The propose connection for RN41 and Arduino Uno is as below:
RN41 TX -----> Arduino Uno RX (Pin 0)
RN41 RX -----> Arduino Uno TX (Pin 1) ....... Voltage divider needed?
RN41 GND -----> Arduino GND pin
RN41 Vcc -----> Arduino 3.3V pin
Honestly, I am weak in circuit connection. Is my propose connection works? If not, can anyone provide suggestion or guidance for me? Thank you for further help.
Yes RN41 can work. You need to reduce the voltage levels 74HC4050 works great for that. No voltage divider needed, and your signals stay sharp. You will need 3.3V supply for the RN41, check what it needs, the 150mA from the Uno regulator may not be enough.
For now, my idea for the overall connection is as follow:
RN41 TX >---input to HC4050 > output---> Arduino Uno RX (Pin 0)
RN41 RX <---output from HC4050 < input---< Arduino Uno TX (Pin 1)
MM74HC4050N Vcc -----> 3.3V
MM74HC4050N GND -----> GND
Do i still need other hardware component other than HC4050? Or do i still miss anything?
