Can someone help me about this error?thankyou
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
Sketch uses 5096 bytes (15%) of program storage space. Maximum is 32256 bytes.
Global variables use 384 bytes (18%) of dynamic memory, leaving 1664 bytes for local variables. Maximum is 2048 bytes.
C:\Users\muhdh\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\muhdh\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\muhdh\AppData\Local\Temp\arduino_build_252894/mop.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\muhdh\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
An error occurred while uploading the sketch
avrdude: ser_open(): can't set com-state for "\\.\COM4"
avrdude done.  Thank you.
option enabled in File -> Preferences.
this means your PC has trouble finding and discussing with your arduino on COM4
right port selected? good USB cable? really an UNO on the other side?
no device on this port, select proper port
i already install the ch340 driver and use a new cable. but the error still occured
the UNO does not need a CH340
when you plug in your Arduino, does it show up in the ports ? does window tell you something got connected ? same when you unplug ?
yes, the port show up. but the error still occured
and if you remove the Arduino, the port disappear ? (I use a Mac so not sure about the behaviour on windows)
Yes, the port disappeared. what do you think?
may be a boot loader issue on your board... if you have an extra board, may be consider reinstalling the boot loader
Have you got anything connected to pins 0 and 1 ?
Hi, @hazequino
Welcome to the forum.
Can you please post an image of your Arduino UNO please?
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
original not need, but clone does
