Can not run Project in newer verson of arduino IDE
Dear Sir/Medam
I have develop and tested a program 2 to 3 years ago in Arduino 1.0.3.
now the thing is that i can not start up the old version of IDE in windows 8,
and i tried to migrate a program to newer version but it shows me to many errors.
please help me as soon as possible.
Just start digging through the errors and fix them one-by-one; you might need to look at the libraries to see what exactly is going on.
A very likely cause is the use outdated 3rd party libraries.
If you post the code and (all !!) errors, we might be able to help.
Note: for outdated libraries, you can try to find newer versions (sometimes not available) or you can modify the current ones yourself (if not available).
abhishekbjani:
I'd create a fresh installation of Arduino 1.0.5-r2 in your Windows.
Then install all the old (2-3 years ago) versions of any third-party libraries you used in your project.
Then try again.
Other try:
Install latest version of the Arduino IDE
Install latest versions of any third-party libraries you used in your project
(or fix them yourself to work with a recent IDE version)
Thank you for support. i have found that the problem is with my library.
now i am facing memory problem. please kindly suggest to free more ram.
bellow is my complete code for Arduino uno
#include <IRremote.h>
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
int RECV_PIN = 8;
IRrecv irrecv(8);
decode_results results;
SdReader card; // This object holds the information for the card
FatVolume vol; // This holds the information for the partition on the card
FatReader root; // This holds the information for the filesystem on the card
FatReader f; // This holds the information for the file we're play
WaveHC wave; // This is the only wave (audio) object, since we will only play one at a time
// this handy function will return the number of bytes currently free in RAM, great for debugging!
int freeRam(void)
extern int __bss_end;
extern int *__brkval;
int free_memory;
if((int)__brkval == 0) {
free_memory = ((int)&free_memory) - ((int)&__bss_end);
else {
free_memory = ((int)&free_memory) - ((int)__brkval);
return free_memory;
void sdErrorCheck(void)
if (!card.errorCode()) return;
putstring("\n\rSD I/O error: ");
Serial.print(card.errorCode(), HEX);
putstring(", ");
Serial.println(card.errorData(), HEX);
while(1);
// set up serial port
irrecv.enableIRIn(); // Start the receiver
putstring_nl("WaveHC with different IR Code");
putstring("Free RAM: "); // This can help with debugging, running out of RAM is bad
Serial.println(freeRam()); // if this is under 150 bytes it may spell trouble!
// Set the output pins for the DAC control. This pins are defined in the library
// pinMode(2, OUTPUT);
//pinMode(3, OUTPUT);
//pinMode(4, OUTPUT);
//pinMode(5, OUTPUT);
if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
// if (!card.init()) { //play with 8 MHz spi (default faster!)
putstring_nl("Card init. failed!"); // Something went wrong, lets print out why
sdErrorCheck();
while(1); // then 'halt' - do nothing!
// enable optimize read - some cards may timeout. Disable if you're having problems
card.partialBlockRead(true);
// Now we will look for a FAT partition!
uint8_t part;
for (part = 0; part < 5; part++) { // we have up to 5 slots to look in
if (vol.init(card, part))
break; // we found one, lets bail
if (part == 5) { // if we ended up not finding one :frowning:
putstring_nl("No valid FAT partition!");
sdErrorCheck(); // Something went wrong, lets print out why
// Lets tell the user about what we found
putstring("Using partition ");
Serial.print(part, DEC);
putstring(", type is FAT");
Serial.println(vol.fatType(),DEC); // FAT16 or FAT32?
// Try to open the root directory
if (!root.openRoot(vol)) {
putstring_nl("Can't open root dir!"); // Something went wrong,
// Whew! We got past the tough parts.
putstring_nl("Ready!");
//irrecv.resume();
irrecv.decode(&results);
Serial.println((results.value));
if ((results.value) == 1)
Serial.println("\nbell");
irrecv.resume(); // Receive the next value
results.value = 0;
playcomplete("bell.wav");
// irrecv.decode(&results);
else if ((results.value) == 2)
Serial.println("\nWelcome");
results.value = 0;
playcomplete("wlcm.wav");
/* if ((results.value) == 3)
Serial.println("\nstart");
results.value = 0;
playcomplete("strt.wav");
if ((results.value) == 4)
Serial.println("\nleft");
results.value = 0;
playcomplete("left.wav");
if ((results.value) == 5 )
Serial.println("\nright");
results.value = 0;
playcomplete("right.wav");
if ((results.value) == 6)
Serial.println("\nwrong");
results.value = 0;
playcomplete("wrong.wav");
if ((results.value) == 7)
Serial.println("\nreached");
results.value = 0;
playcomplete("reached.wav");
results.value = 0;
// Plays a full file from beginning to end with no pause.
void playcomplete(char *name) {
// call our helper to find and play this name
playfile(name);
while (wave.isplaying) {
// do nothing while its playing
// now its done playing
wave.stop();// added extra
void playfile(char *name) {
// see if the wave object is currently doing something
if (wave.isplaying) {// already playing something, so stop it!
wave.stop(); // stop it
// look in the root directory and open the file
if (!f.open(root, name)) {
putstring("Couldn't open file "); Serial.print(name); return;
// OK read the file and turn it into a wave object
if (!wave.create(f)) {
putstring_nl("Not a valid WAV"); return;
// ok time to play! start playback
wave.play();
Please edit your post. Place [code] at the beginning of your code and [/code] at the end of your code.
The result will look like
your code is here
