can not run /bin/avrdude when trying to load sketch Mac osx 10.11.6
Hi:
I am new to this so if this is a stupid question I am sorry. I am running Mac 10.11.6 and Ardunio 1.6.10 and when I try to upload the sketch to the Ardunio Uno, I get the following error
Arduino: 1.6.10 Hourly Build 2016/07/26 04:12 (Mac OS X), Board: “Arduino/Genuino Uno”
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
java.io.IOException: Cannot run program “{runtime.tools.avrdude.path}/bin/avrdude”: error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at java.lang.Runtime.exec(Runtime.java:620)
at java.lang.Runtime.exec(Runtime.java:485)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:11)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:130)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingProgrammer(SerialUploader.java:345)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:91)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
at processing.app.Sketch.upload(Sketch.java:1187)
at processing.app.Sketch.exportApplet(Sketch.java:1160)
at processing.app.Sketch.exportApplet(Sketch.java:1132)
at processing.app.Editor$DefaultExportAppHandler.run(Editor.java:2506)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.(UNIXProcess.java:248)
at java.lang.ProcessImpl.start(ProcessImpl.java:134)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
… 12 more
An error occurred while uploading the sketch
“Show verbose output during compilation”
option enabled in File → Preferences.
I have opened the Arduino package and looked for the ardude file. It is present and runnable, so what is wrong?
Thanks
Enable verbose upload, attempt to upload again, and paste the output here. I want to see the command it's trying to invoke to start avrdude - it looks as if it's not subbing in the location of avrdude correctly. But I can't tell without the verbose output.
If you want a good user experience, don't use the hourly builds. They are very often buggy. Don't use the most recent release either until you check on the forums, most of the releases in 1.6.x have been bad. 1.6.9 and 1.6.5r5 are the most recent ones that work well enough to recommend. 1.6.10 release is/was unusable - lot of severe bugs.
i have the same problem. thus is my verbose output :-
/Applications/Arduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/Abhi/Documents/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10611 -build-path /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp -warnings=none -prefs=build.warn_data_percentage=75 -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino /Applications/Arduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Arduino.app/Contents/Java/hardware -tools /Applications/Arduino.app/Contents/Java/tools-builder -tools /Applications/Arduino.app/Contents/Java/hardware/tools/avr -built-in-libraries /Applications/Arduino.app/Contents/Java/libraries -libraries /Users/Abhi/Documents/Arduino/libraries -fqbn=arduino:avr:uno -ide-version=10611 -build-path /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp -warnings=none -prefs=build.warn_data_percentage=75 -verbose /Applications/Arduino.app/Contents/Java/examples/01.Basics/Blink/Blink.ino Using board 'uno' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr Using core 'arduino' from platform in folder: /Applications/Arduino.app/Contents/Java/hardware/arduino/avr Detecting libraries used... "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/sketch/Blink.ino.cpp" -o "/dev/null" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/sketch/Blink.ino.cpp" -o "/dev/null" Generating function prototypes... "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/sketch/Blink.ino.cpp" -o "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/preproc/ctags_target_for_gcc_minus_e.cpp" "/Applications/Arduino.app/Contents/Java/tools-builder/ctags/5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/preproc/ctags_target_for_gcc_minus_e.cpp" Compiling sketch... "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/sketch/Blink.ino.cpp" -o "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/sketch/Blink.ino.cpp.o" Compiling libraries... Compiling core... "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc" -c -g -x assembler-with-cpp -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino" "-I/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/variants/standard" "/Applications/Arduino.app/Contents/Java/hardware/arduino/avr/cores/arduino/wiring_pulse.S" -o "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/wiring_pulse.S.o" Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/WInterrupts.c.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/hooks.c.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/wiring.c.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/wiring_analog.c.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/wiring_digital.c.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/wiring_pulse.c.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/wiring_shift.c.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/CDC.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/HardwareSerial.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/HardwareSerial0.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/HardwareSerial1.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/HardwareSerial2.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/HardwareSerial3.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/IPAddress.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/PluggableUSB.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/Print.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/Stream.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/Tone.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/USBCore.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/WMath.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/WString.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/abi.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/main.cpp.o Using previously compiled file: /var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/new.cpp.o
"/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/wiring_pulse.S.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/WInterrupts.c.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/hooks.c.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/wiring.c.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/wiring_analog.c.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/wiring_digital.c.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/wiring_pulse.c.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/wiring_shift.c.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/CDC.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/HardwareSerial.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/HardwareSerial0.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/HardwareSerial1.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/HardwareSerial2.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/HardwareSerial3.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/IPAddress.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/PluggableUSB.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/Print.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/Stream.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/Tone.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/USBCore.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/WMath.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/WString.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/abi.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/main.cpp.o" "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc-ar" rcs "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a" "/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/new.cpp.o"
Linking everything together…
“/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-gcc” -w -Os -flto -fuse-linker-plugin -Wl,–gc-sections -mmcu=atmega328p -o “/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/Blink.ino.elf” “/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/sketch/Blink.ino.cpp.o” “/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/core/core.a” “-L/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp” -lm
“/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy” -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 “/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/Blink.ino.elf” “/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/Blink.ino.eep”
“/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avr-objcopy” -O ihex -R .eeprom “/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/Blink.ino.elf” “/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/Blink.ino.hex”
{runtime.tools.avrdude.path}/bin/avrdude -C{runtime.tools.avrdude.path}/etc/avrdude.conf -v -patmega328p -carduino “-P/dev/cu.wchusbserialfa410” -b115200 -D -Uflash:w:/var/folders/25/6_vlwt3s6gx4hrbgz9qltfdc0000gn/T/buildd5ae82e677127ac286f51de66781d807.tmp/Blink.ino.hex:i
