the high speed transceivers in the CAN adapter I was using was reading the data fine.
coryjfowler: The transceiver and physical bus are independent of the protocol controller and the library wouldn't even notice the difference.
I thought and hoped so already. so that's good to hear..
coryjfowler: From a quick look, it appears that all low-speed transceivers are larger than a SOIC8 package due to the extra pins required for the termination resistors among other features, so a board would need to be made for this. Looking at how each device is terminated, it seems to me that a good confirmation of your thought about the bus being low-speed fault-tolerant would be to disconnect the battery and measure the resistance between the CAN High and CAN Low of that bus to see if it reads around 60 ohms or not. From what I'm seeing, I would expect a higher resistance or an open to be read when they are unpowered, but I could be wrong as I've not messed with this physical specification yet. Its also worthy to note that a low-speed fault-tolerant bus is designed for a specific number of nodes in mind since each device has a termination resistance. Hopefully the vendor thought about future proofing and the total line resistance is greater than 100 ohms allowing for an additional device or so.
I want to make my own board indeed, soldering a PCB is not a real problem. I have looked in to some circuit diagrams and it seems pretty easy to do.
The termination is good point though, I also read about this. I think the manufacturer thought about at least one more device, as there is a connection to a CD changer available on the radio with CANL and CANH. Also, there is an option for a handsfree set, which I don't have. I'm thinking of using the CD changer connection (this way I'll also have a neat solution for connecting my device).
Determining the value of the termination resistors is one thing I'll have to solve indeed. But I'm not sure how to do this exactly. I have included a (crude, sorry for that) diagram of the ECU's, as found in the official technical documentation of the car. So it seems I have six nodes on this bus, but I am not sure how to find the value for the termination resistors for my project. I'm not sure how to measure the termination resistance of each node, as measuring over CANH and CANL is not correct in this case I think. CANH and CANL don't seem to be connected by the termination resistance.
Update for future searchers:
I managed to receive messages on the comfort/fault tolerant/low speed CAN bus of my Peugeot 207, via the RD4 radio. I finally got it working with the circuit as described in this paper. Comparable designs and more information can also be found on a few German and Russian forums. Google Translate is my friend :)
I still have to develop a refined 'production' board, as I now only have a breadboard prototype. Also, I haven't tested sending messages yet.
schema.PNG|836x585
While I have a working board now, I'm still running into some trouble. I'm receiving messages, but after a short while, this stops. It seems the MCP2515 does not give an interupt anymore, as there is some error situation.
The error does not seem to be with the transceiver, as it does not signal an error on its error-pin.
Is it possible to see the errors the MCP2515 encounters, with the library? When I read the datasheet, it seems that error flags can be read from the chip register? How can this be done?
reynard80: Is it possible to see the errors the MCP2515 encounters, with the library? When I read the datasheet, it seems that error flags can be read from the chip register? How can this be done?
Add the below to your main loop someplace. When an error occurs, it will flood your terminal window. With this piece of code in the main loop of my J1939 test application connected to my bench bus that has an ECM on it, I eventually get a receive buffer 0 overflow error which I expect to get on occasion since the ECM transmits cyclic messages at some high rates.
 if(CAN0.checkError() == CAN_CTRLERROR){
    Serial.print("Error register value: ");
    byte tempErr = CAN0.getError() & MCP_EFLG_ERRORMASK; // We are only interested in errors, not warnings.
    Serial.println(tempErr, BIN);
    Serial.print("Transmit error counter register value: ");
    tempErr = CAN0.errorCountTX();
    Serial.println(tempErr, DEC);
    Serial.print("Receive error counter register value: ");
    tempErr = CAN0.errorCountRX();
    //I do not have a function that clears errors and that has been added to my todo list. 04/26/17 CJF
coryjfowler:
Thanks, is there an overview of the error codes somewhere? I can’t find it in the datasheet, or am I overlooking it? I am receiving errors like this, where the counter is counting down:
Error register value: 1000000
Transmit error counter register value: 0
Receive error counter register value: 65
The error bits are read from the EFLG (ERROR FLAG) register of the MCP2515. Looks like the 6th bit is set which the datasheet says is RX0 overflow which is expected on a busy CAN bus. What concerns me is the 65 receive errors...
coryjfowler: The error bits are read from the EFLG (ERROR FLAG) register of the MCP2515. Looks like the 6th bit is set which the datasheet says is RX0 overflow which is expected on a busy CAN bus. What concerns me is the 65 receive errors...
This may be a rather stupid question, but how do you see the 6th bit is set? Because there are 6 zeroes? I think it is a busy CAN bus indeed, but does this mean the controller just hasn't got enough capacity to handle this busy bus? Or can something be done about it? Will setting a mask/filter help keeping the RX buffer from overflowing?
I have the serial output formatted to binary in the error code snippet, just need to see a 1 and its zero-based position.
As for overflow, its not typically an issue unless RX1 also overflowed since I have the BUKT bit set by default. BUKT being set moves the packet from RX0 to RX1 when a received message is destined for RX0. Filtering for only the CAN IDs you are interested in would definitely alleviate any overflows. Anything to increase the microcontroller's ability to read from the CAN controller would also help, like increasing the SPI clock speed, removing/fixing blocking functions, limiting unnecessary serial writes and/or increasing the serial speed, etc.
As for the SPI clock speed, Arduino added some new SPI features that I've not had time to incorporate into the library and test out which has been on the todo list. Something like SPISettings(10000000, MSBFIRST, SPI_MODE0) added below the CAN0.begin(...) function would help maximize the SPI clock.
