Can not send any variable with the ehternet shield
Hello everyone,
I just got my new arduino Ethernet shield, i bought this one: http://store.arduino.cc/eu/index.php?main_page=product_info&cPath=11_5&products_id=199
I also got an arduino mega 2560.
Just tried the example project with the Ethernet shield and i am getting information back from Google, just to test.
Now i would like to send some variables to my php file on my website.
Here is a little code i make to test it:
#include <Ethernet.h>
#include <SPI.h>
byte mac[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
char serverName[] = "www.website.com";
EthernetClient client;
  Serial.println("Starting up the board");
  Serial.print("Starting up ehternet");
  Ethernet.begin(mac);
  Serial.println("....Done");
  if(currentMillis < previousMillis)
    previousMillis = 0;
  if(currentMillis - previousMillis2 > interval2)
    previousMillis2 = currentMillis;
    Serial.print("Connecting to website...");
    if (client.connect(serverName, 80)) {
      Serial.println("connected");
      client.println("GET /meterstand.php?meter1=1 HTTP/1.1");
      client.println();
      client.println();
      Serial.println("Disconnecting");
      client.stop();
      Serial.println("could not connect");
It says it’s connected and disconnected but when i look into my database it’s empty.
When i use the url in my browser everything works just fine.
I hope someone could help me because i already looked at the forum and tried several things but it does not work for me.
When you request data from a server, using the GET function, is it not reasonable to expect a response? Why are you ignoring any response?
If you were to actually read the response, perhaps a clue-by-four would whack you.
I found what the problem was, i did not use http://
I do not have to get some information from the server, i only want to send data to it to put into the sql database.
That may be, but the server is going to return information anyway, especially in the event of a failure to communicate. You should, at least in the beginning, read that response, to confirm that things are working as intended.
Ah okey i understand, what is the best way to see if it's working right?
Gee, I don't know. Maybe read the response from the server.
I think Paul is correct. Try something like this:
      // send host url for virtual servers
      client.print("Host: ");
      client.println(serverName);
      // tell server to close when finished with HTTP/1.1
      client.println("Connection: close");
      client.println();
      while(client.connected())
         // server will close the connection when finished
         // but the connection will not close until the rx buffer is empty
         while(client.available())
            Serial.write(client.read());
      Serial.println("Disconnected");
      client.stop();
edit: added host for virtual servers.
