Can someone help I have got lost
Hi everyone
I am trying to create a project that can toggle lights on either by using multiple buttons or a webpage. I found a couple of example projects and have cobbled something together.
I have set up an array that references pin 13 only for testing(waiting for some more lights!)
The problem I am having is in the ToggleLights function I can’t see why the lights aren’t turning on/off. If someone could point me in the right direction I would very very happy!!!
thanks
jasemilly
#include <SPI.h>
#include <Ethernet.h>
// the analog 0-5 pins are also known as 14-19  THIS is what the LIGHT SWITCHES ARE WIRED TOO
byte buttons[] = {2, 3, 8};
byte Lights[] = {13, 13, 13};
#define buttonState sizeof(buttons)
#define DEBOUNCE 10  // button debouncer, how many ms to debounce, 5+ ms is usually plenty
// This handy macro lets us determine how big the array up above is, by checking the size
#define NUMBUTTONS sizeof(buttons)
// we will track if a button is just pressed, just released, or 'currently pressed'
byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 0, 20); // IP address, may need to change depending on network
EthernetServer server(80);  // create a server at port 80
String HTTP_req;          // stores the HTTP request
boolean LED_status = 0;   // state of LED, off by default
// here is the set up
    byte i;
    Ethernet.begin(mac, ip);  // initialize Ethernet device
    server.begin();           // start to listen for clients
    Serial.begin(9600);       // for diagnostics
    // Make Lights
    for (i=0; i< NUMBUTTONS; i++) {
      pinMode(Lights[i], OUTPUT);
    // Make input & enable pull-up resistors on switch pins
      pinMode(buttons[i], INPUT);
      digitalWrite(buttons[i], HIGH);
//here is the loop
    EthernetClient client = server.available();  // try to get client
    if (client) {  // got client?
        boolean currentLineIsBlank = true;
        while (client.connected()) {
            if (client.available()) {   // client data available to read
                char c = client.read(); // read 1 byte (character) from client
                HTTP_req += c;  // save the HTTP request 1 char at a time
                // last line of client request is blank and ends with \n
                // respond to client only after last line received
                if (c == '\n' && currentLineIsBlank) {
                    // send a standard http response header
                    client.println("Content-Type: text/html");
                    client.println("Connection: close");
                    client.println();
                    // send web page
                    client.println("<!DOCTYPE html>");
                    client.println("<html>");
                    client.println("<head>");
                    client.println("<title>Arduino LED Control</title>");
                    client.println("</head>");
                    client.println("<body>");
                    client.println("<h1>LED</h1>");
                    client.println("<p>Click to switch LED on and off.</p>");
                    client.println("<form method=\"get\">");
                    ProcessCheckbox(client);
                    client.println("</form>");
                    client.println("</body>");
                    client.println("</html>");
                    Serial.print(HTTP_req);
                    HTTP_req = "";    // finished with request, empty string
                // every line of text received from the client ends with \r\n
                if (c == '\n') {
                    // last character on line of received text
                    // starting new line with next character read
                else if (c != '\r') {
                    // a text character was received from client
                    currentLineIsBlank = false;
            } // end if (client.available())
        } // end while (client.connected())
        delay(1);      // give the web browser time to receive the data
        client.stop(); // close the connection
    } // end if (client)
    check_switches();      // when we check the switches we'll get the current state
  for (byte i = 0; i < NUMBUTTONS; i++) {
    if (justpressed[i]) {
      Serial.print(i, DEC);
      Serial.println(" Just pressed");
      // remember, check_switches() will CLEAR the 'just pressed' flag
      //make a call here for to toggle lights pass I to get house code array
      ToggleLights(i);
// switch LED and send back HTML for LED checkbox
void ProcessCheckbox(EthernetClient cl)
    if (HTTP_req.indexOf("LED2=2") > -1) {  // see if checkbox was clicked
        // the checkbox was clicked, toggle the LED
        if (LED_status) {
            LED_status = 0;
        else {
            LED_status = 1;
    if (LED_status) {    // switch LED on
        digitalWrite(13, HIGH);
        // checkbox is checked
        cl.println("<input type=\"checkbox\" name=\"LED2\" value=\"2\" \
        onclick=\"submit();\" checked>LED2");
    else {              // switch LED off
        digitalWrite(13, LOW);
        // checkbox is unchecked
        onclick=\"submit();\">LED2");
void ToggleLights(int HouseCodeArray){
  Serial.println(" ToggleLights " && Lights[HouseCodeArray]);
   if(Lights[HouseCodeArray] ==HIGH){
     digitalWrite(Lights[HouseCodeArray],LOW);
   if(Lights[HouseCodeArray] ==LOW) {
       digitalWrite(Lights[HouseCodeArray],HIGH);
void check_switches()
  static byte previousstate[NUMBUTTONS];
  static byte currentstate[NUMBUTTONS];
  static long lasttime;
  byte index;
  if (millis() < lasttime) {
     // we wrapped around, lets just try again
     lasttime = millis();
  if ((lasttime + DEBOUNCE) > millis()) {
    // not enough time has passed to debounce
    return;
  // ok we have waited DEBOUNCE milliseconds, lets reset the timer
  for (index = 0; index < NUMBUTTONS; index++) {
    justpressed[index] = 0;       // when we start, we clear out the "just" indicators
    justreleased[index] = 0;
    currentstate[index] = digitalRead(buttons[index]);   // read the button
    if (currentstate[index] == previousstate[index]) {
      if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {
          // just pressed
          justpressed[index] = 1;
      else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
          // just released
          justreleased[index] = 1;
      pressed[index] = !currentstate[index];  // remember, digital HIGH means NOT pressed
    //Serial.println(pressed[index], DEC);
    previousstate[index] = currentstate[index];   // keep a running tally of the buttons
Pin 13 is an SPI pin, used for communication between the ethernet shield and the Arduino. You can NOT use it.
