thanks for the responses. Here is how i have modified the code so far but to no avail.
#include <FrequencyTimer2.h>
* Show messages on an 8x8 led matrix,
* scrolling from right to left.
* Uses FrequencyTimer2 library to
* constantly run an interrupt routine
* at a specified frequency. This
* refreshes the display without the
* main loop having to do anything.
#define T { \
{0, 0, 1, 1, 1, 1, 1, 1, 0, 0}, \
{0, 0, 0, 0, 1, 1, 0, 0, 0, 0}, \
{0, 0, 0, 0, 1, 1, 0, 0, 0, 0} \
#define E { \
{0, 0, 0, 1, 1, 1, 1, 0, 0, 0}, \
{0, 0, 0, 1, 0, 0, 0, 0, 0, 0}, \
{0, 0, 0, 1, 1, 1, 0, 0, 0, 0}, \
{0, 0, 0, 1, 1, 1, 1, 0, 0, 0} \
#define S { \
{0, 0, 0, 0, 1, 1, 1, 0, 0, 0}, \
{0, 0, 0, 0, 1, 0, 0, 0, 0, 0}, \
{0, 0, 0, 0, 0, 1, 1, 0, 0, 0}, \
{0, 0, 0, 0, 0, 0, 1, 0, 0, 0}, \
byte col = 0;
byte leds[6][10];
// pin[xx] on led matrix connected to nn on Arduino (-1 is dummy to make array start at pos 1)
int pins[17]= {-1, 14, 15, 16, 17, 18, 19, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13};
// col[xx] of leds = pin yy on led matrix
int cols[10] = {pins[7], pins[8], pins[9], pins[10], pins[11], pins[12], pins[13], pins[14], pins[15], pins[16]};
// row[xx] of leds = pin yy on led matrix
int rows[6] = {pins[1], pins[2], pins[3], pins[4], pins[5], pins[6]};
const int numPatterns = 4;
byte patterns[numPatterns][6][10] = {
T,E,S,T
int pattern = 0;
// sets the pins as output
for (int i = 1; i <= 16; i++) {
pinMode(pins[i], OUTPUT);
// set up cols and rows
for (int i = 1; i <= 10; i++) {
digitalWrite(cols[i - 1], LOW);
for (int i = 1; i <= 6; i++) {
digitalWrite(rows[i - 1], LOW);
clearLeds();
// Turn off toggling of pin 11
FrequencyTimer2::disable();
// Set refresh rate (interrupt timeout period)
FrequencyTimer2::setPeriod(1000);
// Set interrupt routine to be called
FrequencyTimer2::setOnOverflow(display);
setPattern(pattern);
pattern = ++pattern % numPatterns;
slidePattern(pattern, 60);
void clearLeds() {
// Clear display array
for (int i = 0; i < 6; i++) {
for (int j = 0; j < 10; j++) {
leds[i][j] = 0;
void setPattern(int pattern) {
leds[i][j] = patterns[pattern][i][j];
void slidePattern(int pattern, int del) {
for (int l = 0; l < 8; l++) {
for (int i = 0; i < 7; i++) {
for (int j = 0; j < 8; j++) {
leds[j][i] = leds[j][i+1];
leds[j][7] = patterns[pattern][j][0 + l];
delay(del);
// Interrupt routine
void display() {
digitalWrite(cols[col], LOW); // Turn whole previous column off
col++;
if (col == 10) {
col = 0;
for (int row = 0; row < 6; row++) {
if (leds[col][5 - row] == 1) {
digitalWrite(rows[row], LOW); // Turn on this led
else {
digitalWrite(rows[row], HIGH); // Turn off this led
digitalWrite(cols[col], HIGH); // Turn whole column on at once (for equal lighting times)
delayMicroseconds(900); // Delay so that on times are longer than off time = brighter leds
Also, my 6x20 matrix is set up like this:
I believe my problem is that the original code is only addressing the one led per column where mine needs to address each column in both directions.
