What I expect is that I am wiring up a network device to a twisted pair to read and write packets which will be expressed as differential voltages. The protocol is Toyota AVC-Lan which is similar to IEBus. The convention is for these terminals to be labeled TX+ for the high voltage and TX- for the low voltage.
I don't understand the code snippet below. What I'm expecting is, I'll understand which Arduino Nano pins to connect the TX+ and TX- terminals of the network.
Although I don't understand this section, I think this would be the place for the configuration I am expecting. Can anybody explain to me what is being done here?
// TX LED connected to Pin1 of PORTC
#define TX_LED_DDR DDRC
#define TX_LED_PORT PORTC
#define TX_LED_PIN PINC
#define TX_LED_OUT 2
// RX LED connected to Pin4 of PORTC
#define RX_LED_DDR DDRC
#define RX_LED_PORT PORTC
#define RX_LED_PIN PINC
#define RX_LED_OUT 4
It could be, that I connect the TX wires to the same ports as the resistors (as I think that's the proper termination topology) but that wouldn't explain which one is the high and which one is the low.
Many thanks. OK, so this PORTC stuff is just a poorly self-documenting and error-prone way to very quickly perform actions like pinMode( 6, OUTPUT ); etc.
As the program will be switching between reading and writing on the two pins, I think I can see why the author chose this route.
If I can figure it out and get it working, I will contribute some better comments to this config file.
A port on a processor is a group of (usually byte wide or 8 bits) dedicated to a specific collection of data. These can be internal or external. Timer ports (registers) would be an example of an internal port. Normally port A, B, C would be 8 bit groupings on a microprocessor addressed at the same address. That definition is now very convoluted and like a sea port it just indicates where a certain type of information can be sent or received such as HDMI, VGA, Serial etc and no longer in groups of 8. Yes I still come across ones I do not know about such as IPMI.
Your c = ... ? ... : c; code looks like a horrible way to uppercase Roman letters but who knows if I have it right! (That's not from my project is it??)
@johnerrington I suspect you might be able to understand the snippet I pasted. Would it be correct to convert in this way?
// TX LED connected to Pin1 of PORTC (i.e. Arduino terminal A1)
#define TX_LED_OUT 0b00000010
// RX LED connected to Pin4 of PORTC (i.e. Arduino terminal A4)
#define RX_LED_OUT 0b00000100
I think the danger in how this was written is that if an implementer naively tried to change RX_LED from 4 to 6 in decimal, they would be setting two pins instead of one.
Importantly, the place where this code is used later looks like:
Question: These cbi() and sbi() functions - are they similarly "fast" and an appropriate use here? As obviously the RX_LED_ON etc. macros are called within loop().
I really appreciate all the feedback I have received here. Thank you.
Maybe it's worth noting, the original library this project was adapted from uses these values like this. I think it is quite a different use case, since multiple pins are being set at once.
I think also these undocumented cbi() and sbi() functions may actually accept a decimal parameter. Meaning, the original code wasn't incorrect except for the 2!=1 part.
Any of several different C/C++ methods of representing a parameter may be used for an argument to any function, including the well documented functions sbi() and cbi().
It seems a very strange idea to name a whole port based on a single pin. As here ALL of port C is named based on pin 0b00000010
so eg if all of port D was being used for indicators I'd name it indicatorsDDR etc.
and yes I agree its clearer and safer to use binary for the actions
I'd suggest the mystery doesn't end there. Why waste analog pins on LEDs?
I also have problems understanding the logic of how the differential voltage data pins are used. They are specified as two digital ports, although I believe the voltages are <1V.
Oh and one more thing. I think you and I possibly confused the fourth macro in each set for a bitwise notation. I think you'll find in #post_8 that these values TX_LED_OUT are used as arguments to the cbi() and sbi() functions, which I think takes an integer from 0 to 7, specifying a single bit. So 0b0000'0110 would set/check bit number six, not bits 1 and 2.
So:
It's confusing to put the pin number spec at the bottom of the PORT specification block;
It's possibly confusing to use PORT references for a single pin;
I think my suggestion of making the pin specification in binary is not appropriate for the relevant two lines - it might make it more confusing what is happening.
At the higher abstraction level, it doesn't really make sense to allocate analog ports for LEDs.
I'm all ears if anyone has an observation. I might have got something really wrong here.
