Can someone explain this code to me from line to line? I need it to for a test
//Array, used to store the data of pattern, can be calculated by yourself or obtained from the modulus tool
unsigned char front[] = {0x00,0x00,0x00,0x00,0x00,0x24,0x12,0x09,0x12,0x24,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char left[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x44,0x28,0x10,0x44,0x28,0x10,0x44,0x28,0x10,0x00};
unsigned char right[] = {0x00,0x10,0x28,0x44,0x10,0x28,0x44,0x10,0x28,0x44,0x00,0x00,0x00,0x00,0x00,0x00};
unsigned char STOP01[] = {0x2E,0x2A,0x3A,0x00,0x02,0x3E,0x02,0x00,0x3E,0x22,0x3E,0x00,0x3E,0x0A,0x0E,0x00};
unsigned char clear[] = {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
#define SCL_Pin  A5  //Set clock pin to A5
#define SDA_Pin  A4  //Set data pin to A4
#define ML_Ctrl 4     //define direction control pin of B motor
#define ML_PWM 5   //define PWM control pin of B motor
#define MR_Ctrl 2    //define direction control pin of A motor
#define MR_PWM 9   //define PWM control pin of A motor
#include "SR04.h"//define the library of ultrasonic sensor
#define TRIG_PIN 12// set the signal input of ultrasonic sensor to D12
#define ECHO_PIN 13//set the signal output of ultrasonic sensor to D13
SR04 sr04 = SR04(ECHO_PIN,TRIG_PIN);
long distance,a1,a2;//define three distance
const int servopin = 10;//set the pin of servo to D10
  Serial.begin(9600);//open serial monitor and set baud rate to 9600
  pinMode(ML_Ctrl, OUTPUT);//set direction control pin of B motor to OUTPUT
  pinMode(ML_PWM, OUTPUT);//set PWM control pin of B motor to OUTPUT
  pinMode(MR_Ctrl, OUTPUT);//set direction control pin of A motor to OUTPUT
  pinMode(MR_PWM, OUTPUT);//set PWM control pin of A motor to OUTPUT
  servopulse(servopin,90);// the angle of servo is 90 degree
  delay(300);
  pinMode(SCL_Pin,OUTPUT);//  set clock pin to OUTPUT
  pinMode(SDA_Pin,OUTPUT);//set data pin to OUTPUT
  matrix_display(clear);// Clear the matrix display
  avoid();//run the main program
void avoid()
  distance=sr04.Distance(); //obtain the value detected by ultrasonic sensor
  if((distance < 20)&&(distance > 0))//if the distance is greater than 0 and less than 20
    car_Stop();//stop
    matrix_display(STOP01);   //show stop pattern
    delay(100);
    servopulse(servopin,180);//servo rotates to 180°
    a1=sr04.Distance();//measure the distance
    delay(100);
    servopulse(servopin,0);//rotate to 0 degree
    a2=sr04.Distance();//measure the distance
    delay(100);
if(a1 > a2)//if distance a1 is greater than a2
      car_left();//turn left
      matrix_display(left);   //display left-turning pattern
      servopulse(servopin,90);//servo rotates to 90 degree
      delay(600);
      matrix_display(front);   //show forward pattern
    else//if the right distance is greater than the left
      car_right();// turn right
      matrix_display(right);   // display right-turning pattern
      servopulse(servopin,90);// servo rotates to 90 degree
      delay(600);
  else//otherwise
    car_front();//go forward
    matrix_display(front);   // show forward pattern
void servopulse(int servopin,int myangle)//the running angle of servo
  for(int i=0; i<30; i++)
    int pulsewidth = (myangle*11)+500;
    digitalWrite(servopin,HIGH);
    delayMicroseconds(pulsewidth);
    digitalWrite(servopin,LOW);
    delay(20-pulsewidth/1000);
void car_front()//car goes forward
  digitalWrite(ML_Ctrl,HIGH);//set direction control pin of B motor to HIGH level
  analogWrite(ML_PWM,150);//set PWM control speed of B motor to 150
  digitalWrite(MR_Ctrl,HIGH);//set direction control pin of A motor to HIGH level
  analogWrite(MR_PWM,150);//set PWM control speed of A motor to 150
void car_back()//go back
  digitalWrite(ML_Ctrl,LOW);//set direction control pin of B motor to LOW
  analogWrite(ML_PWM,200);//set PWM control speed of B motor to 200
  digitalWrite(MR_Ctrl,LOW);//set direction control pin of A motor to LOW
  analogWrite(MR_PWM,200);//set PWM control speed of A motor to 200
void car_left()//car turns left
void car_right()//car turn rights
void car_Stop()//car stops
  delay(50);
  analogWrite(ML_PWM,0);//set PWM control speed of B motor to 0
  analogWrite(MR_PWM,0);//set PWM control speed of A motor to 0
//this function is used for dot matrix display
void matrix_display(unsigned char matrix_value[])
  IIC_start();  //the function to call the data transmission
  IIC_send(0xc0);  //Select address
  for(int i = 0;i < 16;i++) //Pattern data has 16 bytes
    IIC_send(matrix_value[i]); //data to convey patterns
  IIC_end();   //end the transmission of patterns data
  IIC_start();
  IIC_send(0x8A);  //display control, set pulse width to 4/16
  IIC_end();
//  the condition that data transmission starts
void IIC_start()
  digitalWrite(SCL_Pin,HIGH);
  delayMicroseconds(3);
  digitalWrite(SDA_Pin,HIGH);
  digitalWrite(SDA_Pin,LOW);
// transmit data
void IIC_send(unsigned char send_data)
  for(char i = 0;i < 8;i++)  //Every character has 8 bits
    digitalWrite(SCL_Pin,LOW);  //pull down the SCL_Pin to change the signal of SDA
    if(send_data & 0x01)  //1 or 0 of byte  is used to set high and low level of SDA_Pin
    digitalWrite(SCL_Pin,HIGH); //Pull up SCL_Pin to stop data transmission
    send_data = send_data >> 1;  //Detect bit by bit, so move the data right by one bit
//the sign that data transmission ends
void IIC_end()
Which lines can you not explain yourself?
the functions like pinmode, servopulse, MR_PWM, ML_ctrl, delay, servopin, digital write, 20-pulsewithd/1000, analogwrite, send_data. Not the actual lines, im sorry for the confusion
the functions like pinmode, servopulse, MR_PWM, ML_ctrl, delay, servopin, digital write, 20-pulsewithd/1000, analogwrite, send_data. Not the actual lines, im sorry for the confusion...
did you look in the documentation or should we do that for you?
pinmode
analogwrite
if you don't understand
then may be you need to learn C++
Start here:
Sadly, we wont be learning c++ but our assignment is to understand this and explain the entire
I suggest you start by googling things like "arduino pinmode" and collect the explanations in maybe a printed page or print to pdf etc.
Also know the "Arduino Reference" is quite terse. For functional statements like "if", "for", "while" etc. you will be better served if you go to a C++ site as they usually have more detail.
Special functions are usually best described in their library documentation.
ok thanks, is there more like this?
non sequitur
For what course is this assignment? Can you post the exact assignment you were given?
The Arduino language reference is the source of explanations for all of the "Arduino" functions.
I like cplusplus.com for references to C++ functions.
you google "Arduino xxxx documentation" for each xxx keyword you don't understand, that should get you started at least for the functions
it won't help for 20-pulsewithd/1000... this is simple maths formula that you have to put in context
but if you don't understand the language I'm unsure what's the point trying to dissect the code...
yea but it would be great if someone could explain the/hardest functions with examples from my posted code
I think the keyword here is "our".
Can you mark-up the particular lines that are causing problems, and save us the effort of having to explain everything?
yeah it would be great if someone would also write your essay about it and take tour final tests so that you don't have any work to do...
seems you are pretty lazy. The goal of the exercise if probably for you to dig into all this and learn from it....
good luck
PS/ I will be good and contribute a bit
the line
is a comment to make the text look good and can safely be ignored.
we are building a arduino robot and our teacher gave us the assignment to "Your robot should run around without colliding with anything. In the event of obstacles, the robot must stop, check to the right and left and decide in which direction it should drive, turn in the direction it is most free and continue its journey in that direction. If it is not possible to drive either to the right or to the left, the robot must turn 180 degrees and continue its journey." after that we must explain the code
so why didn't you write the code. I think the exercice to explain the code is to ensure that you did not steal it from someone else or the internet...
seems this is what you did... (the */ at the start of the code seems to indicate you removed something that was before that, like copyright or credit to the author)
And your teacher did that without teaching you anything about C++?
If that is true, I get the feeling that this is a case for a review board, not for this forum, because it paints your teacher as quite incompetent. But I also get the feeling that it is not true.
BTW - seen this post from 26 days ago
so code is coming from
https://wiki.keyestudio.com/KS0470_Keyestudio_4WD_BT_Robot_Car_V2.0_Kit_for_Arduino#Project_12:_Ultrasonic_Avoiding_Robot
