Can not write files to 2 micro SD card modules connected to a Mega.
I am trying to write a text file ("test.txt") to each of the micro SD card modules. But only 1 module has the test.txt file on it the other micro sd card is blank. I have wired it as follows:
pin 50 to both MISO.
pin 51 to both MOSI.
pin 52 to both SCK.
pin 9 to CS on one micro SD card.
pin 10 to cs on one micro SD card.
3.3v to both VCC.
Ground to both GND.
Here is the code...
// Libraries to drive the SD Card. ******************************
#include <SD.h>
/* The SD card communicates over pins for the Arduino Mega:
MOSI - Pin 51
MISO - Pin 50
Clock - Pin 52
Chip Select - pin 53
Yellow LED goes on during a read operation.
Red LED goes on during a write operation.
Use '(char *)filename.c_str()' to pass a string variable to concatinate the file name.
Use 'filename.c_str()' to pass a variable file name to the FILE.open(fn,option) command.
Make sure to disconnect the power to the SD card shield prior to removing
the chip.
int baudrate = 9600; //set the baud rate.
String filename; //Store file name.
String root = "/";
int var; //Case statement variable.
int countMakeDirectory = 0;//Test.
int countMakeFile = 0;//Test.
int countListDirectory = 0;//Test.
int loopCounter = 0;//Test.
int rootCounter = 1;//test.
int CSpinRequired = 53; //Chip Select pin required by SD library.
int CSpin1 = 10; //Chip Select pin 2.
int CSpin2 = 9; //Chip Select pin 3.
File myFile; //File to open.
//setup *************************************************************************
Serial.begin(baudrate); // Start serial communication.
pinMode(CSpinRequired, OUTPUT);//Required by the SD library.
pinMode(CSpin1, OUTPUT);//Used as Chip Select.
pinMode(CSpin2, OUTPUT);//Used as Chip Select.
root = "/"; //Set the root directory.
}//End setup.
//loop *********************************************************************************
loopCounter = loopCounter + 1;
Serial.print(F("Loop Counter--> "));
Serial.println(loopCounter);
var= random(1,4); //Test random CASE option.
filename = ""; //test: reset filename. line 200
if ( (loopCounter % 2) == 0) { //If loopCounter is Even.
Serial.println(F("OLD CARD"));//Use this option to reduce SRAM memory useage and increase 32K main memory useage.
digitalWrite(CSpin1, LOW);//Set to HIGH to Disable. Set to LOW to Enable.
digitalWrite(CSpin2, HIGH);//Set to HIGH to Disable. Set to LOW to Enable.
SD.begin(CSpinRequired);
}//End if.
else { //If loopCounter is Odd.
Serial.println(F("NEW CARD"));//Use this option to reduce SRAM memory useage and increase 32K main memory useage.
digitalWrite(CSpin1, HIGH);//Set to HIGH to Disable. Set to LOW to Enable.
digitalWrite(CSpin2, LOW);//Set to HIGH to Disable. Set to LOW to Enable.
}//End else.
switch(var){
case 1:
Serial.println(F("List Directory..."));
ListDirectory();//Call function.
countListDirectory = countListDirectory + 1;
case 2:
Serial.println(F("Make File..."));
MakeFile(); //Call function.
countMakeFile = countMakeFile + 1;
case 3:
Serial.println(F("Make Directory..."));
MakeDirectory(); //Call function.
countMakeDirectory = countMakeDirectory + 1;
} //End case statement.
if( loopCounter >= 10){
Serial.println(F("****************************************"));
Serial.print(F("Total List Directory..."));
Serial.println(countListDirectory);
Serial.print(F("Total Make File..."));
Serial.println(countMakeFile);
Serial.print(F("Total Make Directory..."));
Serial.println(countMakeDirectory);
while(true); //Test.Stop program.
} //End if.
} //End loop.
//MakeDirectory **************************************************
void MakeDirectory(){
Serial.println(F("(1)Make the directory...")); //debug.
//generate a random file name.Remove.
int i = random(65,90);//test.
filename = String((char) i);//test.
Serial.print(F("(2)Directory: "));//test.
filename = root + filename;
Serial.println(filename);//test.
SD.mkdir("/DIR1/");
delay(500); //Wait for SD card to complete.
myFile.close(); //Write the file to the SD card.
} //End MakeDirectory function.
//MakeFile **********************************************************
void MakeFile(){
Serial.println(F("(1)Make a file...")); //debug.
int i = random(65,90);//test.Create a chara A to Z.
filename = root + String((char) i) + ".txt";//test.
Serial.print(F("(2)"));//test.
myFile = SD.open("FILE.TXT", FILE_WRITE);
delay(500);//Wait for file to open.
myFile.close(); //Close the file and save it to the SD card.
delay(500);//Wait for file to close.
} //end MakeFile function.
//ListDirectory **************************************************
void ListDirectory(){
myFile = SD.open("/"); //Root directory.
delay(200);//Wait for myFile to open.
PrintDirectory(myFile, 0);
myFile.close();//Close the myFile.
delay(200);//Wait for file to close.
}//end ListDirectory function.
// PrintDirectory **************************************************
// This code is from the arduino library SD Listfiles ( https://www.arduino.cc/en/Tutorial/listfiles ).
// The code does not work correctly. The last entrys in a subdirectory does not display.
void PrintDirectory(File dir, int numTabs) {
dir.seek(0); // Add seek!!!
while (true) {
File entry = dir.openNextFile();
if (! entry) {
dir.rewindDirectory();
} //End if.
for (uint8_t i = 0; i < numTabs; i++) {
Serial.print('\t');
} //End for.
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
PrintDirectory(entry, numTabs + 1);
} //End if.
// files have sizes, directories do not
Serial.print("\t\t");
Serial.println(entry.size(), DEC);
} //End else
entry.close(); //Write the file to the disk.
} //End while.
} //End PrintDirectory function.
Can anyone help???
Thx.
Please edit your post to add code tags: ("</>") button.
