I would really appreciate your help i need it know and i'm desperate because i don't know what to do
tone(thePin, 38000);
Here is one that uses Timer 1
Maybe research into MsTimer2.h if you need to use Timer 2.
#include <TimerOne.h>
// Initialize the digital pin as an output.
// Pin 13 has an LED connected on most Arduino boards
pinMode(13, OUTPUT);
Timer1.initialize(13);
Timer1.attachInterrupt( timerIsr ); // attach the service routine here
void timerIsr()
PINB |= _BV(PINB5); // Toggle digital pin D13
gardner:
Confirmed with my scope:
void setup ()
tone(3, 38000);
} // end of setup
void loop () { }
Boy, that was easy!
READ THE OP
OP was given alternatives in case they were not aware them.
They were directed to research into MsTimer2.h
If the OP doesn't want to read replies they don't have to.
Vaclav:
READ THE OP
What are you getting at? The tone library uses Timer 2.
Besides, this isn't a programming question it is a Project Guidance question.
gardner:
http://arduino.cc/en/Reference/Tonetone(thePin, 38000);
I'm wondering if the OP didn't mean a38k carrier for (say) an IR signal. Is it possible to use that tone with a message? I suppose it could be sent in bursts.
Without using timers at all*, adafruit have simple code here which has a function pulseIR(long microsecs). It sends a square 38k wave (just digitalWrites of high and low using delayMicroseconds) for a burst of microsecs, thus sending the message using 38k as the carrier.
- or does delayMicroseconds use a timer under the hood?
I've verified the waveform on a 'scope.
edit:
In this part of the adafruit code:
// This procedure sends a 38KHz pulse to the IRledPin
// for a certain # of microseconds. We'll use this whenever we need to send codes
void pulseIR(long microsecs) {
// we'll count down from the number of microseconds we are told to wait
cli(); // this turns off any background interrupts
while (microsecs > 0) {
// 38 kHz is about 13 microseconds high and 13 microseconds low
digitalWrite(IRledPin, HIGH); // this takes about 3 microseconds to happen
delayMicroseconds(10); // hang out for 10 microseconds, you can also change this to 9 if its not working
digitalWrite(IRledPin, LOW); // this also takes about 3 microseconds
// so 26 microseconds altogether
microsecs -= 26;
sei(); // this turns them back on
.... I guess the digitalWrites to give the wave could just be replaced with tone(), thusly:
tone(IRledPin, 38000);
microsecs -= 26;
JimboZA:
No.
I have stuff about timers and 38 kHz here:
However the original post was so devoid of detail (except that the OP is desperate) that it is hard to know what it is required for.
@electman: The better the question, the better the answer.
JimboZA:
I'm wondering
Me too. My mindreading is not that great.
