can not upload to ardunio due
hi i can not upload to my arduino
got this error
Sketch uses 444 bytes (3%) of program storage space. Maximum is 14336 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 1015 bytes for local variables. Maximum is 1024 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa7
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa7
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Looks like you have 168 for Duemilanove board setup, but a Due (a totally different board type) for the Com port?
Are there other options for the Port? I'd expect the Duemilanove to have an FT232 for the USB interface. the Due did not.
i tested these port and also arduino 328 and avr isp bootloader
but got that error
all pin is empty i just want to upload an empty project
As CrossRoads explained, you have the wrong board selected from the Tools > Board menu. Despite the somewhat similar names, the Due and the Duemilanove are very different boards.
Do this:
  • Tools > Board > Boards Manager
  • Wait for the downloads to finish.
  • From the list of boards platforms, select "Arduino SAM Boards (32-bits ARM Cortex-M3)"
  • Click the "Install" button.
  • Wait for installation to finish.
  • Click the "Close" button.
  • Tools > Board > Arduino Due (Programming Port)
  • Now try uploading again.
oh i didn't got that thanks
it works
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
