Hi all,
Using Arduino 1.8.19 Linux arm 64 bit
Using Jetson Nano based Ubuntu 20.04 LTS 64 bit operating system
Used Arduino Uno without any trouble to upload and read serial communication. Port: ttyACM0
Now I am trying to use an Arduino Nano without any luck. tried Port: ttyUSB0 and Port: ttyTHS2
I have tested the Arduino Nano board on Windows and loaded a simple script to send data over the serial promp. When I try on the Jetson Port: ttyTHS2 doesn't show anything and using Port: tyyUSB0 show this:
Here is the error message:
Arduino: 1.8.19 (Linux), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/arduino-builder -dump-prefs -logger=machine -hardware /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware -tools /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/tools-builder -tools /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -built-in-libraries /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/libraries -libraries /home/jetson/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10819 -build-path /tmp/arduino_build_833147 -warnings=none -build-cache /tmp/arduino_cache_189512 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -verbose /home/jetson/Documents/Keggerator_V1/Temp_v6/Temp_v6.ino
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/arduino-builder -compile -logger=machine -hardware /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware -tools /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/tools-builder -tools /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -built-in-libraries /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/libraries -libraries /home/jetson/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10819 -build-path /tmp/arduino_build_833147 -warnings=none -build-cache /tmp/arduino_cache_189512 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.arduinoOTA.path=/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.avr-gcc.path=/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -verbose /home/jetson/Documents/Keggerator_V1/Temp_v6/Temp_v6.ino
Using board 'nano' from platform in folder: /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/arduino/avr
Using core 'arduino' from platform in folder: /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/arduino/avr
Detecting libraries used...
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/arduino/avr/cores/arduino -I/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/arduino/avr/variants/eightanaloginputs /tmp/arduino_build_833147/sketch/Temp_v6.ino.cpp -o /dev/null
Alternatives for SimpleKalmanFilter.h: [SimpleKalmanFilter@0.1]
ResolveLibrary(SimpleKalmanFilter.h)
-> candidates: [SimpleKalmanFilter@0.1]
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/arduino/avr/cores/arduino -I/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/arduino/avr/variants/eightanaloginputs -I/home/jetson/Arduino/libraries/SimpleKalmanFilter/src /tmp/arduino_build_833147/sketch/Temp_v6.ino.cpp -o /dev/null
Using cached library dependencies for file: /home/jetson/Arduino/libraries/SimpleKalmanFilter/src/SimpleKalmanFilter.cpp
Generating function prototypes...
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/arduino/avr/cores/arduino -I/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/arduino/avr/variants/eightanaloginputs -I/home/jetson/Arduino/libraries/SimpleKalmanFilter/src /tmp/arduino_build_833147/sketch/Temp_v6.ino.cpp -o /tmp/arduino_build_833147/preproc/ctags_target_for_gcc_minus_e.cpp
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_833147/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/arduino/avr/cores/arduino -I/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/arduino/avr/variants/eightanaloginputs -I/home/jetson/Arduino/libraries/SimpleKalmanFilter/src /tmp/arduino_build_833147/sketch/Temp_v6.ino.cpp -o /tmp/arduino_build_833147/sketch/Temp_v6.ino.cpp.o
Compiling libraries...
Compiling library "SimpleKalmanFilter"
Using previously compiled file: /tmp/arduino_build_833147/libraries/SimpleKalmanFilter/SimpleKalmanFilter.cpp.o
Compiling core...
Using precompiled core: /tmp/arduino_cache_189512/core/core_arduino_avr_nano_cpu_atmega328old_93c4b7950128f9ba3226281dea221313.a
Linking everything together...
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /tmp/arduino_build_833147/Temp_v6.ino.elf /tmp/arduino_build_833147/sketch/Temp_v6.ino.cpp.o /tmp/arduino_build_833147/libraries/SimpleKalmanFilter/SimpleKalmanFilter.cpp.o /tmp/arduino_build_833147/../arduino_cache_189512/core/core_arduino_avr_nano_cpu_atmega328old_93c4b7950128f9ba3226281dea221313.a -L/tmp/arduino_build_833147 -lm
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_833147/Temp_v6.ino.elf /tmp/arduino_build_833147/Temp_v6.ino.eep
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino_build_833147/Temp_v6.ino.elf /tmp/arduino_build_833147/Temp_v6.ino.hex
Using library SimpleKalmanFilter at version 0.1 in folder: /home/jetson/Arduino/libraries/SimpleKalmanFilter
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr/bin/avr-size -A /tmp/arduino_build_833147/Temp_v6.ino.elf
Sketch uses 7670 bytes (24%) of program storage space. Maximum is 30720 bytes.
Global variables use 227 bytes (11%) of dynamic memory, leaving 1821 bytes for local variables. Maximum is 2048 bytes.
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr/bin/avrdude -C/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/tmp/arduino_build_833147/Temp_v6.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/jetson/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
An error occurred while uploading the sketch
I don't understand why Arduino Uno is ok and Arduino Nano is not
Any suggestion?
Thanks
What have you got selected under Tools/Processor in the IDE menu ?
Maybe try the Old Bootloader option
Hi UKHeliBob, I have added more info to the post. I have tried all 3 options. same result...
PaulRB
July 1, 2023, 11:06am
4
@jmonsalve15 what port(s) appear, when you plug the Nano in, that were not there before?
Please do not do that in future as it can invalidate any replies that have already been made to the original post
PaulRB
July 1, 2023, 11:11am
6
Also please post long error messages inside code tags (fix post #1 like that also please).
Sorry guys. first time using a forum.
Answering @PaulRB new port is ttyUSB0
PaulRB
July 1, 2023, 11:16am
8
Could be something to do with the different USB-Serial chips used by those 2 boards. But it's not normally a problem with Linux.
PaulRB
July 1, 2023, 11:17am
9
jmonsalve15:
new port is ttyUSB0
Then those other ports are nothing to do with the Arduino Nano, you can stop testing those.
maybe, but in Windows is not a problem. Any suggestion on what can I do to test before buying another Arduino?
PaulRB
July 1, 2023, 11:23am
11
I guess this is not the cause of the problem. Can you confirm if you see that message when you upload to the Uno?
PaulRB
July 1, 2023, 11:26am
12
Windows is not based on Linux. The fact that the Nano works in Windows tells you it is not faulty.
Is there any circuit connected to the Arduino Nano? If so, disconnect that and test again.
PaulRB
July 1, 2023, 11:29am
13
jmonsalve15:
tyyUSB0 show this:
Have you matched the baud rate selection in Serial Monitor with whatever is set in the code you uploaded to the Arduino?
Here is the code with the Uno
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/arduino-builder -dump-prefs -logger=machine -hardware /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware -hardware /home/jetson/.arduino15/packages -tools /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/tools-builder -tools /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -tools /home/jetson/.arduino15/packages -built-in-libraries /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/libraries -libraries /home/jetson/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10819 -build-path /tmp/arduino_build_845524 -warnings=none -build-cache /tmp/arduino_cache_662827 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/jetson/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/jetson/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=/home/jetson/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/jetson/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -verbose /home/jetson/Documents/Keggerator_V1/Temp_v6/Temp_v6.ino
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/arduino-builder -compile -logger=machine -hardware /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware -hardware /home/jetson/.arduino15/packages -tools /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/tools-builder -tools /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -tools /home/jetson/.arduino15/packages -built-in-libraries /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/libraries -libraries /home/jetson/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10819 -build-path /tmp/arduino_build_845524 -warnings=none -build-cache /tmp/arduino_cache_662827 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/jetson/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/jetson/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=/home/jetson/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/jetson/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -verbose /home/jetson/Documents/Keggerator_V1/Temp_v6/Temp_v6.ino
Using board 'uno' from platform in folder: /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6
Using core 'arduino' from platform in folder: /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /tmp/arduino_build_845524/sketch/Temp_v6.ino.cpp -o /dev/null
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/home/jetson/Arduino/libraries/SimpleKalmanFilter/src /tmp/arduino_build_845524/sketch/Temp_v6.ino.cpp -o /dev/null
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/home/jetson/Arduino/libraries/SimpleKalmanFilter/src /home/jetson/Arduino/libraries/SimpleKalmanFilter/src/SimpleKalmanFilter.cpp -o /dev/null
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/home/jetson/Arduino/libraries/SimpleKalmanFilter/src /tmp/arduino_build_845524/sketch/Temp_v6.ino.cpp -o /tmp/arduino_build_845524/preproc/ctags_target_for_gcc_minus_e.cpp
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_845524/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/home/jetson/Arduino/libraries/SimpleKalmanFilter/src /tmp/arduino_build_845524/sketch/Temp_v6.ino.cpp -o /tmp/arduino_build_845524/sketch/Temp_v6.ino.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard -I/home/jetson/Arduino/libraries/SimpleKalmanFilter/src /home/jetson/Arduino/libraries/SimpleKalmanFilter/src/SimpleKalmanFilter.cpp -o /tmp/arduino_build_845524/libraries/SimpleKalmanFilter/SimpleKalmanFilter.cpp.o
Compiling core...
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/wiring_pulse.S -o /tmp/arduino_build_845524/core/wiring_pulse.S.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/WInterrupts.c -o /tmp/arduino_build_845524/core/WInterrupts.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/wiring_analog.c -o /tmp/arduino_build_845524/core/wiring_analog.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/hooks.c -o /tmp/arduino_build_845524/core/hooks.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/wiring.c -o /tmp/arduino_build_845524/core/wiring.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/wiring_digital.c -o /tmp/arduino_build_845524/core/wiring_digital.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/wiring_pulse.c -o /tmp/arduino_build_845524/core/wiring_pulse.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/wiring_shift.c -o /tmp/arduino_build_845524/core/wiring_shift.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/CDC.cpp -o /tmp/arduino_build_845524/core/CDC.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/HardwareSerial1.cpp -o /tmp/arduino_build_845524/core/HardwareSerial1.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/HardwareSerial.cpp -o /tmp/arduino_build_845524/core/HardwareSerial.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/HardwareSerial0.cpp -o /tmp/arduino_build_845524/core/HardwareSerial0.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/HardwareSerial2.cpp -o /tmp/arduino_build_845524/core/HardwareSerial2.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/HardwareSerial3.cpp -o /tmp/arduino_build_845524/core/HardwareSerial3.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/IPAddress.cpp -o /tmp/arduino_build_845524/core/IPAddress.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/PluggableUSB.cpp -o /tmp/arduino_build_845524/core/PluggableUSB.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/Print.cpp -o /tmp/arduino_build_845524/core/Print.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/Stream.cpp -o /tmp/arduino_build_845524/core/Stream.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/Tone.cpp -o /tmp/arduino_build_845524/core/Tone.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/USBCore.cpp -o /tmp/arduino_build_845524/core/USBCore.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/WMath.cpp -o /tmp/arduino_build_845524/core/WMath.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/WString.cpp -o /tmp/arduino_build_845524/core/WString.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/abi.cpp -o /tmp/arduino_build_845524/core/abi.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/main.cpp -o /tmp/arduino_build_845524/core/main.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/standard /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/new.cpp -o /tmp/arduino_build_845524/core/new.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/wiring_pulse.S.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/WInterrupts.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/hooks.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/wiring.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/wiring_analog.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/wiring_digital.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/wiring_pulse.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/wiring_shift.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/CDC.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/HardwareSerial.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/HardwareSerial0.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/HardwareSerial1.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/HardwareSerial2.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/HardwareSerial3.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/IPAddress.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/PluggableUSB.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/Print.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/Stream.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/Tone.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/USBCore.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/WMath.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/WString.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/abi.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/main.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc-ar rcs /tmp/arduino_build_845524/core/core.a /tmp/arduino_build_845524/core/new.cpp.o
Archiving built core (caching) in: /tmp/arduino_cache_662827/core/core_arduino_avr_uno_2631a9dbd6aa4bab076bef9a567f3bb8.a
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /tmp/arduino_build_845524/Temp_v6.ino.elf /tmp/arduino_build_845524/sketch/Temp_v6.ino.cpp.o /tmp/arduino_build_845524/libraries/SimpleKalmanFilter/SimpleKalmanFilter.cpp.o /tmp/arduino_build_845524/core/core.a -L/tmp/arduino_build_845524 -lm
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_845524/Temp_v6.ino.elf /tmp/arduino_build_845524/Temp_v6.ino.eep
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino_build_845524/Temp_v6.ino.elf /tmp/arduino_build_845524/Temp_v6.ino.hex
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-size -A /tmp/arduino_build_845524/Temp_v6.ino.elf
Sketch uses 7664 bytes (23%) of program storage space. Maximum is 32256 bytes.
/home/jetson/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/home/jetson/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyACM0 -b115200 -D -Uflash:w:/tmp/arduino_build_845524/Temp_v6.ino.hex:i
System wide configuration file is "/home/jetson/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
Using Port : /dev/ttyACM0
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "/tmp/arduino_build_845524/Temp_v6.ino.hex"
avrdude: writing flash (7664 bytes):
Writing | ################################################## | 100% 1.23s
avrdude: 7664 bytes of flash written
avrdude: verifying flash memory against /tmp/arduino_build_845524/Temp_v6.ino.hex:
avrdude: load data flash data from input file /tmp/arduino_build_845524/Temp_v6.ino.hex:
avrdude: input file /tmp/arduino_build_845524/Temp_v6.ino.hex contains 7664 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.99s
Tried again with the Nano without any circuit, same issue:
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/arduino-builder -dump-prefs -logger=machine -hardware /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware -hardware /home/jetson/.arduino15/packages -tools /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/tools-builder -tools /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -tools /home/jetson/.arduino15/packages -built-in-libraries /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/libraries -libraries /home/jetson/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10819 -build-path /tmp/arduino_build_845524 -warnings=none -build-cache /tmp/arduino_cache_662827 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/jetson/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/jetson/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=/home/jetson/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/jetson/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -verbose /home/jetson/Documents/Keggerator_V1/Temp_v6/Temp_v6.ino
/home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/arduino-builder -compile -logger=machine -hardware /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware -hardware /home/jetson/.arduino15/packages -tools /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/tools-builder -tools /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/hardware/tools/avr -tools /home/jetson/.arduino15/packages -built-in-libraries /home/jetson/Downloads/arduino-1.8.19-linuxaarch64/arduino-1.8.19/libraries -libraries /home/jetson/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10819 -build-path /tmp/arduino_build_845524 -warnings=none -build-cache /tmp/arduino_cache_662827 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/jetson/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/jetson/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=/home/jetson/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/jetson/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -verbose /home/jetson/Documents/Keggerator_V1/Temp_v6/Temp_v6.ino
Using board 'nano' from platform in folder: /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /tmp/arduino_build_845524/sketch/Temp_v6.ino.cpp -o /dev/null
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs -I/home/jetson/Arduino/libraries/SimpleKalmanFilter/src /tmp/arduino_build_845524/sketch/Temp_v6.ino.cpp -o /dev/null
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs -I/home/jetson/Arduino/libraries/SimpleKalmanFilter/src /home/jetson/Arduino/libraries/SimpleKalmanFilter/src/SimpleKalmanFilter.cpp -o /dev/null
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs -I/home/jetson/Arduino/libraries/SimpleKalmanFilter/src /tmp/arduino_build_845524/sketch/Temp_v6.ino.cpp -o /tmp/arduino_build_845524/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs -I/home/jetson/Arduino/libraries/SimpleKalmanFilter/src /tmp/arduino_build_845524/sketch/Temp_v6.ino.cpp -o /tmp/arduino_build_845524/sketch/Temp_v6.ino.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs -I/home/jetson/Arduino/libraries/SimpleKalmanFilter/src /home/jetson/Arduino/libraries/SimpleKalmanFilter/src/SimpleKalmanFilter.cpp -o /tmp/arduino_build_845524/libraries/SimpleKalmanFilter/SimpleKalmanFilter.cpp.o
Compiling core...
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/wiring_pulse.S -o /tmp/arduino_build_845524/core/wiring_pulse.S.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/WInterrupts.c -o /tmp/arduino_build_845524/core/WInterrupts.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/hooks.c -o /tmp/arduino_build_845524/core/hooks.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/wiring.c -o /tmp/arduino_build_845524/core/wiring.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/wiring_analog.c -o /tmp/arduino_build_845524/core/wiring_analog.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/wiring_digital.c -o /tmp/arduino_build_845524/core/wiring_digital.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/wiring_pulse.c -o /tmp/arduino_build_845524/core/wiring_pulse.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/wiring_shift.c -o /tmp/arduino_build_845524/core/wiring_shift.c.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/HardwareSerial1.cpp -o /tmp/arduino_build_845524/core/HardwareSerial1.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/HardwareSerial.cpp -o /tmp/arduino_build_845524/core/HardwareSerial.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/CDC.cpp -o /tmp/arduino_build_845524/core/CDC.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/HardwareSerial0.cpp -o /tmp/arduino_build_845524/core/HardwareSerial0.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/HardwareSerial2.cpp -o /tmp/arduino_build_845524/core/HardwareSerial2.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/HardwareSerial3.cpp -o /tmp/arduino_build_845524/core/HardwareSerial3.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/IPAddress.cpp -o /tmp/arduino_build_845524/core/IPAddress.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/Print.cpp -o /tmp/arduino_build_845524/core/Print.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/PluggableUSB.cpp -o /tmp/arduino_build_845524/core/PluggableUSB.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/Stream.cpp -o /tmp/arduino_build_845524/core/Stream.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/Tone.cpp -o /tmp/arduino_build_845524/core/Tone.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/USBCore.cpp -o /tmp/arduino_build_845524/core/USBCore.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/WMath.cpp -o /tmp/arduino_build_845524/core/WMath.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/WString.cpp -o /tmp/arduino_build_845524/core/WString.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/abi.cpp -o /tmp/arduino_build_845524/core/abi.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/main.cpp -o /tmp/arduino_build_845524/core/main.cpp.o
/home/jetson/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino -I/home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/variants/eightanaloginputs /home/jetson/.arduino15/packages/arduino/hardware/avr/1.8.6/cores/arduino/new.cpp -o /tmp/arduino_build_845524/core/new.cpp.o
Archiving built core (caching) in: /tmp/arduino_cache_662827/core/core_arduino_avr_nano_cpu_atmega328old_2631a9dbd6aa4bab076bef9a567f3bb8.a
Sketch uses 7664 bytes (24%) of program storage space. Maximum is 30720 bytes.
/home/jetson/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/home/jetson/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/tmp/arduino_build_845524/Temp_v6.ino.hex:i
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
I'm not familiar with the Jetson Nano. Seeing that it's Linux, did you check the output of lsusb and the output of dmesg -w .
Run the latter with the board disconnected; the application will not close. Next connect the board and check for any errors and for the word BRLTTY ; if you find the latter, uninstall it.
PaulRB
July 1, 2023, 1:35pm
17
In case you are concerned about it, I have uploaded to Nano many many times using Ubuntu 20.04, and 22.04 with no problems, and so have many others. This was on desktop PC and laptop, but that should not make any difference.
PaulRB
July 1, 2023, 1:40pm
18
Are you using the same USB cable, between the Arduino Nano and the Jetson Nano, that you used with the windows PC?
system
Closed
December 28, 2023, 1:40pm
19
