Can someone complete the program for me?
I downloaded the stair lighting code from the internet and modified it to match my stairs.
I would like to add a button to the existing code that would change the mode and some kind of "party mode"
I am an absolute noob to coding, and I believe that something like this is very simple for some of you.
So if someone is willing to write the code in existing ino file for me
Thank you in advance
<#include <Adafruit_NeoPixel.h>
#define PIN 6
// Parameter 1 = 321
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(321, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit...if you must, connect GND first.
// Set up Variables
unsigned long timeOut=60000; // timestamp to remember when the PIR was triggered.
int downUp = 0; // variable to rememer the direction of travel up or down the stairs
int alarmPinTop = 4; // PIR at the top of the stairs
int alarmPinBottom =2; // PIR at the bottom of the stairs
int alarmValueTop = HIGH; // Variable to hold the PIR status
int alarmValueBottom = HIGH; // Variable to hold the PIR status
int ledPin = 13; // LED on the arduino board flashes when PIR activated
int LDRSensor = A0; // Light dependant resistor
int LDRValue = 0; // Variable to hold the LDR value
int colourArray[350]; // An array to hold RGB values
int change = 1; // used in 'breathing' the LED's
int breathe = 0; // used in 'breathing' the LED's
strip.begin();
strip.show(); // Initialize all pixels to 'off'
Serial.begin (9600); // only requred for debugging
pinMode(ledPin, OUTPUT); // initilise the onboard pin 13 LED as an indicator
pinMode(alarmPinTop, INPUT_PULLUP); // for PIR at top of stairs initialise the input pin and use the internal restistor
pinMode(alarmPinBottom, INPUT_PULLUP); // for PIR at bottom of stairs initialise the input pin and use the internal restistor
delay (2000); // it takes the sensor 2 seconds to scan the area around it before it can
//detect infrared presence.
for (int i=0 ;i < 321; i++) { // initilise the colourArray to zero
colourArray[i]=0;
LDRValue = analogRead(LDRSensor);
//Serial.println(LDRValue);
if (timeOut+12000 < millis()) { // idle state - 'breathe' the top and bottom LED to show program is looping
 breathe = breathe + change;
   strip.setPixelColor(0,0,0,breathe);
   strip.setPixelColor(20,0,0,breathe);
   strip.setPixelColor(21,0,0,breathe);
   strip.setPixelColor(41,0,0,breathe);
   strip.setPixelColor(42,0,0,breathe);
   strip.setPixelColor(62,0,0,breathe);
   strip.setPixelColor(63,0,0,breathe);
   strip.setPixelColor(83,0,0,breathe);
   strip.setPixelColor(84,0,0,breathe);
   strip.setPixelColor(104,0,0,breathe);
   strip.setPixelColor(105,0,0,breathe);
   strip.setPixelColor(125,0,0,breathe);
   strip.setPixelColor(126,0,0,breathe);
   strip.setPixelColor(146,0,0,breathe);
   strip.setPixelColor(147,0,0,breathe);
   strip.setPixelColor(167,0,0,breathe);
   strip.setPixelColor(168,0,0,breathe);
   strip.setPixelColor(188,0,0,breathe);
   strip.setPixelColor(189,0,0,breathe);
   strip.setPixelColor(210,0,0,breathe);
   strip.setPixelColor(211,0,0,breathe);
   strip.setPixelColor(236,0,0,breathe);
   strip.setPixelColor(237,0,0,breathe);
   strip.setPixelColor(268,0,0,breathe);
   strip.setPixelColor(269,0,0,breathe);
   strip.setPixelColor(295,0,0,breathe);
   strip.setPixelColor(296,0,0,breathe);
   strip.setPixelColor(320,0,0,breathe);
 strip.show();
 if (breathe == 100 || breathe == 0) change = -change;      // breathe the LED from 0 = off to 100 = fairly bright
 if (breathe == 100 || breathe == 0) delay (250);           // Pause at beginning and end of each breath
 delay(25);
if (LDRValue < 400) { // only switch on LED's at night when LDR senses low light conditions - you may have to change the number for your circumstances!
alarmValueTop = digitalRead(alarmPinTop);        // Constantly poll the PIR at the top of the stairs
alarmValueBottom = digitalRead(alarmPinBottom);  // Constantly poll the PIR at the bottom of the stairs
 if (alarmValueTop == HIGH && downUp != 2)  {      // the 2nd term allows timeOut to be contantly reset if one lingers at the top of the stairs before decending but will not allow the bottom PIR to reset timeOut as you decend past it.
  timeOut=millis();  // Timestamp when the PIR is triggered.  The LED cycle wil then start.
  downUp = 1;
  topdown();         // lights up the strip from top down
if (alarmValueBottom == HIGH && downUp != 1)  {    // the 2nd term allows timeOut to be contantly reset if one lingers at the bottom of the stairs before decending but will not allow the top PIR to reset timeOut as you decend past it.
  downUp = 2;
  bottomup();         // lights up the strip from bottom up
if (timeOut+10000 < millis() && timeOut+11999 < millis()) {    //switch off LED's in the direction of travel.
   if (downUp == 1) {
      colourWipeDown(strip.Color(0, 0, 0), 40); // Off
   if (downUp == 2)  {
    colourWipeUp(strip.Color(0, 0, 0), 40);   // Off
  downUp = 0;
  //   for (int i=0 ;i < 350; i++)  {          // Depending on your preference you may want to include this loop to clear out the colourArray
  //    colourArray[i]=0;
// if (timeOut+13000 < millis() && timeOut+35999 > millis()) waterfall(); // Waterfall effect to play between these times after a PIR trigger.
// if (timeOut+36000 < millis() && timeOut+9999 > millis()) fade(); // Fade/switch off LED's
void topdown() {
Serial.println ("detected top"); // Helpful debug message
colourWipeDown(strip.Color(130, 100, 30), 40); // Warm White
for(int i=0; i<3; i++) { // Helpful debug indication flashes led on Arduino board twice
digitalWrite(ledPin,HIGH);
delay(200);
digitalWrite(ledPin,LOW);
delay(200);
void bottomup() {
Serial.println ("detected bottom"); // Helpful debug message
colourWipeUp(strip.Color(130, 100, 30), 40); // Warm White
delay(200);
delay(200);
// Fill the dots one after the other with a color
void colourWipeDown(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(5);
void colourWipeUp(uint32_t c, uint8_t wait) {
for(uint16_t i=strip.numPixels(); i < -1; i--) {
strip.show();
delay(5);
// Play the Waterfall effect
void waterfall(){
for(int i=347; i>-1; i--) { // Shift the RGB colours down in the colourArray[]
colourArray[i+3]=colourArray[i];
colourArray[0] = random(0,20); // Genearate the red component of the 1st LED at the top of the stairs
colourArray[1] = random(0,40); // Genearate the green component of the 1st LED at the top of the stairs
colourArray[2] = random(10,70); // Genearate the blue component of the 1st LED at the top of the stairs
  for (int k=0; k<351; k=k+3)   {       // Set and send the colours to the strip
   uint32_t c = strip.Color(colourArray[k],colourArray[k+1],colourArray[k+2]);
   strip.setPixelColor(((k+3)/3)-1,c);
  strip.show();      // and display the result
  delay(35);         // delay to simulate running water
// Play the LED fade out
void fade(){
for (int j = 0; j <70; j++) {
for(int i=350; i>-1; i--) {
colourArray[i]=colourArray[i]-1; // reduce intensity of light by 1
if (colourArray[i] <= 0 ) colourArray[i] = 0;
strip.show();
delay(60);
breathe = 0;
change = 1;
Please edit your post to add code tags. See the "How to get the best out of this forum" post for the details.
If you are going to ask someone to write code for you, at least define, in a very detailed way, what a "party mode" is and explain if you also want the "party mode" to be reset if the button is pressed a second time.
The internet is quite a big place, can you say where you found the example code?
Its a big bit of code.
A lot of the volunteers on here wont have all the hardware the code uses and can replicate and test the setup you have.
As for what exactly that means ........................
Can, say, this code
connect with the above code.
With a button that would switch between modes
Did you actually try that code to see if it works for you?
BG_LED_Stairs works perfectly, with sensors like normal stair lighting after i modified number of leds and speed
But I would like to add something else to make the stairs a little more interesting
epic
