hello, iam programing a switch case with some rgb blinking and normal leds, my problem is when i wanna turn on another color, my device cant return to switch and keep blinking.
this is the code:
#include <SPI.h>
#include <Ethernet.h>
#include <MFRC522.h>
byte mac[] = {0x90, 0xA2, 0xDA, 0x0D, 0x6B, 0xC4};
byte server[] = { 192, 168, 0, 107};
byte ip[] = {192, 168, 0, 120};
#define RST_PIN 2 // Configurable, see typical pin layout above
#define SS_PIN 6 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
MFRC522::MIFARE_Key key;
EthernetClient client;
Ethernet.begin(mac,ip);
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
// Prepare the key (used both as key A and as key B)
// using FFFFFFFFFFFFh which is the default at chip delivery from the factory
for (byte i = 0; i < 6; i++) {
key.keyByte = 0xFF;
dump_byte_array(key.keyByte, MFRC522::MF_KEY_SIZE);*
pinMode(5, OUTPUT);*
pinMode(3, OUTPUT);*
pinMode(9, OUTPUT);*
pinMode(7, OUTPUT);*
pinMode(8, OUTPUT);*
Serial.println("connecting...");*
conectar();*
void loop() { -
if (!client.connected()) {*
Serial.println();*
Serial.println("disconnecting.");*
client.stop();*
conectar();*
if (client.available()) {*
char c = client.read();*
Serial.print(c);*
switch (c) {*
case '1' :*
analogWrite(3, 0);*
analogWrite(5, 255);*
analogWrite(9, 0);*
client.println("verde");*
break;*
case '2':*
analogWrite(3, 255);*
analogWrite(5, 30);*
analogWrite(9, 0);*
client.println("naranja");*
break;*
case '3':*
analogWrite(5, 0);*
analogWrite(9, 0);*
client.println("rojo");*
break;*
case '4':*
do{*
analogWrite(3, 0);*
analogWrite(9, 0);*
delay(1000);*
analogWrite(3, 0);*
analogWrite(5, 0);*
analogWrite(9, 0);*
delay(1000);*
if(c=='7') break;*
}while(1);*
break;*
case '5':*
for(;;){*
analogWrite(9, 0);*
delay(1000);*
analogWrite(3, 0);*
analogWrite(5, 0);*
analogWrite(9, 0);*
delay(1000);*
break;*
case '6':*
do {*
analogWrite(5, 0);*
analogWrite(9, 0);*
delay(1000);*
analogWrite(3, 0);*
analogWrite(5, 0);*
analogWrite(9, 0);*
delay(1000);*
} while (c == '6');*
c = client.read();*
break;*
case '7':*
analogWrite(3, 0);*
analogWrite(5, 0);*
analogWrite(9, 0);*
delay(1000);*
c = '4';*
client.println("Apagado");*
break;*
case '8':*
digitalWrite(8, HIGH);*
digitalWrite(7, LOW);*
delay(1000);*
digitalWrite(8, LOW);*
client.println("abierto");*
break;*
case '9':*
digitalWrite(7, HIGH);*
delay(1000);*
client.println("cerrado");*
break;*
default:*
break;*
start_reading();*
void conectar() { -
if (client.connect(server, 8194)) {*
Serial.println("connected");*
client.println();*
} else {*
Serial.println("connection failed");*
void start_reading() { -
if ( ! mfrc522.PICC_IsNewCardPresent())*
return;*
// Select one of the cards*
if ( ! mfrc522.PICC_ReadCardSerial())*
return;*
// Show some details of the PICC (that is: the tag/card)*
//Serial.print(F("Card UID:"));*
//Imprime id de rfid*
dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);*
Serial.println();*
// Halt PICC*
mfrc522.PICC_HaltA();*
// Stop encryption on PCD*
mfrc522.PCD_StopCrypto1();*
void dump_byte_array(byte *buffer, byte bufferSize) { -
for (byte i = 0; i < bufferSize; i++) {*
_ Serial.print(buffer < 0x10 ? " 0" : " ");_
_ Serial.print(buffer*, HEX);
client.print(buffer < 0x10 ? " 0" : " ");
client.print(buffer, HEX);
}*_
