* Append Example
* This sketch shows how to use open for append.
* The sketch will append 100 line each time it opens the file.
* The sketch will open and close the file 100 times.
#include <SdFat.h>
// file system object
SdFat sd;
// create Serial stream
ArduinoOutStream cout(Serial);
// store error strings in flash to save RAM
#define error(s) sd.errorHalt_P(PSTR(s))
// filename for this example
char filename[] = "APPEND.TXT";
// pstr() stores strings in flash to save RAM
cout << endl << pstr("Type any character to start\n");
while (!Serial.available());
// initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
// breadboards. use SPI_FULL_SPEED for better performance.
if (!sd.init(SPI_HALF_SPEED)) sd.initErrorHalt();
cout << pstr("Appending to: ") << filename;
for (uint8_t i = 0; i < 100; i++) {
// open stream for append
ofstream sdout(filename, ios::out | ios::app);
if (!sdout) error("open failed");
// append 100 lines to the file
for (uint8_t j = 0; j < 100; j++) {
// use int() so byte will print as decimal number
sdout << "line " << int(j) << " of pass " << int(i);
sdout << " millis = " << millis() << endl;
// close the stream
sdout.close();
if (!sdout) error("append data failed");
// output progress indicator
if (i % 25 == 0) cout << endl;
cout << '.';
cout << endl << "Done" << endl;
void loop() {}
I see "cout" and "endl", but I don't find any references for them.
Are they part of the SD-library, or native C?
Search gave me only codes where they are included, but I can't find specific informations for these?
