Okay, the invocations are identical, as are the outputs up until the read/verify stage. The macOS version also has an additional output line for each progress update.
The output for the same source code compiled on each platform:
macOS output:
Sketch uses 135840 bytes (26%) of program storage space. Maximum is 507904 bytes.
Global variables use 9132 bytes of dynamic memory.
Performing 1200-bps touch reset on serial port /dev/cu.usbmodem2101
Waiting for upload port...
No upload port found, using /dev/cu.usbmodem2101 as fallback
"/Users/rmann/Library/Arduino15/packages/arduino/tools/bossac/1.9.1-arduino1/bossac" -i -d -a --port=cu.usbmodem2101 -U -e -w -v --offset=0x4000 "/Users/rmann/Library/Caches/arduino/sketches/833020ED47CB87CD067EA89A46C23BA8/WriteDigitalOutput.ino.bin" -R
Set binary mode
version()=v1.1 [Arduino:XYZ] Sep 14 2020 14:10:57
Connected at 921600 baud
readWord(addr=0)=0x2000e430
readWord(addr=0xe000ed00)=0x410fc241
readWord(addr=0x4)=0x59d
readWord(addr=0x41002018)=0x61830303
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x80)
writeWord(addr=0x20004020,value=0x20008000)
readByte(addr=0x804000)=0x39
readByte(addr=0x804001)=0x92
readByte(addr=0x804008)=0xff
readByte(addr=0x804009)=0xff
readByte(addr=0x80400a)=0xff
readByte(addr=0x80400b)=0xff
Device : ATSAME53x19
Version : v1.1 [Arduino:XYZ] Sep 14 2020 14:10:57
Address : 0x0
Pages : 1024
Page Size : 512 bytes
Total Size : 512KB
Planes : 1
Lock Regions : 32
Locked : none
Security : false
BOD : false
BOR : true
Erase flash
chipErase(addr=0x4000)
Done in 2.366 seconds
Write 136496 bytes to flash (267 pages)
[ ] 0% (0/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x4000, size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x5000, size=0x1000)
[= ] 5% (16/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x6000, size=0x1000)
[== ] 8% (24/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x7000, size=0x1000)
[=== ] 11% (32/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x8000, size=0x1000)
[==== ] 14% (40/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x9000, size=0x1000)
[===== ] 17% (48/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0xa000, size=0x1000)
[====== ] 20% (56/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0xb000, size=0x1000)
[======= ] 23% (64/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0xc000, size=0x1000)
[======== ] 26% (72/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0xd000, size=0x1000)
[======== ] 29% (80/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0xe000, size=0x1000)
[========= ] 32% (88/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0xf000, size=0x1000)
[========== ] 35% (96/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x10000, size=0x1000)
[=========== ] 38% (104/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x11000, size=0x1000)
[============ ] 41% (112/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x12000, size=0x1000)
[============= ] 44% (120/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x13000, size=0x1000)
[============== ] 47% (128/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x14000, size=0x1000)
[=============== ] 50% (136/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x15000, size=0x1000)
[================ ] 53% (144/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x16000, size=0x1000)
[================= ] 56% (152/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x17000, size=0x1000)
[================= ] 59% (160/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x18000, size=0x1000)
[================== ] 62% (168/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x19000, size=0x1000)
[=================== ] 65% (176/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x1a000, size=0x1000)
[==================== ] 68% (184/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x1b000, size=0x1000)
[===================== ] 71% (192/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x1c000, size=0x1000)
[====================== ] 74% (200/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x1d000, size=0x1000)
[======================= ] 77% (208/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x1e000, size=0x1000)
[======================== ] 80% (216/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x1f000, size=0x1000)
[========================= ] 83% (224/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x20000, size=0x1000)
[========================== ] 86% (232/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x21000, size=0x1000)
[========================== ] 89% (240/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x22000, size=0x1000)
[=========================== ] 92% (248/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x23000, size=0x1000)
[============================ ] 95% (256/267 pages)write(addr=0x20004034,size=0x1000)
writeBuffer(scr_addr=0x20004034, dst_addr=0x24000, size=0x1000)
[============================= ] 98% (264/267 pages)write(addr=0x20004034,size=0x600)
writeBuffer(scr_addr=0x20004034, dst_addr=0x25000, size=0x600)
[==============================] 100% (267/267 pages)
Done in 0.740 seconds
Verify 136496 bytes of flash
checksumBuffer(start_addr=0x4000, size=0x200) = 489d
read(addr=0x4000,size=0x200)
checksumBuffer(start_addr=0x4200, size=0x200) = d8ef
read(addr=0x4200,size=0x200)
checksumBuffer(start_addr=0x4400, size=0x200) = b605
read(addr=0x4400,size=0x200)
checksumBuffer(start_addr=0x4600, size=0x200) = 137f
read(addr=0x4600,size=0x200)
checksumBuffer(start_addr=0x4800, size=0x200) = 5db8
read(addr=0x4800,size=0x200)
checksumBuffer(start_addr=0x4a00, size=0x200) = a238
read(addr=0x4a00,size=0x200)
checksumBuffer(start_addr=0x4c00, size=0x200) = d072
read(addr=0x4c00,size=0x200)
checksumBuffer(start_addr=0x4e00, size=0x200) = 3623
read(addr=0x4e00,size=0x200)
checksumBuffer(start_addr=0x5000, size=0x200) = 466c
read(addr=0x5000,size=0x200)
[= ] 3% (9/267 pages)checksumBuffer(start_addr=0x5200, size=0x200) = 5067
read(addr=0x5200,size=0x200)
[= ] 3% (10/267 pages)checksumBuffer(start_addr=0x5400, size=0x200) = a4c2
read(addr=0x5400,size=0x200)
[= ] 4% (11/267 pages)checksumBuffer(start_addr=0x5600, size=0x200) = c013
read(addr=0x5600,size=0x200)
[= ] 4% (12/267 pages)checksumBuffer(start_addr=0x5800, size=0x200) = e738
read(addr=0x5800,size=0x200)
[= ] 4% (13/267 pages)checksumBuffer(start_addr=0x5a00, size=0x200) = 13d6
read(addr=0x5a00,size=0x200)
[= ] 5% (14/267 pages)checksumBuffer(start_addr=0x5c00, size=0x200) = f163
read(addr=0x5c00,size=0x200)
[= ] 5% (15/267 pages)checksumBuffer(start_addr=0x5e00, size=0x200) = f902
read(addr=0x5e00,size=0x200)
[= ] 5% (16/267 pages)checksumBuffer(start_addr=0x6000, size=0x200) = e298
read(addr=0x6000,size=0x200)
[= ] 6% (17/267 pages)checksumBuffer(start_addr=0x6200, size=0x200) = e503
read(addr=0x6200,size=0x200)
[== ] 6% (18/267 pages)checksumBuffer(start_addr=0x6400, size=0x200) = b22b
read(addr=0x6400,size=0x200)
[== ] 7% (19/267 pages)checksumBuffer(start_addr=0x6600, size=0x200) = abb5
read(addr=0x6600,size=0x200)
[== ] 7% (20/267 pages)checksumBuffer(start_addr=0x6800, size=0x200) = 5227
read(addr=0x6800,size=0x200)
[== ] 7% (21/267 pages)checksumBuffer(start_addr=0x6a00, size=0x200) = 55f7
read(addr=0x6a00,size=0x200)
[== ] 8% (22/267 pages)checksumBuffer(start_addr=0x6c00, size=0x200) = 8940
read(addr=0x6c00,size=0x200)
[== ] 8% (23/267 pages)checksumBuffer(start_addr=0x6e00, size=0x200) = e73e
read(addr=0x6e00,size=0x200)
[== ] 8% (24/267 pages)checksumBuffer(start_addr=0x7000, size=0x200) = f8cc
read(addr=0x7000,size=0x200)
[== ] 9% (25/267 pages)checksumBuffer(start_addr=0x7200, size=0x200) = d24d
read(addr=0x7200,size=0x200)
[== ] 9% (26/267 pages)checksumBuffer(start_addr=0x7400, size=0x200) = 974e
read(addr=0x7400,size=0x200)
[=== ] 10% (27/267 pages)checksumBuffer(start_addr=0x7600, size=0x200) = c7ae
read(addr=0x7600,size=0x200)
[=== ] 10% (28/267 pages)checksumBuffer(start_addr=0x7800, size=0x200) = 96fe
read(addr=0x7800,size=0x200)
[=== ] 10% (29/267 pages)checksumBuffer(start_addr=0x7a00, size=0x200) = 968a
read(addr=0x7a00,size=0x200)
[=== ] 11% (30/267 pages)checksumBuffer(start_addr=0x7c00, size=0x200) = 2212
read(addr=0x7c00,size=0x200)
[=== ] 11% (31/267 pages)checksumBuffer(start_addr=0x7e00, size=0x200) = 9b5
read(addr=0x7e00,size=0x200)
[=== ] 11% (32/267 pages)checksumBuffer(start_addr=0x8000, size=0x200) = 1c82
read(addr=0x8000,size=0x200)
[=== ] 12% (33/267 pages)checksumBuffer(start_addr=0x8200, size=0x200) = 3615
read(addr=0x8200,size=0x200)
[=== ] 12% (34/267 pages)checksumBuffer(start_addr=0x8400, size=0x200) = 7433
read(addr=0x8400,size=0x200)
[=== ] 13% (35/267 pages)checksumBuffer(start_addr=0x8600, size=0x200) = 286b
read(addr=0x8600,size=0x200)
[==== ] 13% (36/267 pages)checksumBuffer(start_addr=0x8800, size=0x200) = 42ad
read(addr=0x8800,size=0x200)
[==== ] 13% (37/267 pages)checksumBuffer(start_addr=0x8a00, size=0x200) = af72
read(addr=0x8a00,size=0x200)
[==== ] 14% (38/267 pages)checksumBuffer(start_addr=0x8c00, size=0x200) = 3e82
read(addr=0x8c00,size=0x200)
[==== ] 14% (39/267 pages)checksumBuffer(start_addr=0x8e00, size=0x200) = c23e
read(addr=0x8e00,size=0x200)
[==== ] 14% (40/267 pages)checksumBuffer(start_addr=0x9000, size=0x200) = ee0c
read(addr=0x9000,size=0x200)
[==== ] 15% (41/267 pages)checksumBuffer(start_addr=0x9200, size=0x200) = 77b0
read(addr=0x9200,size=0x200)
[==== ] 15% (42/267 pages)checksumBuffer(start_addr=0x9400, size=0x200) = 6a57
read(addr=0x9400,size=0x200)
[==== ] 16% (43/267 pages)checksumBuffer(start_addr=0x9600, size=0x200) = 3d9d
read(addr=0x9600,size=0x200)
[==== ] 16% (44/267 pages)checksumBuffer(start_addr=0x9800, size=0x200) = ab26
read(addr=0x9800,size=0x200)
[===== ] 16% (45/267 pages)checksumBuffer(start_addr=0x9a00, size=0x200) = 239f
read(addr=0x9a00,size=0x200)
[===== ] 17% (46/267 pages)checksumBuffer(start_addr=0x9c00, size=0x200) = f1aa
read(addr=0x9c00,size=0x200)
[===== ] 17% (47/267 pages)checksumBuffer(start_addr=0x9e00, size=0x200) = 4eb8
read(addr=0x9e00,size=0x200)
[===== ] 17% (48/267 pages)checksumBuffer(start_addr=0xa000, size=0x200) = f68
read(addr=0xa000,size=0x200)
[===== ] 18% (49/267 pages)checksumBuffer(start_addr=0xa200, size=0x200) = 4da2
read(addr=0xa200,size=0x200)
[===== ] 18% (50/267 pages)checksumBuffer(start_addr=0xa400, size=0x200) = 3578
read(addr=0xa400,size=0x200)
[===== ] 19% (51/267 pages)checksumBuffer(start_addr=0xa600, size=0x200) = ed44
read(addr=0xa600,size=0x200)
[===== ] 19% (52/267 pages)checksumBuffer(start_addr=0xa800, size=0x200) = a8ae
read(addr=0xa800,size=0x200)
[===== ] 19% (53/267 pages)checksumBuffer(start_addr=0xaa00, size=0x200) = 8f4c
read(addr=0xaa00,size=0x200)
[====== ] 20% (54/267 pages)checksumBuffer(start_addr=0xac00, size=0x200) = 307b
read(addr=0xac00,size=0x200)
[====== ] 20% (55/267 pages)checksumBuffer(start_addr=0xae00, size=0x200) = 381c
read(addr=0xae00,size=0x200)
[====== ] 20% (56/267 pages)checksumBuffer(start_addr=0xb000, size=0x200) = d8fa
read(addr=0xb000,size=0x200)
[====== ] 21% (57/267 pages)checksumBuffer(start_addr=0xb200, size=0x200) = 364d
read(addr=0xb200,size=0x200)
[====== ] 21% (58/267 pages)checksumBuffer(start_addr=0xb400, size=0x200) = de47
read(addr=0xb400,size=0x200)
[====== ] 22% (59/267 pages)checksumBuffer(start_addr=0xb600, size=0x200) = f3e2
read(addr=0xb600,size=0x200)
[====== ] 22% (60/267 pages)checksumBuffer(start_addr=0xb800, size=0x200) = 9e17
read(addr=0xb800,size=0x200)
[====== ] 22% (61/267 pages)checksumBuffer(start_addr=0xba00, size=0x200) = 178d
read(addr=0xba00,size=0x200)
[====== ] 23% (62/267 pages)checksumBuffer(start_addr=0xbc00, size=0x200) = 80cc
read(addr=0xbc00,size=0x200)
[======= ] 23% (63/267 pages)checksumBuffer(start_addr=0xbe00, size=0x200) = 86ae
read(addr=0xbe00,size=0x200)
[======= ] 23% (64/267 pages)checksumBuffer(start_addr=0xc000, size=0x200) = e868
[======= ] 24% (65/267 pages)checksumBuffer(start_addr=0xc200, size=0x200) = 173b
[======= ] 24% (66/267 pages)checksumBuffer(start_addr=0xc400, size=0x200) = c551
[======= ] 25% (67/267 pages)checksumBuffer(start_addr=0xc600, size=0x200) = a91f
[======= ] 25% (68/267 pages)checksumBuffer(start_addr=0xc800, size=0x200) = b894
[======= ] 25% (69/267 pages)checksumBuffer(start_addr=0xca00, size=0x200) = 4a44
[======= ] 26% (70/267 pages)checksumBuffer(start_addr=0xcc00, size=0x200) = aac6
[======= ] 26% (71/267 pages)checksumBuffer(start_addr=0xce00, size=0x200) = b96
[======== ] 26% (72/267 pages)checksumBuffer(start_addr=0xd000, size=0x200) = d1df
read(addr=0xd000,size=0x200)
[======== ] 27% (73/267 pages)checksumBuffer(start_addr=0xd200, size=0x200) = cd71
read(addr=0xd200,size=0x200)
[======== ] 27% (74/267 pages)checksumBuffer(start_addr=0xd400, size=0x200) = 376c
read(addr=0xd400,size=0x200)
[======== ] 28% (75/267 pages)checksumBuffer(start_addr=0xd600, size=0x200) = a534
read(addr=0xd600,size=0x200)
[======== ] 28% (76/267 pages)checksumBuffer(start_addr=0xd800, size=0x200) = 9d31
read(addr=0xd800,size=0x200)
[======== ] 28% (77/267 pages)checksumBuffer(start_addr=0xda00, size=0x200) = 23e
read(addr=0xda00,size=0x200)
[======== ] 29% (78/267 pages)checksumBuffer(start_addr=0xdc00, size=0x200) = 14c3
read(addr=0xdc00,size=0x200)
[======== ] 29% (79/267 pages)checksumBuffer(start_addr=0xde00, size=0x200) = aeb6
read(addr=0xde00,size=0x200)
[======== ] 29% (80/267 pages)checksumBuffer(start_addr=0xe000, size=0x200) = d177
read(addr=0xe000,size=0x200)
[========= ] 30% (81/267 pages)checksumBuffer(start_addr=0xe200, size=0x200) = 2780
read(addr=0xe200,size=0x200)
[========= ] 30% (82/267 pages)checksumBuffer(start_addr=0xe400, size=0x200) = 8c19
read(addr=0xe400,size=0x200)
[========= ] 31% (83/267 pages)checksumBuffer(start_addr=0xe600, size=0x200) = 709e
read(addr=0xe600,size=0x200)
[========= ] 31% (84/267 pages)checksumBuffer(start_addr=0xe800, size=0x200) = 7d73
read(addr=0xe800,size=0x200)
[========= ] 31% (85/267 pages)checksumBuffer(start_addr=0xea00, size=0x200) = 3624
read(addr=0xea00,size=0x200)
[========= ] 32% (86/267 pages)checksumBuffer(start_addr=0xec00, size=0x200) = 52fe
read(addr=0xec00,size=0x200)
[========= ] 32% (87/267 pages)checksumBuffer(start_addr=0xee00, size=0x200) = 5005
read(addr=0xee00,size=0x200)
[========= ] 32% (88/267 pages)checksumBuffer(start_addr=0xf000, size=0x200) = 20d
read(addr=0xf000,size=0x200)
[========== ] 33% (89/267 pages)checksumBuffer(start_addr=0xf200, size=0x200) = 8d80
read(addr=0xf200,size=0x200)
[========== ] 33% (90/267 pages)checksumBuffer(start_addr=0xf400, size=0x200) = 7223
read(addr=0xf400,size=0x200)
[========== ] 34% (91/267 pages)checksumBuffer(start_addr=0xf600, size=0x200) = 16c5
read(addr=0xf600,size=0x200)
[========== ] 34% (92/267 pages)checksumBuffer(start_addr=0xf800, size=0x200) = 17f6
read(addr=0xf800,size=0x200)
[========== ] 34% (93/267 pages)checksumBuffer(start_addr=0xfa00, size=0x200) = 528e
read(addr=0xfa00,size=0x200)
[========== ] 35% (94/267 pages)checksumBuffer(start_addr=0xfc00, size=0x200) = 7c99
read(addr=0xfc00,size=0x200)
[========== ] 35% (95/267 pages)checksumBuffer(start_addr=0xfe00, size=0x200) = 5335
read(addr=0xfe00,size=0x200)
[========== ] 35% (96/267 pages)checksumBuffer(start_addr=0x10000, size=0x200) = 1a99
read(addr=0x10000,size=0x200)
[========== ] 36% (97/267 pages)checksumBuffer(start_addr=0x10200, size=0x200) = f071
read(addr=0x10200,size=0x200)
[=========== ] 36% (98/267 pages)checksumBuffer(start_addr=0x10400, size=0x200) = 576f
read(addr=0x10400,size=0x200)
[=========== ] 37% (99/267 pages)checksumBuffer(start_addr=0x10600, size=0x200) = 6a87
read(addr=0x10600,size=0x200)
[=========== ] 37% (100/267 pages)checksumBuffer(start_addr=0x10800, size=0x200) = 86ad
read(addr=0x10800,size=0x200)
[=========== ] 37% (101/267 pages)checksumBuffer(start_addr=0x10a00, size=0x200) = 4851
read(addr=0x10a00,size=0x200)
[=========== ] 38% (102/267 pages)checksumBuffer(start_addr=0x10c00, size=0x200) = 5b6b
read(addr=0x10c00,size=0x200)
[=========== ] 38% (103/267 pages)checksumBuffer(start_addr=0x10e00, size=0x200) = 2c86
read(addr=0x10e00,size=0x200)
[=========== ] 38% (104/267 pages)checksumBuffer(start_addr=0x11000, size=0x200) = 3a1
read(addr=0x11000,size=0x200)
[=========== ] 39% (105/267 pages)checksumBuffer(start_addr=0x11200, size=0x200) = 11d7
read(addr=0x11200,size=0x200)
[=========== ] 39% (106/267 pages)checksumBuffer(start_addr=0x11400, size=0x200) = 7614
read(addr=0x11400,size=0x200)
[============ ] 40% (107/267 pages)checksumBuffer(start_addr=0x11600, size=0x200) = a30
read(addr=0x11600,size=0x200)
[============ ] 40% (108/267 pages)checksumBuffer(start_addr=0x11800, size=0x200) = 65b5
read(addr=0x11800,size=0x200)
[============ ] 40% (109/267 pages)checksumBuffer(start_addr=0x11a00, size=0x200) = 40a5
read(addr=0x11a00,size=0x200)
[============ ] 41% (110/267 pages)checksumBuffer(start_addr=0x11c00, size=0x200) = a5b8
read(addr=0x11c00,size=0x200)
[============ ] 41% (111/267 pages)checksumBuffer(start_addr=0x11e00, size=0x200) = cd21
read(addr=0x11e00,size=0x200)
[============ ] 41% (112/267 pages)checksumBuffer(start_addr=0x12000, size=0x200) = 4dda
read(addr=0x12000,size=0x200)
[============ ] 42% (113/267 pages)checksumBuffer(start_addr=0x12200, size=0x200) = 70a2
read(addr=0x12200,size=0x200)
[============ ] 42% (114/267 pages)checksumBuffer(start_addr=0x12400, size=0x200) = 238d
read(addr=0x12400,size=0x200)
[============ ] 43% (115/267 pages)checksumBuffer(start_addr=0x12600, size=0x200) = 4815
read(addr=0x12600,size=0x200)
[============= ] 43% (116/267 pages)checksumBuffer(start_addr=0x12800, size=0x200) = c88d
read(addr=0x12800,size=0x200)
[============= ] 43% (117/267 pages)checksumBuffer(start_addr=0x12a00, size=0x200) = 29e5
read(addr=0x12a00,size=0x200)
[============= ] 44% (118/267 pages)checksumBuffer(start_addr=0x12c00, size=0x200) = ff9e
read(addr=0x12c00,size=0x200)
[============= ] 44% (119/267 pages)checksumBuffer(start_addr=0x12e00, size=0x200) = cef5
read(addr=0x12e00,size=0x200)
[============= ] 44% (120/267 pages)checksumBuffer(start_addr=0x13000, size=0x200) = 75ed
read(addr=0x13000,size=0x200)
[============= ] 45% (121/267 pages)checksumBuffer(start_addr=0x13200, size=0x200) = 5f7a
read(addr=0x13200,size=0x200)
[============= ] 45% (122/267 pages)checksumBuffer(start_addr=0x13400, size=0x200) = aa95
read(addr=0x13400,size=0x200)
[============= ] 46% (123/267 pages)checksumBuffer(start_addr=0x13600, size=0x200) = f8aa
read(addr=0x13600,size=0x200)
[============= ] 46% (124/267 pages)checksumBuffer(start_addr=0x13800, size=0x200) = 7c81
read(addr=0x13800,size=0x200)
[============== ] 46% (125/267 pages)checksumBuffer(start_addr=0x13a00, size=0x200) = 62cf
read(addr=0x13a00,size=0x200)
[============== ] 47% (126/267 pages)checksumBuffer(start_addr=0x13c00, size=0x200) = 12c4
read(addr=0x13c00,size=0x200)
[============== ] 47% (127/267 pages)checksumBuffer(start_addr=0x13e00, size=0x200) = dcc
read(addr=0x13e00,size=0x200)
[============== ] 47% (128/267 pages)checksumBuffer(start_addr=0x14000, size=0x200) = 10a6
read(addr=0x14000,size=0x200)
[============== ] 48% (129/267 pages)checksumBuffer(start_addr=0x14200, size=0x200) = 8f28
read(addr=0x14200,size=0x200)
[============== ] 48% (130/267 pages)checksumBuffer(start_addr=0x14400, size=0x200) = d0ec
read(addr=0x14400,size=0x200)
[============== ] 49% (131/267 pages)checksumBuffer(start_addr=0x14600, size=0x200) = 5d21
read(addr=0x14600,size=0x200)
[============== ] 49% (132/267 pages)checksumBuffer(start_addr=0x14800, size=0x200) = b7a
read(addr=0x14800,size=0x200)
[============== ] 49% (133/267 pages)checksumBuffer(start_addr=0x14a00, size=0x200) = 1ac
read(addr=0x14a00,size=0x200)
[=============== ] 50% (134/267 pages)checksumBuffer(start_addr=0x14c00, size=0x200) = 3e5b
read(addr=0x14c00,size=0x200)
[=============== ] 50% (135/267 pages)checksumBuffer(start_addr=0x14e00, size=0x200) = 9a12
read(addr=0x14e00,size=0x200)
[=============== ] 50% (136/267 pages)checksumBuffer(start_addr=0x15000, size=0x200) = d5b4
read(addr=0x15000,size=0x200)
[=============== ] 51% (137/267 pages)checksumBuffer(start_addr=0x15200, size=0x200) = 52a5
read(addr=0x15200,size=0x200)
[=============== ] 51% (138/267 pages)checksumBuffer(start_addr=0x15400, size=0x200) = 20a8
read(addr=0x15400,size=0x200)
[=============== ] 52% (139/267 pages)checksumBuffer(start_addr=0x15600, size=0x200) = bc66
read(addr=0x15600,size=0x200)
[=============== ] 52% (140/267 pages)checksumBuffer(start_addr=0x15800, size=0x200) = 48d
read(addr=0x15800,size=0x200)
[=============== ] 52% (141/267 pages)checksumBuffer(start_addr=0x15a00, size=0x200) = 3750
read(addr=0x15a00,size=0x200)
[=============== ] 53% (142/267 pages)checksumBuffer(start_addr=0x15c00, size=0x200) = eeb8
read(addr=0x15c00,size=0x200)
[================ ] 53% (143/267 pages)checksumBuffer(start_addr=0x15e00, size=0x200) = 8309
read(addr=0x15e00,size=0x200)
[================ ] 53% (144/267 pages)checksumBuffer(start_addr=0x16000, size=0x200) = f6d0
read(addr=0x16000,size=0x200)
[================ ] 54% (145/267 pages)checksumBuffer(start_addr=0x16200, size=0x200) = 36c6
read(addr=0x16200,size=0x200)
[================ ] 54% (146/267 pages)checksumBuffer(start_addr=0x16400, size=0x200) = 94bc
read(addr=0x16400,size=0x200)
[================ ] 55% (147/267 pages)checksumBuffer(start_addr=0x16600, size=0x200) = 68ce
read(addr=0x16600,size=0x200)
[================ ] 55% (148/267 pages)checksumBuffer(start_addr=0x16800, size=0x200) = b69d
read(addr=0x16800,size=0x200)
[================ ] 55% (149/267 pages)checksumBuffer(start_addr=0x16a00, size=0x200) = f1ce
read(addr=0x16a00,size=0x200)
[================ ] 56% (150/267 pages)checksumBuffer(start_addr=0x16c00, size=0x200) = 9073
read(addr=0x16c00,size=0x200)
[================ ] 56% (151/267 pages)checksumBuffer(start_addr=0x16e00, size=0x200) = 7103
read(addr=0x16e00,size=0x200)
[================= ] 56% (152/267 pages)checksumBuffer(start_addr=0x17000, size=0x200) = 4dd1
read(addr=0x17000,size=0x200)
[================= ] 57% (153/267 pages)checksumBuffer(start_addr=0x17200, size=0x200) = 8041
read(addr=0x17200,size=0x200)
[================= ] 57% (154/267 pages)checksumBuffer(start_addr=0x17400, size=0x200) = d4f2
read(addr=0x17400,size=0x200)
[================= ] 58% (155/267 pages)checksumBuffer(start_addr=0x17600, size=0x200) = e4b7
read(addr=0x17600,size=0x200)
[================= ] 58% (156/267 pages)checksumBuffer(start_addr=0x17800, size=0x200) = 1652
read(addr=0x17800,size=0x200)
[================= ] 58% (157/267 pages)checksumBuffer(start_addr=0x17a00, size=0x200) = 633b
read(addr=0x17a00,size=0x200)
[================= ] 59% (158/267 pages)checksumBuffer(start_addr=0x17c00, size=0x200) = 5906
read(addr=0x17c00,size=0x200)
[================= ] 59% (159/267 pages)checksumBuffer(start_addr=0x17e00, size=0x200) = a3b1
read(addr=0x17e00,size=0x200)
[================= ] 59% (160/267 pages)checksumBuffer(start_addr=0x18000, size=0x200) = 41f0
[================== ] 60% (161/267 pages)checksumBuffer(start_addr=0x18200, size=0x200) = e52d
[================== ] 60% (162/267 pages)checksumBuffer(start_addr=0x18400, size=0x200) = 6c5f
[================== ] 61% (163/267 pages)checksumBuffer(start_addr=0x18600, size=0x200) = ba4c
[================== ] 61% (164/267 pages)checksumBuffer(start_addr=0x18800, size=0x200) = 4f34
[================== ] 61% (165/267 pages)checksumBuffer(start_addr=0x18a00, size=0x200) = 1cac
[================== ] 62% (166/267 pages)checksumBuffer(start_addr=0x18c00, size=0x200) = 7ec
[================== ] 62% (167/267 pages)checksumBuffer(start_addr=0x18e00, size=0x200) = e6c2
[================== ] 62% (168/267 pages)checksumBuffer(start_addr=0x19000, size=0x200) = 91f1
read(addr=0x19000,size=0x200)
[================== ] 63% (169/267 pages)checksumBuffer(start_addr=0x19200, size=0x200) = 9d13
read(addr=0x19200,size=0x200)
[=================== ] 63% (170/267 pages)checksumBuffer(start_addr=0x19400, size=0x200) = 619e
read(addr=0x19400,size=0x200)
[=================== ] 64% (171/267 pages)checksumBuffer(start_addr=0x19600, size=0x200) = 564a
read(addr=0x19600,size=0x200)
[=================== ] 64% (172/267 pages)checksumBuffer(start_addr=0x19800, size=0x200) = 2c7f
read(addr=0x19800,size=0x200)
[=================== ] 64% (173/267 pages)checksumBuffer(start_addr=0x19a00, size=0x200) = 76bd
read(addr=0x19a00,size=0x200)
[=================== ] 65% (174/267 pages)checksumBuffer(start_addr=0x19c00, size=0x200) = 134b
read(addr=0x19c00,size=0x200)
[=================== ] 65% (175/267 pages)checksumBuffer(start_addr=0x19e00, size=0x200) = a569
read(addr=0x19e00,size=0x200)
[=================== ] 65% (176/267 pages)checksumBuffer(start_addr=0x1a000, size=0x200) = 5938
read(addr=0x1a000,size=0x200)
[=================== ] 66% (177/267 pages)checksumBuffer(start_addr=0x1a200, size=0x200) = ee21
read(addr=0x1a200,size=0x200)
[==================== ] 66% (178/267 pages)checksumBuffer(start_addr=0x1a400, size=0x200) = 8014
read(addr=0x1a400,size=0x200)
[==================== ] 67% (179/267 pages)checksumBuffer(start_addr=0x1a600, size=0x200) = 42d6
read(addr=0x1a600,size=0x200)
[==================== ] 67% (180/267 pages)checksumBuffer(start_addr=0x1a800, size=0x200) = eda7
read(addr=0x1a800,size=0x200)
[==================== ] 67% (181/267 pages)checksumBuffer(start_addr=0x1aa00, size=0x200) = 9f29
read(addr=0x1aa00,size=0x200)
[==================== ] 68% (182/267 pages)checksumBuffer(start_addr=0x1ac00, size=0x200) = 3a1a
read(addr=0x1ac00,size=0x200)
[==================== ] 68% (183/267 pages)checksumBuffer(start_addr=0x1ae00, size=0x200) = 1c24
read(addr=0x1ae00,size=0x200)
[==================== ] 68% (184/267 pages)checksumBuffer(start_addr=0x1b000, size=0x200) = ab4b
read(addr=0x1b000,size=0x200)
[==================== ] 69% (185/267 pages)checksumBuffer(start_addr=0x1b200, size=0x200) = 11e0
read(addr=0x1b200,size=0x200)
[==================== ] 69% (186/267 pages)checksumBuffer(start_addr=0x1b400, size=0x200) = 7734
read(addr=0x1b400,size=0x200)
[===================== ] 70% (187/267 pages)checksumBuffer(start_addr=0x1b600, size=0x200) = bedb
read(addr=0x1b600,size=0x200)
[===================== ] 70% (188/267 pages)checksumBuffer(start_addr=0x1b800, size=0x200) = ed8b
read(addr=0x1b800,size=0x200)
[===================== ] 70% (189/267 pages)checksumBuffer(start_addr=0x1ba00, size=0x200) = 9160
read(addr=0x1ba00,size=0x200)
[===================== ] 71% (190/267 pages)checksumBuffer(start_addr=0x1bc00, size=0x200) = 49cc
read(addr=0x1bc00,size=0x200)
[===================== ] 71% (191/267 pages)checksumBuffer(start_addr=0x1be00, size=0x200) = 9c19
read(addr=0x1be00,size=0x200)
[===================== ] 71% (192/267 pages)checksumBuffer(start_addr=0x1c000, size=0x200) = b008
read(addr=0x1c000,size=0x200)
[===================== ] 72% (193/267 pages)checksumBuffer(start_addr=0x1c200, size=0x200) = 4e89
read(addr=0x1c200,size=0x200)
[===================== ] 72% (194/267 pages)checksumBuffer(start_addr=0x1c400, size=0x200) = 87
read(addr=0x1c400,size=0x200)
[===================== ] 73% (195/267 pages)checksumBuffer(start_addr=0x1c600, size=0x200) = 4c2
read(addr=0x1c600,size=0x200)
[====================== ] 73% (196/267 pages)checksumBuffer(start_addr=0x1c800, size=0x200) = b045
read(addr=0x1c800,size=0x200)
[====================== ] 73% (197/267 pages)checksumBuffer(start_addr=0x1ca00, size=0x200) = d9f3
read(addr=0x1ca00,size=0x200)
[====================== ] 74% (198/267 pages)checksumBuffer(start_addr=0x1cc00, size=0x200) = 460b
read(addr=0x1cc00,size=0x200)
[====================== ] 74% (199/267 pages)checksumBuffer(start_addr=0x1ce00, size=0x200) = 8677
read(addr=0x1ce00,size=0x200)
[====================== ] 74% (200/267 pages)checksumBuffer(start_addr=0x1d000, size=0x200) = 1689
read(addr=0x1d000,size=0x200)
[====================== ] 75% (201/267 pages)checksumBuffer(start_addr=0x1d200, size=0x200) = 2c8d
read(addr=0x1d200,size=0x200)
[====================== ] 75% (202/267 pages)checksumBuffer(start_addr=0x1d400, size=0x200) = 539
read(addr=0x1d400,size=0x200)
[====================== ] 76% (203/267 pages)checksumBuffer(start_addr=0x1d600, size=0x200) = b8b
read(addr=0x1d600,size=0x200)
[====================== ] 76% (204/267 pages)checksumBuffer(start_addr=0x1d800, size=0x200) = 62e1
read(addr=0x1d800,size=0x200)
[======================= ] 76% (205/267 pages)checksumBuffer(start_addr=0x1da00, size=0x200) = 4bf8
read(addr=0x1da00,size=0x200)
[======================= ] 77% (206/267 pages)checksumBuffer(start_addr=0x1dc00, size=0x200) = b7d5
read(addr=0x1dc00,size=0x200)
[======================= ] 77% (207/267 pages)checksumBuffer(start_addr=0x1de00, size=0x200) = 1b6d
read(addr=0x1de00,size=0x200)
[======================= ] 77% (208/267 pages)checksumBuffer(start_addr=0x1e000, size=0x200) = e93c
read(addr=0x1e000,size=0x200)
[======================= ] 78% (209/267 pages)checksumBuffer(start_addr=0x1e200, size=0x200) = 2b7d
read(addr=0x1e200,size=0x200)
[======================= ] 78% (210/267 pages)checksumBuffer(start_addr=0x1e400, size=0x200) = 1b75
read(addr=0x1e400,size=0x200)
[======================= ] 79% (211/267 pages)checksumBuffer(start_addr=0x1e600, size=0x200) = 5f41
read(addr=0x1e600,size=0x200)
[======================= ] 79% (212/267 pages)checksumBuffer(start_addr=0x1e800, size=0x200) = 470a
read(addr=0x1e800,size=0x200)
[======================= ] 79% (213/267 pages)checksumBuffer(start_addr=0x1ea00, size=0x200) = abb8
read(addr=0x1ea00,size=0x200)
[======================== ] 80% (214/267 pages)checksumBuffer(start_addr=0x1ec00, size=0x200) = 955b
read(addr=0x1ec00,size=0x200)
[======================== ] 80% (215/267 pages)checksumBuffer(start_addr=0x1ee00, size=0x200) = aa22
read(addr=0x1ee00,size=0x200)
[======================== ] 80% (216/267 pages)checksumBuffer(start_addr=0x1f000, size=0x200) = dfd0
read(addr=0x1f000,size=0x200)
[======================== ] 81% (217/267 pages)checksumBuffer(start_addr=0x1f200, size=0x200) = 4626
read(addr=0x1f200,size=0x200)
[======================== ] 81% (218/267 pages)checksumBuffer(start_addr=0x1f400, size=0x200) = 9c0b
read(addr=0x1f400,size=0x200)
[======================== ] 82% (219/267 pages)checksumBuffer(start_addr=0x1f600, size=0x200) = 9d9e
read(addr=0x1f600,size=0x200)
[======================== ] 82% (220/267 pages)checksumBuffer(start_addr=0x1f800, size=0x200) = 7484
read(addr=0x1f800,size=0x200)
[======================== ] 82% (221/267 pages)checksumBuffer(start_addr=0x1fa00, size=0x200) = c31f
read(addr=0x1fa00,size=0x200)
[======================== ] 83% (222/267 pages)checksumBuffer(start_addr=0x1fc00, size=0x200) = ec2f
read(addr=0x1fc00,size=0x200)
[========================= ] 83% (223/267 pages)checksumBuffer(start_addr=0x1fe00, size=0x200) = a99b
read(addr=0x1fe00,size=0x200)
[========================= ] 83% (224/267 pages)checksumBuffer(start_addr=0x20000, size=0x200) = 54f1
read(addr=0x20000,size=0x200)
[========================= ] 84% (225/267 pages)checksumBuffer(start_addr=0x20200, size=0x200) = baf
read(addr=0x20200,size=0x200)
[========================= ] 84% (226/267 pages)checksumBuffer(start_addr=0x20400, size=0x200) = 1a13
read(addr=0x20400,size=0x200)
[========================= ] 85% (227/267 pages)checksumBuffer(start_addr=0x20600, size=0x200) = 233a
read(addr=0x20600,size=0x200)
[========================= ] 85% (228/267 pages)checksumBuffer(start_addr=0x20800, size=0x200) = 9af5
read(addr=0x20800,size=0x200)
[========================= ] 85% (229/267 pages)checksumBuffer(start_addr=0x20a00, size=0x200) = c07d
read(addr=0x20a00,size=0x200)
[========================= ] 86% (230/267 pages)checksumBuffer(start_addr=0x20c00, size=0x200) = e91e
read(addr=0x20c00,size=0x200)
[========================= ] 86% (231/267 pages)checksumBuffer(start_addr=0x20e00, size=0x200) = e2f9
read(addr=0x20e00,size=0x200)
[========================== ] 86% (232/267 pages)checksumBuffer(start_addr=0x21000, size=0x200) = 7fb8
read(addr=0x21000,size=0x200)
[========================== ] 87% (233/267 pages)checksumBuffer(start_addr=0x21200, size=0x200) = 2f1
read(addr=0x21200,size=0x200)
[========================== ] 87% (234/267 pages)checksumBuffer(start_addr=0x21400, size=0x200) = aca7
read(addr=0x21400,size=0x200)
[========================== ] 88% (235/267 pages)checksumBuffer(start_addr=0x21600, size=0x200) = a88d
read(addr=0x21600,size=0x200)
[========================== ] 88% (236/267 pages)checksumBuffer(start_addr=0x21800, size=0x200) = 4037
read(addr=0x21800,size=0x200)
[========================== ] 88% (237/267 pages)checksumBuffer(start_addr=0x21a00, size=0x200) = 3cab
read(addr=0x21a00,size=0x200)
[========================== ] 89% (238/267 pages)checksumBuffer(start_addr=0x21c00, size=0x200) = cbff
read(addr=0x21c00,size=0x200)
[========================== ] 89% (239/267 pages)checksumBuffer(start_addr=0x21e00, size=0x200) = 51f6
read(addr=0x21e00,size=0x200)
[========================== ] 89% (240/267 pages)checksumBuffer(start_addr=0x22000, size=0x200) = 3085
read(addr=0x22000,size=0x200)
[=========================== ] 90% (241/267 pages)checksumBuffer(start_addr=0x22200, size=0x200) = e3cd
read(addr=0x22200,size=0x200)
[=========================== ] 90% (242/267 pages)checksumBuffer(start_addr=0x22400, size=0x200) = dff8
read(addr=0x22400,size=0x200)
[=========================== ] 91% (243/267 pages)checksumBuffer(start_addr=0x22600, size=0x200) = abe9
read(addr=0x22600,size=0x200)
[=========================== ] 91% (244/267 pages)checksumBuffer(start_addr=0x22800, size=0x200) = 824c
read(addr=0x22800,size=0x200)
[=========================== ] 91% (245/267 pages)checksumBuffer(start_addr=0x22a00, size=0x200) = 4584
read(addr=0x22a00,size=0x200)
[=========================== ] 92% (246/267 pages)checksumBuffer(start_addr=0x22c00, size=0x200) = 4b7b
read(addr=0x22c00,size=0x200)
[=========================== ] 92% (247/267 pages)checksumBuffer(start_addr=0x22e00, size=0x200) = 43a2
read(addr=0x22e00,size=0x200)
[=========================== ] 92% (248/267 pages)checksumBuffer(start_addr=0x23000, size=0x200) = cdb3
read(addr=0x23000,size=0x200)
[=========================== ] 93% (249/267 pages)checksumBuffer(start_addr=0x23200, size=0x200) = 7361
read(addr=0x23200,size=0x200)
[============================ ] 93% (250/267 pages)checksumBuffer(start_addr=0x23400, size=0x200) = 2f5b
read(addr=0x23400,size=0x200)
[============================ ] 94% (251/267 pages)checksumBuffer(start_addr=0x23600, size=0x200) = d5e3
read(addr=0x23600,size=0x200)
[============================ ] 94% (252/267 pages)checksumBuffer(start_addr=0x23800, size=0x200) = ca50
read(addr=0x23800,size=0x200)
[============================ ] 94% (253/267 pages)checksumBuffer(start_addr=0x23a00, size=0x200) = fa31
read(addr=0x23a00,size=0x200)
[============================ ] 95% (254/267 pages)checksumBuffer(start_addr=0x23c00, size=0x200) = b8c4
read(addr=0x23c00,size=0x200)
[============================ ] 95% (255/267 pages)checksumBuffer(start_addr=0x23e00, size=0x200) = 671f
read(addr=0x23e00,size=0x200)
[============================ ] 95% (256/267 pages)checksumBuffer(start_addr=0x24000, size=0x200) = ddab
read(addr=0x24000,size=0x200)
[============================ ] 96% (257/267 pages)checksumBuffer(start_addr=0x24200, size=0x200) = fe2f
read(addr=0x24200,size=0x200)
[============================ ] 96% (258/267 pages)checksumBuffer(start_addr=0x24400, size=0x200) = c183
read(addr=0x24400,size=0x200)
[============================= ] 97% (259/267 pages)checksumBuffer(start_addr=0x24600, size=0x200) = eb5e
read(addr=0x24600,size=0x200)
[============================= ] 97% (260/267 pages)checksumBuffer(start_addr=0x24800, size=0x200) = aefc
read(addr=0x24800,size=0x200)
[============================= ] 97% (261/267 pages)checksumBuffer(start_addr=0x24a00, size=0x200) = a67b
read(addr=0x24a00,size=0x200)
[============================= ] 98% (262/267 pages)checksumBuffer(start_addr=0x24c00, size=0x200) = 0
read(addr=0x24c00,size=0x200)
[============================= ] 98% (263/267 pages)checksumBuffer(start_addr=0x24e00, size=0x200) = 3cb1
read(addr=0x24e00,size=0x200)
[============================= ] 98% (264/267 pages)checksumBuffer(start_addr=0x25000, size=0x200) = 409b
read(addr=0x25000,size=0x200)
[============================= ] 99% (265/267 pages)checksumBuffer(start_addr=0x25200, size=0x200) = 7e22
read(addr=0x25200,size=0x200)
[============================= ] 99% (266/267 pages)checksumBuffer(start_addr=0x25400, size=0x130) = f015
read(addr=0x25400,size=0x200)
Verify failed
Page errors: 251
Byte errors: 124485
Failed uploading: uploading error: exit status 2
Windows output:
Performing 1200-bps touch reset on serial port COM4
No upload port found, using COM4 as fallback
"C:\Users\Rick\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino1/bossac.exe" -i -d -a --port=COM4 -U -e -w -v --offset=0x4000 "C:\Users\Rick\AppData\Local\arduino\sketches\6F79964E375E53952DB058595B408258/WriteDigitalOutput.ino.bin" -R
Set binary mode
Address : 0x0
Pages : 1024
Total Size : 512KB
Planes : 1
Lock Regions : 32
Locked : none
Security : false
BOD : false
BOR : true
Erase flash
Done in 2.354 seconds
Write 136504 bytes to flash (267 pages)
Done in 1.039 seconds
Verify 136504 bytes of flash
checksumBuffer(start_addr=0x4000, size=0x200) = 2a6c
checksumBuffer(start_addr=0x4200, size=0x200) = f86a
checksumBuffer(start_addr=0x4400, size=0x200) = eeb2
checksumBuffer(start_addr=0x4600, size=0x200) = d857
checksumBuffer(start_addr=0x4800, size=0x200) = 3469
checksumBuffer(start_addr=0x4a00, size=0x200) = 92f9
checksumBuffer(start_addr=0x4c00, size=0x200) = f49d
checksumBuffer(start_addr=0x4e00, size=0x200) = a8e
checksumBuffer(start_addr=0x5000, size=0x200) = fc6e
[= ] 3% (9/267 pages)checksumBuffer(start_addr=0x5200, size=0x200) = 8788
[= ] 3% (10/267 pages)checksumBuffer(start_addr=0x5400, size=0x200) = 1ba
[= ] 4% (11/267 pages)checksumBuffer(start_addr=0x5600, size=0x200) = dfd6
[= ] 4% (12/267 pages)checksumBuffer(start_addr=0x5800, size=0x200) = be47
[= ] 4% (13/267 pages)checksumBuffer(start_addr=0x5a00, size=0x200) = c43c
[= ] 5% (14/267 pages)checksumBuffer(start_addr=0x5c00, size=0x200) = a5c1
[= ] 5% (15/267 pages)checksumBuffer(start_addr=0x5e00, size=0x200) = d605
[= ] 5% (16/267 pages)checksumBuffer(start_addr=0x6000, size=0x200) = 34f0
[= ] 6% (17/267 pages)checksumBuffer(start_addr=0x6200, size=0x200) = 218d
[== ] 6% (18/267 pages)checksumBuffer(start_addr=0x6400, size=0x200) = f106
[== ] 7% (19/267 pages)checksumBuffer(start_addr=0x6600, size=0x200) = f532
[== ] 7% (20/267 pages)checksumBuffer(start_addr=0x6800, size=0x200) = 3ece
[== ] 7% (21/267 pages)checksumBuffer(start_addr=0x6a00, size=0x200) = 957e
[== ] 8% (22/267 pages)checksumBuffer(start_addr=0x6c00, size=0x200) = f396
[== ] 8% (23/267 pages)checksumBuffer(start_addr=0x6e00, size=0x200) = 39f6
[== ] 8% (24/267 pages)checksumBuffer(start_addr=0x7000, size=0x200) = ee7b
[== ] 9% (25/267 pages)checksumBuffer(start_addr=0x7200, size=0x200) = 345d
[== ] 9% (26/267 pages)checksumBuffer(start_addr=0x7400, size=0x200) = 44b6
[=== ] 10% (27/267 pages)checksumBuffer(start_addr=0x7600, size=0x200) = f74d
[=== ] 10% (28/267 pages)checksumBuffer(start_addr=0x7800, size=0x200) = 1d8b
[=== ] 10% (29/267 pages)checksumBuffer(start_addr=0x7a00, size=0x200) = 6f8e
[=== ] 11% (30/267 pages)checksumBuffer(start_addr=0x7c00, size=0x200) = 93a8
[=== ] 11% (31/267 pages)checksumBuffer(start_addr=0x7e00, size=0x200) = 37d7
[=== ] 11% (32/267 pages)checksumBuffer(start_addr=0x8000, size=0x200) = 80ca
[=== ] 12% (33/267 pages)checksumBuffer(start_addr=0x8200, size=0x200) = 5163
[=== ] 12% (34/267 pages)checksumBuffer(start_addr=0x8400, size=0x200) = 3825
[=== ] 13% (35/267 pages)checksumBuffer(start_addr=0x8600, size=0x200) = 3dca
[==== ] 13% (36/267 pages)checksumBuffer(start_addr=0x8800, size=0x200) = c4f
[==== ] 13% (37/267 pages)checksumBuffer(start_addr=0x8a00, size=0x200) = afde
[==== ] 14% (38/267 pages)checksumBuffer(start_addr=0x8c00, size=0x200) = a187
[==== ] 14% (39/267 pages)checksumBuffer(start_addr=0x8e00, size=0x200) = b365
[==== ] 14% (40/267 pages)checksumBuffer(start_addr=0x9000, size=0x200) = fa7
[==== ] 15% (41/267 pages)checksumBuffer(start_addr=0x9200, size=0x200) = 532d
[==== ] 15% (42/267 pages)checksumBuffer(start_addr=0x9400, size=0x200) = 20dc
[==== ] 16% (43/267 pages)checksumBuffer(start_addr=0x9600, size=0x200) = f8ff
[==== ] 16% (44/267 pages)checksumBuffer(start_addr=0x9800, size=0x200) = d3a3
[===== ] 16% (45/267 pages)checksumBuffer(start_addr=0x9a00, size=0x200) = d323
[===== ] 17% (46/267 pages)checksumBuffer(start_addr=0x9c00, size=0x200) = f94
[===== ] 17% (47/267 pages)checksumBuffer(start_addr=0x9e00, size=0x200) = 96fc
[===== ] 17% (48/267 pages)checksumBuffer(start_addr=0xa000, size=0x200) = 1ca3
[===== ] 18% (49/267 pages)checksumBuffer(start_addr=0xa200, size=0x200) = cece
[===== ] 18% (50/267 pages)checksumBuffer(start_addr=0xa400, size=0x200) = 86e2
[===== ] 19% (51/267 pages)checksumBuffer(start_addr=0xa600, size=0x200) = 54bf
[===== ] 19% (52/267 pages)checksumBuffer(start_addr=0xa800, size=0x200) = ba5e
[===== ] 19% (53/267 pages)checksumBuffer(start_addr=0xaa00, size=0x200) = 1e54
[====== ] 20% (54/267 pages)checksumBuffer(start_addr=0xac00, size=0x200) = cbc9
[====== ] 20% (55/267 pages)checksumBuffer(start_addr=0xae00, size=0x200) = b04b
[====== ] 20% (56/267 pages)checksumBuffer(start_addr=0xb000, size=0x200) = 267a
[====== ] 21% (57/267 pages)checksumBuffer(start_addr=0xb200, size=0x200) = 8e54
[====== ] 21% (58/267 pages)checksumBuffer(start_addr=0xb400, size=0x200) = 3626
[====== ] 22% (59/267 pages)checksumBuffer(start_addr=0xb600, size=0x200) = 7ebb
[====== ] 22% (60/267 pages)checksumBuffer(start_addr=0xb800, size=0x200) = 5ba7
[====== ] 22% (61/267 pages)checksumBuffer(start_addr=0xba00, size=0x200) = 9445
[====== ] 23% (62/267 pages)checksumBuffer(start_addr=0xbc00, size=0x200) = 1911
[======= ] 23% (63/267 pages)checksumBuffer(start_addr=0xbe00, size=0x200) = 3890
[======== ] 26% (72/267 pages)checksumBuffer(start_addr=0xd000, size=0x200) = dc6b
[======== ] 27% (73/267 pages)checksumBuffer(start_addr=0xd200, size=0x200) = ef5f
[======== ] 27% (74/267 pages)checksumBuffer(start_addr=0xd400, size=0x200) = db4
[======== ] 28% (75/267 pages)checksumBuffer(start_addr=0xd600, size=0x200) = 6f1b
[======== ] 28% (76/267 pages)checksumBuffer(start_addr=0xd800, size=0x200) = 6c16
[======== ] 28% (77/267 pages)checksumBuffer(start_addr=0xda00, size=0x200) = e7aa
[======== ] 29% (78/267 pages)checksumBuffer(start_addr=0xdc00, size=0x200) = 712c
[======== ] 29% (79/267 pages)checksumBuffer(start_addr=0xde00, size=0x200) = 70e6
[======== ] 29% (80/267 pages)checksumBuffer(start_addr=0xe000, size=0x200) = d55d
[========= ] 30% (81/267 pages)checksumBuffer(start_addr=0xe200, size=0x200) = dc63
[========= ] 30% (82/267 pages)checksumBuffer(start_addr=0xe400, size=0x200) = c818
[========= ] 31% (83/267 pages)checksumBuffer(start_addr=0xe600, size=0x200) = af9f
[========= ] 31% (84/267 pages)checksumBuffer(start_addr=0xe800, size=0x200) = 8abc
[========= ] 31% (85/267 pages)checksumBuffer(start_addr=0xea00, size=0x200) = 65d9
[========= ] 32% (86/267 pages)checksumBuffer(start_addr=0xec00, size=0x200) = c3fd
[========= ] 32% (87/267 pages)checksumBuffer(start_addr=0xee00, size=0x200) = dd2
[========= ] 32% (88/267 pages)checksumBuffer(start_addr=0xf000, size=0x200) = c4ce
[========== ] 33% (89/267 pages)checksumBuffer(start_addr=0xf200, size=0x200) = 2257
[========== ] 33% (90/267 pages)checksumBuffer(start_addr=0xf400, size=0x200) = db41
[========== ] 34% (91/267 pages)checksumBuffer(start_addr=0xf600, size=0x200) = 2fea
[========== ] 34% (92/267 pages)checksumBuffer(start_addr=0xf800, size=0x200) = df76
[========== ] 34% (93/267 pages)checksumBuffer(start_addr=0xfa00, size=0x200) = 2106
[========== ] 35% (94/267 pages)checksumBuffer(start_addr=0xfc00, size=0x200) = 6a03
[========== ] 35% (95/267 pages)checksumBuffer(start_addr=0xfe00, size=0x200) = a5c2
[========== ] 35% (96/267 pages)checksumBuffer(start_addr=0x10000, size=0x200) = 758f
[========== ] 36% (97/267 pages)checksumBuffer(start_addr=0x10200, size=0x200) = 79a0
[=========== ] 36% (98/267 pages)checksumBuffer(start_addr=0x10400, size=0x200) = bfed
[=========== ] 37% (99/267 pages)checksumBuffer(start_addr=0x10600, size=0x200) = f3ee
[=========== ] 37% (100/267 pages)checksumBuffer(start_addr=0x10800, size=0x200) = 457
[=========== ] 37% (101/267 pages)checksumBuffer(start_addr=0x10a00, size=0x200) = cf3e
[=========== ] 38% (102/267 pages)checksumBuffer(start_addr=0x10c00, size=0x200) = 98d
[=========== ] 38% (103/267 pages)checksumBuffer(start_addr=0x10e00, size=0x200) = 60ae
[=========== ] 38% (104/267 pages)checksumBuffer(start_addr=0x11000, size=0x200) = 3e72
[=========== ] 39% (105/267 pages)checksumBuffer(start_addr=0x11200, size=0x200) = 3276
[=========== ] 39% (106/267 pages)checksumBuffer(start_addr=0x11400, size=0x200) = 5a7b
[============ ] 40% (107/267 pages)checksumBuffer(start_addr=0x11600, size=0x200) = 5a35
[============ ] 40% (108/267 pages)checksumBuffer(start_addr=0x11800, size=0x200) = 770f
[============ ] 40% (109/267 pages)checksumBuffer(start_addr=0x11a00, size=0x200) = dcbe
[============ ] 41% (110/267 pages)checksumBuffer(start_addr=0x11c00, size=0x200) = e8e7
[============ ] 41% (111/267 pages)checksumBuffer(start_addr=0x11e00, size=0x200) = 2395
[============ ] 41% (112/267 pages)checksumBuffer(start_addr=0x12000, size=0x200) = 75e3
[============ ] 42% (113/267 pages)checksumBuffer(start_addr=0x12200, size=0x200) = 5dcd
[============ ] 42% (114/267 pages)checksumBuffer(start_addr=0x12400, size=0x200) = 4292
[============ ] 43% (115/267 pages)checksumBuffer(start_addr=0x12600, size=0x200) = 86f4
[============= ] 43% (116/267 pages)checksumBuffer(start_addr=0x12800, size=0x200) = ba6c
[============= ] 43% (117/267 pages)checksumBuffer(start_addr=0x12a00, size=0x200) = 48e5
[============= ] 44% (118/267 pages)checksumBuffer(start_addr=0x12c00, size=0x200) = af26
[============= ] 44% (119/267 pages)checksumBuffer(start_addr=0x12e00, size=0x200) = 78a
[============= ] 44% (120/267 pages)checksumBuffer(start_addr=0x13000, size=0x200) = eb8e
[============= ] 45% (121/267 pages)checksumBuffer(start_addr=0x13200, size=0x200) = 3b9c
[============= ] 45% (122/267 pages)checksumBuffer(start_addr=0x13400, size=0x200) = 2e93
[============= ] 46% (123/267 pages)checksumBuffer(start_addr=0x13600, size=0x200) = 2076
[============= ] 46% (124/267 pages)checksumBuffer(start_addr=0x13800, size=0x200) = 656
[============== ] 46% (125/267 pages)checksumBuffer(start_addr=0x13a00, size=0x200) = d15e
[============== ] 47% (126/267 pages)checksumBuffer(start_addr=0x13c00, size=0x200) = 1fc7
[============== ] 47% (127/267 pages)checksumBuffer(start_addr=0x13e00, size=0x200) = b7e5
[============== ] 47% (128/267 pages)checksumBuffer(start_addr=0x14000, size=0x200) = ddb9
[============== ] 48% (129/267 pages)checksumBuffer(start_addr=0x14200, size=0x200) = 1ac4
[============== ] 48% (130/267 pages)checksumBuffer(start_addr=0x14400, size=0x200) = a046
[============== ] 49% (131/267 pages)checksumBuffer(start_addr=0x14600, size=0x200) = d828
[============== ] 49% (132/267 pages)checksumBuffer(start_addr=0x14800, size=0x200) = 1317
[============== ] 49% (133/267 pages)checksumBuffer(start_addr=0x14a00, size=0x200) = 7781
[=============== ] 50% (134/267 pages)checksumBuffer(start_addr=0x14c00, size=0x200) = 353b
[=============== ] 50% (135/267 pages)checksumBuffer(start_addr=0x14e00, size=0x200) = e8be
[=============== ] 50% (136/267 pages)checksumBuffer(start_addr=0x15000, size=0x200) = 7146
[=============== ] 51% (137/267 pages)checksumBuffer(start_addr=0x15200, size=0x200) = e793
[=============== ] 51% (138/267 pages)checksumBuffer(start_addr=0x15400, size=0x200) = 8c2c
[=============== ] 52% (139/267 pages)checksumBuffer(start_addr=0x15600, size=0x200) = c44d
[=============== ] 52% (140/267 pages)checksumBuffer(start_addr=0x15800, size=0x200) = 7c2e
[=============== ] 52% (141/267 pages)checksumBuffer(start_addr=0x15a00, size=0x200) = 4957
[=============== ] 53% (142/267 pages)checksumBuffer(start_addr=0x15c00, size=0x200) = e614
[================ ] 53% (143/267 pages)checksumBuffer(start_addr=0x15e00, size=0x200) = 2d03
[================ ] 53% (144/267 pages)checksumBuffer(start_addr=0x16000, size=0x200) = 7252
[================ ] 54% (145/267 pages)checksumBuffer(start_addr=0x16200, size=0x200) = de7c
[================ ] 54% (146/267 pages)checksumBuffer(start_addr=0x16400, size=0x200) = 8e39
[================ ] 55% (147/267 pages)checksumBuffer(start_addr=0x16600, size=0x200) = 778e
[================ ] 55% (148/267 pages)checksumBuffer(start_addr=0x16800, size=0x200) = a9e3
[================ ] 55% (149/267 pages)checksumBuffer(start_addr=0x16a00, size=0x200) = 5252
[================ ] 56% (150/267 pages)checksumBuffer(start_addr=0x16c00, size=0x200) = a1eb
[================ ] 56% (151/267 pages)checksumBuffer(start_addr=0x16e00, size=0x200) = 72bb
[================= ] 56% (152/267 pages)checksumBuffer(start_addr=0x17000, size=0x200) = 35af
[================= ] 57% (153/267 pages)checksumBuffer(start_addr=0x17200, size=0x200) = d9e2
[================= ] 57% (154/267 pages)checksumBuffer(start_addr=0x17400, size=0x200) = 5a18
[================= ] 58% (155/267 pages)checksumBuffer(start_addr=0x17600, size=0x200) = 2ba0
[================= ] 58% (156/267 pages)checksumBuffer(start_addr=0x17800, size=0x200) = 9cf7
[================= ] 58% (157/267 pages)checksumBuffer(start_addr=0x17a00, size=0x200) = 7d1d
[================= ] 59% (158/267 pages)checksumBuffer(start_addr=0x17c00, size=0x200) = c219
[================= ] 59% (159/267 pages)checksumBuffer(start_addr=0x17e00, size=0x200) = 8a5
[================== ] 62% (168/267 pages)checksumBuffer(start_addr=0x19000, size=0x200) = d79c
[================== ] 63% (169/267 pages)checksumBuffer(start_addr=0x19200, size=0x200) = 298a
[=================== ] 63% (170/267 pages)checksumBuffer(start_addr=0x19400, size=0x200) = 33cf
[=================== ] 64% (171/267 pages)checksumBuffer(start_addr=0x19600, size=0x200) = 4cb3
[=================== ] 64% (172/267 pages)checksumBuffer(start_addr=0x19800, size=0x200) = 5073
[=================== ] 64% (173/267 pages)checksumBuffer(start_addr=0x19a00, size=0x200) = 73c1
[=================== ] 65% (174/267 pages)checksumBuffer(start_addr=0x19c00, size=0x200) = 3980
[=================== ] 65% (175/267 pages)checksumBuffer(start_addr=0x19e00, size=0x200) = 8b86
[=================== ] 65% (176/267 pages)checksumBuffer(start_addr=0x1a000, size=0x200) = db10
[=================== ] 66% (177/267 pages)checksumBuffer(start_addr=0x1a200, size=0x200) = 90b5
[==================== ] 66% (178/267 pages)checksumBuffer(start_addr=0x1a400, size=0x200) = 314
[==================== ] 67% (179/267 pages)checksumBuffer(start_addr=0x1a600, size=0x200) = b622
[==================== ] 67% (180/267 pages)checksumBuffer(start_addr=0x1a800, size=0x200) = 880c
[==================== ] 67% (181/267 pages)checksumBuffer(start_addr=0x1aa00, size=0x200) = 4380
[==================== ] 68% (182/267 pages)checksumBuffer(start_addr=0x1ac00, size=0x200) = a208
[==================== ] 68% (183/267 pages)checksumBuffer(start_addr=0x1ae00, size=0x200) = 6844
[==================== ] 68% (184/267 pages)checksumBuffer(start_addr=0x1b000, size=0x200) = 8d08
[==================== ] 69% (185/267 pages)checksumBuffer(start_addr=0x1b200, size=0x200) = 595e
[==================== ] 69% (186/267 pages)checksumBuffer(start_addr=0x1b400, size=0x200) = 8e63
[===================== ] 70% (187/267 pages)checksumBuffer(start_addr=0x1b600, size=0x200) = d7cb
[===================== ] 70% (188/267 pages)checksumBuffer(start_addr=0x1b800, size=0x200) = 694b
[===================== ] 70% (189/267 pages)checksumBuffer(start_addr=0x1ba00, size=0x200) = 1c58
[===================== ] 71% (190/267 pages)checksumBuffer(start_addr=0x1bc00, size=0x200) = 9a39
[===================== ] 71% (191/267 pages)checksumBuffer(start_addr=0x1be00, size=0x200) = bbdf
[===================== ] 71% (192/267 pages)checksumBuffer(start_addr=0x1c000, size=0x200) = 5907
[===================== ] 72% (193/267 pages)checksumBuffer(start_addr=0x1c200, size=0x200) = 31cd
[===================== ] 72% (194/267 pages)checksumBuffer(start_addr=0x1c400, size=0x200) = eb2e
[===================== ] 73% (195/267 pages)checksumBuffer(start_addr=0x1c600, size=0x200) = fa1e
[====================== ] 73% (196/267 pages)checksumBuffer(start_addr=0x1c800, size=0x200) = 4321
[====================== ] 73% (197/267 pages)checksumBuffer(start_addr=0x1ca00, size=0x200) = ee07
[====================== ] 74% (198/267 pages)checksumBuffer(start_addr=0x1cc00, size=0x200) = 9e5e
[====================== ] 74% (199/267 pages)checksumBuffer(start_addr=0x1ce00, size=0x200) = 92c0
[====================== ] 74% (200/267 pages)checksumBuffer(start_addr=0x1d000, size=0x200) = 6be9
[====================== ] 75% (201/267 pages)checksumBuffer(start_addr=0x1d200, size=0x200) = 2fbe
[====================== ] 75% (202/267 pages)checksumBuffer(start_addr=0x1d400, size=0x200) = 396c
[====================== ] 76% (203/267 pages)checksumBuffer(start_addr=0x1d600, size=0x200) = b861
[====================== ] 76% (204/267 pages)checksumBuffer(start_addr=0x1d800, size=0x200) = 7bbf
[======================= ] 76% (205/267 pages)checksumBuffer(start_addr=0x1da00, size=0x200) = 4654
[======================= ] 77% (206/267 pages)checksumBuffer(start_addr=0x1dc00, size=0x200) = 53fc
[======================= ] 77% (207/267 pages)checksumBuffer(start_addr=0x1de00, size=0x200) = 5297
[======================= ] 77% (208/267 pages)checksumBuffer(start_addr=0x1e000, size=0x200) = eecc
[======================= ] 78% (209/267 pages)checksumBuffer(start_addr=0x1e200, size=0x200) = feca
[======================= ] 78% (210/267 pages)checksumBuffer(start_addr=0x1e400, size=0x200) = 453b
[======================= ] 79% (211/267 pages)checksumBuffer(start_addr=0x1e600, size=0x200) = ee7f
[======================= ] 79% (212/267 pages)checksumBuffer(start_addr=0x1e800, size=0x200) = f767
[======================= ] 79% (213/267 pages)checksumBuffer(start_addr=0x1ea00, size=0x200) = 9f31
[======================== ] 80% (214/267 pages)checksumBuffer(start_addr=0x1ec00, size=0x200) = 2167
[======================== ] 80% (215/267 pages)checksumBuffer(start_addr=0x1ee00, size=0x200) = 4ed0
[======================== ] 80% (216/267 pages)checksumBuffer(start_addr=0x1f000, size=0x200) = d88f
[======================== ] 81% (217/267 pages)checksumBuffer(start_addr=0x1f200, size=0x200) = fcdb
[======================== ] 81% (218/267 pages)checksumBuffer(start_addr=0x1f400, size=0x200) = 20dd
[======================== ] 82% (219/267 pages)checksumBuffer(start_addr=0x1f600, size=0x200) = 1659
[======================== ] 82% (220/267 pages)checksumBuffer(start_addr=0x1f800, size=0x200) = 405
[======================== ] 82% (221/267 pages)checksumBuffer(start_addr=0x1fa00, size=0x200) = 54fd
[======================== ] 83% (222/267 pages)checksumBuffer(start_addr=0x1fc00, size=0x200) = 32d0
[========================= ] 83% (223/267 pages)checksumBuffer(start_addr=0x1fe00, size=0x200) = f912
[========================= ] 83% (224/267 pages)checksumBuffer(start_addr=0x20000, size=0x200) = 493c
[========================= ] 84% (225/267 pages)checksumBuffer(start_addr=0x20200, size=0x200) = 647d
[========================= ] 84% (226/267 pages)checksumBuffer(start_addr=0x20400, size=0x200) = 2cb7
[========================= ] 85% (227/267 pages)checksumBuffer(start_addr=0x20600, size=0x200) = a3b9
[========================= ] 85% (228/267 pages)checksumBuffer(start_addr=0x20800, size=0x200) = 1888
[========================= ] 85% (229/267 pages)checksumBuffer(start_addr=0x20a00, size=0x200) = 7f28
[========================= ] 86% (230/267 pages)checksumBuffer(start_addr=0x20c00, size=0x200) = 8f44
[========================= ] 86% (231/267 pages)checksumBuffer(start_addr=0x20e00, size=0x200) = 2b02
[========================== ] 86% (232/267 pages)checksumBuffer(start_addr=0x21000, size=0x200) = 4760
[========================== ] 87% (233/267 pages)checksumBuffer(start_addr=0x21200, size=0x200) = 68e0
[========================== ] 87% (234/267 pages)checksumBuffer(start_addr=0x21400, size=0x200) = 1cf4
[========================== ] 88% (235/267 pages)checksumBuffer(start_addr=0x21600, size=0x200) = a0d2
[========================== ] 88% (236/267 pages)checksumBuffer(start_addr=0x21800, size=0x200) = 6f36
[========================== ] 88% (237/267 pages)checksumBuffer(start_addr=0x21a00, size=0x200) = 545e
[========================== ] 89% (238/267 pages)checksumBuffer(start_addr=0x21c00, size=0x200) = 74b3
[========================== ] 89% (239/267 pages)checksumBuffer(start_addr=0x21e00, size=0x200) = 534d
[========================== ] 89% (240/267 pages)checksumBuffer(start_addr=0x22000, size=0x200) = b0b0
[=========================== ] 90% (241/267 pages)checksumBuffer(start_addr=0x22200, size=0x200) = 665e
[=========================== ] 90% (242/267 pages)checksumBuffer(start_addr=0x22400, size=0x200) = 25be
[=========================== ] 91% (243/267 pages)checksumBuffer(start_addr=0x22600, size=0x200) = 81df
[=========================== ] 91% (244/267 pages)checksumBuffer(start_addr=0x22800, size=0x200) = ee36
[=========================== ] 91% (245/267 pages)checksumBuffer(start_addr=0x22a00, size=0x200) = c29f
[=========================== ] 92% (246/267 pages)checksumBuffer(start_addr=0x22c00, size=0x200) = 9dfc
[=========================== ] 92% (247/267 pages)checksumBuffer(start_addr=0x22e00, size=0x200) = 3c36
[=========================== ] 92% (248/267 pages)checksumBuffer(start_addr=0x23000, size=0x200) = 38ab
[=========================== ] 93% (249/267 pages)checksumBuffer(start_addr=0x23200, size=0x200) = 92e0
[============================ ] 93% (250/267 pages)checksumBuffer(start_addr=0x23400, size=0x200) = 7f46
[============================ ] 94% (251/267 pages)checksumBuffer(start_addr=0x23600, size=0x200) = d2cc
[============================ ] 94% (252/267 pages)checksumBuffer(start_addr=0x23800, size=0x200) = 249f
[============================ ] 94% (253/267 pages)checksumBuffer(start_addr=0x23a00, size=0x200) = 688c
[============================ ] 95% (254/267 pages)checksumBuffer(start_addr=0x23c00, size=0x200) = df9e
[============================ ] 95% (255/267 pages)checksumBuffer(start_addr=0x23e00, size=0x200) = 7bb7
[============================ ] 95% (256/267 pages)checksumBuffer(start_addr=0x24000, size=0x200) = a42f
[============================ ] 96% (257/267 pages)checksumBuffer(start_addr=0x24200, size=0x200) = 2dc8
[============================ ] 96% (258/267 pages)checksumBuffer(start_addr=0x24400, size=0x200) = 9170
[============================= ] 97% (259/267 pages)checksumBuffer(start_addr=0x24600, size=0x200) = 9405
[============================= ] 97% (260/267 pages)checksumBuffer(start_addr=0x24800, size=0x200) = d23f
[============================= ] 97% (261/267 pages)checksumBuffer(start_addr=0x24a00, size=0x200) = e08e
[============================= ] 98% (262/267 pages)checksumBuffer(start_addr=0x24c00, size=0x200) = 79c0
[============================= ] 98% (263/267 pages)checksumBuffer(start_addr=0x24e00, size=0x200) = 4093
[============================= ] 98% (264/267 pages)checksumBuffer(start_addr=0x25000, size=0x200) = b2fd
[============================= ] 99% (265/267 pages)checksumBuffer(start_addr=0x25200, size=0x200) = b6a3
[============================= ] 99% (266/267 pages)checksumBuffer(start_addr=0x25400, size=0x138) = a712
Verify successful
Done in 0.240 seconds
writeWord(addr=0xe000ed0c,value=0x5fa0004)
