Can someone help me to combine 2 codes in one to use only one plate attached code
Hello.
I wanted to put together a project for a stepper motor and a project for a sequence of leds in a single board.
#include <AccelStepper.h>           // Load the AccelStepper library
#define motorPin1  5                // IN1 pin on the ULN2003A driver
#define motorPin2  4                // IN2 pin on the ULN2003A driver
#define motorPin3  0               // IN3 pin on the ULN2003A driver
#define motorPin4  2               // IN4 pin on the ULN2003A driver
int stepsPerRevolution = 64;        // steps per revolution
float degreePerRevolution = 5.625;  // degree per revolution
AccelStepper stepper(AccelStepper::HALF4WIRE, motorPin1, motorPin3, motorPin2, motorPin4);
  Serial.begin(9600);               // initialise the serial monitor
  stepper.setMaxSpeed(1000.0);      // set the max motor speed
  stepper.setAcceleration(100.0);   // set the acceleration
  stepper.setSpeed(200);            // set the current speed
  stepper.moveTo(degToSteps(360));   // order the motor to rotate 90 degrees forward
  stepper.run();                    // start moving the motor
 * Converts degrees to steps
 * 28BYJ-48 motor has 5.625 degrees per step
 * 360 degrees / 5.625 = 64 steps per revolution
 * Example with degToSteps(45):
 * (64 / 5.625) * 45 = 512 steps
float degToSteps(float deg) {
  return (stepsPerRevolution / degreePerRevolution) * deg;
#ifdef __AVR__
 #include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
// Which pin on the Arduino is connected to the NeoPixels?
#define PIN        2 // On Trinket or Gemma, suggest changing this to 1
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 33 // Popular NeoPixel ring size
// When setting up the NeoPixel library, we tell it how many pixels,
// and which pin to use to send signals. Note that for older NeoPixel
// strips you might need to change the third parameter -- see the
// strandtest example for more information on possible values.
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
#define DELAYVAL 500 // Time (in milliseconds) to pause between pixels
  // These lines are specifically to support the Adafruit Trinket 5V 16 MHz.
  // Any other board, you can remove this part (but no harm leaving it):
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
  clock_prescale_set(clock_div_1);
#endif
  // END of Trinket-specific code.
  pixels.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
  // The first NeoPixel in a strand is #0, second is 1, all the way up
  // to the count of pixels minus one.
  for(int i=0; i<NUMPIXELS; i++) { // For each pixel...
    // pixels.Color() takes RGB values, from 0,0,0 up to 255,255,255
    // Here we're using a moderately bright green color:
    pixels.setPixelColor(i, pixels.Color(255, 0, 0));
    pixels.show();   // Send the updated pixel colors to the hardware.
    delay(DELAYVAL); // Pause before next pass through loop
Review this:
http://www.thebox.myzen.co.uk/Tutorial/Merging_Code.html
And/Or this:
https://arduinoinfo.mywikis.net/wiki/CombiningArduinoSketches
