Can program program through AVRburner, but Arduino won't
I'm trying to program a chip to be used with Arduino, but having no results.
I'm using a USBasp to upload to a atmega8. I can upload any hex I want through Burner extreme without any issue.
When I try to get a bootloader burned through the IDE, but it doesn't work (error attached).
I've tried uploading the bootloader hex through burner extreme and it uploads succefully, but the IDE still doesn't like it. I've tried to just go through the IDE burn bootloader command, with no luck.
I've tried with a virgin chip as well and it makes no difference.
Can anyone tell me what I'm doing wrong?
Arduino: 1.8.9 (Windows 10), Board: "ATmega8, Yes (UART0), BOD disabled, LTO disabled, Internal 8 MHz"
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\goldi\Documents\Arduino\hardware\MiniCore-master\avr/avrdude.conf"
         Using Port                    : usb
         Using Programmer              : usbasp
         AVR Part                      : ATmega8
         Chip Erase delay              : 10000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom         4    20   128    0 no        512    4      0  9000  9000 0xff 0xff
           flash         33    10    64    0 yes      8192   64    128  4500  4500 0xff 0x00
           lfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           efuse          0     0     0    0 no          0    0      0     0     0 0x00 0x00
           lock           0     0     0    0 no          1    0      0  2000  2000 0x00 0x00
           calibration    0     0     0    0 no          4    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : usbasp
         Description     : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: error: program enable: target doesn't answer. 0
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
Error while burning bootloader.
option enabled in File -> Preferences.
This error is caused by using the libusb-win32 driver with Arduino's version of avrdude:
The solution is to use the libusbK driver instead:
  • Download Zadig: http://zadig.akeo.ie/. Note that Zadig is recommended on the official USBasp page: http://www.fischl.de/usbasp/.
  • Plug in your USBasp
  • Start Zadig
  • From the dropdown menu, select USBasp. If it doesn't show up on the menu, then select Options > List all devices and check again.
  • Click the up or down arrows next to the Driver selection box on the right side until you see libusbK.
  • Click the "Replace Driver" button.
  • After it finishes you can close Zadig.
