I want to write code utilizing an array but I can not find any information regarding it
additionally I am much more comfterable writing in python and am not familiar with may of the methods
is there a .length function to tell me the amount of items in an array
are arrays mutable (can I add and subtract from them)
You could allocate one that is as large as the largest array you want to be able to support and maintain a variable that will tell you how many entries are being used.
otherwise you would have to look at Vectors or other types of containers (not an a UNO and similar)
const byte maxCount = 30;
int dataStorage[maxCount];
byte nextFreeIndex = 0; // represents also the number of elements in the array
then when you have something to record, you store it at the index nextFreeIndex if it exists
if (nextFreeIndex < maxCount) {
dataStorage[nextFreeIndex++] = analogRead(sensorPin); // whatever you want to store
// no more space in the array. deal with that
yes, the ++ increment the value of nextFreeIndex but the expression is evaluated at the current value, so you store at the current location and the nextFreeIndex is incremented for next time (or you can see this value as the count of elements in the array as index starts at 0)
