Can not send numerical output to MQTT Server [SOLVED]
I am trying to make a simple cpunter and send numerical variables to MQTT Server.
On serial monitor I see the counters datas fine but on MQTT Screen I see them as mixed characters. (Attached)
The code is below
#include <SPI.h>
#include <Ethernet.h>
#include <PubSubClient.h>
void subscribeReceive(char* topic, byte* payload, unsigned int length);
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 202);
const char* server = "192.168.1.117";
EthernetClient ethClient;
PubSubClient mqttClient(ethClient);
int counter;
counter = 0;
Ethernet.begin(mac, ip);
delay(3000);
mqttClient.setServer(server, 1883);
if (mqttClient.connect("My Counter"))
{ Serial.println("Connected"); mqttClient.setCallback(subscribeReceive);}
{ Serial.println("NOT Connected"); }
mqttClient.loop();
mqttClient.subscribe("Counter 1");
if(mqttClient.publish("Counter 1", counter ))
{ Serial.println("Mesaj Sent"); }
{ Serial.println("Mesaj NOT Sent :("); }
counter ++;
Serial.print("Topic: ");
Serial.println(topic);
Serial.print("Message: ");
{ Serial.println(counter); }
I guess INT data type is not valid with mqttClient.publish command.
What is the way for getting the significant output on server screen?
Thaks in advance
your image
kind of. You can either transform your int into a cString and publish the ASCII text corresponding to your number or publish a binary version in which case you need to pass the address of the memory buffer (& of your int) and the number of bytes (sizeof your int)
Solved the problem with the code below
int counter;
counter = 0;
char ccounter[5];
String str(counter);
str.toCharArray(ccounter,5);
Thanks so much for your help.
Cheers
:slight_smile:
