CAN shield MCP2515 not working in loopback mode with ACAN2515 library
Here is the code, it's the loopback demo. It sends frames, but doesn't receive them like it should be.
//  ACAN2515 Demo in loopback mode
#include <ACAN2515.h>
//  MCP2515 connections:
//    - standard SPI pins for SCK, MOSI and MISO
//    - a digital output for CS
//    - interrupt input pin for INT
// If you use CAN-BUS shield (http://wiki.seeedstudio.com/CAN-BUS_Shield_V2.0/) with Arduino Uno,
// use B connections for MISO, MOSI, SCK, #9 or #10 for CS (as you want),
// #2 or #3 for INT (as you want).
// Error codes and possible causes:
//    In case you see "Configuration error 0x1", the Arduino doesn't communicate
//       with the 2515. You will get this error if there is no CAN shield or if
//       the CS pin is incorrect.
//    In case you see succes up to "Sent: 17" and from then on "Send failure":
//       There is a problem with the interrupt. Check if correct pin is configured
static const byte MCP2515_CS  = 10 ; // CS input of MCP2515 (adapt to your design)
static const byte MCP2515_INT =  3 ; // INT output of MCP2515 (adapt to your design)
//  MCP2515 Driver object
ACAN2515 can (MCP2515_CS, SPI, MCP2515_INT) ;
//  MCP2515 Quartz: adapt to your design
static const uint32_t QUARTZ_FREQUENCY = 8UL * 1000UL * 1000UL ; // 8 MHz
//   SETUP
void setup () {
//--- Switch on builtin led
  pinMode (LED_BUILTIN, OUTPUT) ;
  digitalWrite (LED_BUILTIN, HIGH) ;
//--- Start serial
  Serial.begin (9600) ;
//--- Wait for serial (blink led at 10 Hz during waiting)
  while (!Serial) {
    delay (50) ;
    digitalWrite (LED_BUILTIN, !digitalRead (LED_BUILTIN)) ;
//--- Begin SPI
  SPI.begin () ;
//--- Configure ACAN2515
  Serial.println ("Configure ACAN2515") ;
  ACAN2515Settings settings (QUARTZ_FREQUENCY, 125UL * 1000UL) ; // CAN bit rate 125 kb/s
  settings.mRequestedMode = ACAN2515Settings::LoopBackMode ; // Select loopback mode
  const uint16_t errorCode = can.begin (settings, [] { can.isr () ; }) ;
  if (errorCode == 0) {
    Serial.print ("Bit Rate prescaler: ") ;
    Serial.println (settings.mBitRatePrescaler) ;
    Serial.print ("Propagation Segment: ") ;
    Serial.println (settings.mPropagationSegment) ;
    Serial.print ("Phase segment 1: ") ;
    Serial.println (settings.mPhaseSegment1) ;
    Serial.print ("Phase segment 2: ") ;
    Serial.println (settings.mPhaseSegment2) ;
    Serial.print ("SJW: ") ;
    Serial.println (settings.mSJW) ;
    Serial.print ("Triple Sampling: ") ;
    Serial.println (settings.mTripleSampling ? "yes" : "no") ;
    Serial.print ("Actual bit rate: ") ;
    Serial.print (settings.actualBitRate ()) ;
    Serial.println (" bit/s") ;
    Serial.print ("Exact bit rate ? ") ;
    Serial.println (settings.exactBitRate () ? "yes" : "no") ;
    Serial.print ("Sample point: ") ;
    Serial.print (settings.samplePointFromBitStart ()) ;
    Serial.println ("%") ;
  }else{
    Serial.print ("Configuration error 0x") ;
    Serial.println (errorCode, HEX) ;
static uint32_t gBlinkLedDate = 0 ;
static uint32_t gReceivedFrameCount = 0 ;
static uint32_t gSentFrameCount = 0 ;
void loop () {
  CANMessage frame ;
  if (gBlinkLedDate < millis ()) {
    gBlinkLedDate += 2000 ;
    const bool ok = can.tryToSend (frame) ;
    if (ok) {
      gSentFrameCount += 1 ;
      Serial.print ("Sent: ") ;
      Serial.println (gSentFrameCount) ;
    }else{
      Serial.println ("Send failure") ;
  if (can.available ()) {
    can.receive (frame) ;
    gReceivedFrameCount ++ ;
    Serial.print ("Received: ") ;
    Serial.println (gReceivedFrameCount) ;
Serial output:
Configure ACAN2515
Bit Rate prescaler: 2
Propagation Segment: 5
Phase segment 1: 5
Phase segment 2: 5
SJW: 4
Triple Sampling: no
Actual bit rate: 125000 bit/s
Exact bit rate ? yes
Sample point: 68%
Sent: 1
Sent: 2
Sent: 3
Sent: 4
Thank you all!
I never hooked up the interrupt pin to my arduino. :man_facepalming: Never mind
