Can not send string via Serial monitor
Hey there, noob here
I am trying to send a string " $GPGSV,2,1,08,01,40,083,46,02,17,308,41,12,07,344,39,14,22,228,45*75"
via serial monitor in code for further execution of code. But when enter the string and click on send button it gives only '$'.....need help
follwing is part of my code
void setup(){
void loop(){
 if(Serial.available()>0){
  char message=(char)Serial.read(); //"$GPGSV,2,1,08,01,40,083,46,02,17,308,41,12,07,344,39,14,22,228,45*75 ";
  // NM.toCharArray(message,i);
   Serial.println(message);
That code won't even compile. Try again.
appreciated for your concern, as i mention above this is part of my code
following is my full code
void setup(){
void loop(){
  char message=(char)Serial.read();//"$GPGSV,2,1,08,01,40,083,46,02,17,308,41,12,07,344,39,14,22,228,45*75 ";
  char*next;// pointer to substring (token)
  float value;
  next=strtok(message,",");//splitting string by "," and get 1st substring token
  Serial.println(next);// print $GPGSV
  Serial.print("NO.of Satellites: ");// NO. of satellites for full data
  (next=strtok(NULL,","));// print next string  and remove previous string
  Serial.print("Sentence No: ");
   Serial.print("satellites in View: ");
  //value=atof(next); - cut this to get exact value from sentence
  Serial.println(next);// get exact "08" of sentence
  Serial.print(" satellite PRN number: ");
  //value=atof(next);
  Serial.println(next );
  Serial.print("Elevation: ");// print elevation in degree
  Serial.print(next);
  Serial.print("°");// ASCII VALUE FOR °= (ALT +428)
  Serial.println(" ");
   Serial.print("Azimuth: ");// print Azimuth in Degree
  Serial.print(next);
  Serial.print("SNR: ");// print SNR higher is better
  //value=atof(next);
  Serial.print(next);
  Serial.print(next);
  //value=atof(next);
  Serial.print(next);
  Serial.print(next);
  //value=atof(next);
  Serial.print(next);
  Serial.print(next);
  (next=strtok(NULL,"*"));
  Serial.print("check sum : ");//print check sum data
  Serial.print("*");
Serial.read() only gets one character. You have to keep calling it over and over and adding the characters to your string one at a time. They don’t all come in at once and they don’t all read with just one call to read().
The serial input basics tutorial may be helpful. In the IDE set line endings to New Line. Then you could use the receive with start and end markers example with start marker of $ and the end marker of '/n'. The $ will not show in the receivedCharacters, though.
Delta_G:
@OP
I am converting the above text code into executable code for you; hope, you will understand why you are not seeing your all characters (that are coming from the InputBox of Serial Monitor) back in the OutputBox of the Serial Monitor.
   byte n = Serial.available(); //to check that a charterer has come from Serial Monitor
   if(n !=0)
      char x = Serial.read();     //a character has come; read it and save in variable x
      Serial.print(x);                //send the received character back at the OutputBox of Serial Monitor
If you want to insist that your style of coding should work, then you have to execute he following codes (Line ending tab of your Serial Monitor must have the option Newline):
char myMessage[100] = "";
   if(n !=0)
      Serial.readBytesUntl('\n', myMessage, 100);
      Serial.print(myMessage);   //send all received characters back at the OutputBox of Serial Monitor
@GolamMostafa thank you for your consern i had tried the code you mention in newline (line ending tab) … still it’s only displaying one character
void loop(){
 // int i;
   //String NM= Serial.readString();
   if(n !=0)
      char message = Serial.read();     //a character has come; read it and save in variable x
      Serial.print(message);      //send the received character back at the OutputBox of Serial
[code/]
i had tried the code you mention in newline (line ending tab) .... still it's only displaying one character
Please post the code you used?
Is your monitor set to terminate the line with a new line character?
Below is the mention code
char message;
  if (Serial.available() > 0) {
    // int i;
      if (n != 0)
        Serial.print(message);                //send the received character back at the OutputBox of Serial Monitor
    //char message=(char)Serial.read();//" $GPGSV,2,1,08,01,40,083,46,02,17,308,41,12,07,344,39,14,22,228,45*75 ";
    float value;
    next = strtok(message, ","); //splitting string by "," and get 1st substring token
    (next = strtok(NULL, ",")); // print next string  and remove previous string
    //value=atoi(next);
    // value=atof(next);
    //value=atof(next);
    Serial.print(next);
    Serial.print(next);
    //  add some logics here to reduc code
    //value=atof(next);
    Serial.print(next);
    Serial.print(next);
    //value=atof(next);
    Serial.print(next);
    Serial.print(next);
    //value=atof(next);
    Serial.print(next);
    Serial.print(next);
    (next = strtok(NULL, "*"));
    Serial.print("*");
  //else{
  //  Serial.end();
next = strtok(message, ",");strtok works on strings, not single characters.
Does that even compile?
You did not follow the readBytesUntil() method. You need to declare a character array to hold the received message. Serial.readBytesUntil() returns the number of characters read into the buffer. It's best to null terminate what you receive without relying on the large array with zeros at the end.
////$GPGSV,2,1,08,01,40,083,46,02,17,308,41,12,07,344,39,14,22,228,45*75
char message[100];//declare an array to hold the complete message
    // int i;
      if (n != 0)
        // char message = Serial.read();     //a character has come; read it and save in variable x
        byte numBytesReceived = Serial.readBytesUntil('\n', message, 100);
        message[numBytesReceived] = '\0'; //null terminate message
    float value;
    //value=atoi(next);
    //value=atof(next);
    Serial.print(next);
    Serial.print(next);
    //value=atof(next);
    Serial.print(next);
    Serial.print(next);
    //value=atof(next);
    Serial.print(next);
    Serial.print(next);
    //value=atof(next);
    Serial.print(next);
    Serial.print(next);
    Serial.print("*");
  //else{
  //  Serial.end();
Monitor shows
11:14:34.183 -> $GPGSV,2,1,08,01,40,083,46,02,17,308,41,12,07,344,39,14,22,228,45*75 $GPGSV
11:14:34.250 -> NO.of Satellites: 2
11:14:34.284 -> Sentence No: 1
11:14:34.317 ->  satellite PRN number: 01
11:14:34.350 -> Elevation: 40°
11:14:34.385 -> Azimuth: 083°
11:14:34.385 -> SNR: 46
11:14:34.385 ->  satellite PRN number: 02
11:14:34.418 -> Elevation: 17°
11:14:34.452 -> Azimuth: 308°
11:14:34.452 -> SNR: 41
11:14:34.487 ->  satellite PRN number: 12
11:14:34.487 -> Elevation: 07°
11:14:34.521 -> Azimuth: 344°
11:14:34.554 -> SNR: 39
11:14:34.554 ->  satellite PRN number: 14
11:14:34.587 -> Elevation: 22°
11:14:34.587 -> Azimuth: 228°
11:14:34.621 -> SNR: 45
11:14:34.621 -> check sum : *75
cattledog:
This is a very good way of null terminating a string; but, I forget it very often.
9 posts were split to a new topic: Bluetooth + Serial Monitor = Trouble?
A post was split to a new topic: I cant send/receive any thing i type any thing to the serial moniter
