Can single pin damage kill entire 328?
I carelessly allowed 9.3V briefly onto the D6 input of my 328 UNO chip. It will not now upload any sketch. I was hoping I could simply make the trivial program change and use another pin.
Bin it and move on with redoubled care? Or can anything practical be done please?
Terry
I would move on, but maybe keep the Arduino until you have more time
I have in the past killed a couple of Nanos by connecting power to them in reverse and although I eventually got them working again by replacing a Zener diode on each of them, it was more important to me at the time to have a working Arduino so I bought 2 more
When I had more time to research I fixed them so I now have 4 working Nanos, which is no bad thing
If the 328 on your Arduino is socketed you could probably just replace it. Which Arduino do you have ?
Thanks for the fast reply.
I mounted it on a 28-pin IC-socket. The program's been working fine (pressing a button on a camera).
I think I read somewhere that although it now appears lifeless (caused by that one pin's damage!), it's sometime possible to re-bootload it with a ch-340?
Anyway, I'll set it aside as you suggest and use another 328 chip. Browsing briefly just now to buy a few more, I see they are being discontinued?
My board is a UNO R3 (a clone).
Terrypin:
You need a programmer (or another Arduino that is programmed as a programmer) to load a bootloader via the ICSP pins.
Terrypin:
Anyway, I’ll set it aside as you suggest and use another 328 chip. Browsing briefly just now to buy a few more, I see they are being discontinued?
Please post a link to where you saw that information.
