Can someone know how to change this error because i need to input pointer, so I change to long double, but i got an error
this is the full code
#include<iostream>
using namespace std;
int ary[10][10],completed[10],n,cost=0;
void takeInput()
long double i,j;
cout<<"Enter the number of villages: ";
cin>>n;
cout<<"\nEnter the Cost Matrix\n";
for(i=0;i < n;i++)
cout<<"\nEnter Elements of Row: "<<i+1<<"\n";
for( j=0;j < n;j++)
cin>>ary[i][j];
completed[i]=0;
cout<<"\n\nThe cost list is:";
for( i=0;i < n;i++)
cout<<"\n";
for(j=0;j < n;j++)
cout<<"\t"<<ary[i][j];
long double least(int c)
long double i,nc=999;
long double min=999,kmin;
for(i=0;i < n;i++)
if((ary[c][i]!=0)&&(completed[i]==0))
if(ary[c][i]+ary[i][c] < min)
min=ary[i][0]+ary[c][i];
kmin=ary[c][i];
nc=i;
if(min!=999)
cost+=kmin;
return nc;
void mincost(int city)
int i,ncity;
completed[city]=1;
cout<<city+1<<"--->";
ncity=least(city);
if(ncity==999)
ncity=0;
cout<<ncity+1;
cost+=ary[city][ncity];
return;
mincost(ncity);
int main()
takeInput();
cout<<"\n\nThe Path is:\n";
mincost(0); //passing 0 because starting vertex
cout<<"\n\nMinimum cost is "<<cost;
return 0;
can someone teach me how to use long double in array because i'm new to programming.
I may have missed it, but where is 'n' initialised? I think somewhere there should be n = 10; before 'n' appears anywhere on the RHS.
Edit: Just saw that its beinvg read from stdin..
What Arduino board are you using?
cin >> n;
i do not know. i'm new to Arduino too :sweat_smile: :sweat_smile:
but i think i'm using forum
You have to know in order to upload code, because you have to select an Arduino from the list at that time.
You changed nearly everything to 'long double'. But you cannot use a floating point variable as array index.
Your program is not a typical Arduino programm and will not compile on any board. You have to know which board you will be using.
Looks like the same Traveling Salesman Problem homework as another user posted today. Here is a program that works on an Aruino UNO:
// #include <bits/stdc++.h>
const int N = 10;
const int int_MAX = 0x7FFF;
// final_path[] stores the final solution ie, the
// path of the salesman.
int final_path[N + 1];
// visited[] keeps track of the already visited nodes
// in a particular path
bool visited[N];
// Stores the final minimum weight of shortest tour.
int final_res = int_MAX;
// Function to copy temporary solution to
// the final solution
void copyToFinal(int curr_path[])
  for (int i = 0; i < N; i++)
    final_path[i] = curr_path[i];
  final_path[N] = curr_path[0];
// Function to find the minimum edge cost
// having an end at the vertex i
int firstMin(float adj[N][N], int i)
  int min = int_MAX;
  for (int k = 0; k < N; k++)
    if (adj[i][k] < min && i != k)
      min = adj[i][k];
  return min;
// function to find the second minimum edge cost
int secondMin(float adj[N][N], int i)
  int first = int_MAX;
  int second = int_MAX;
  for (int j = 0; j < N; j++)
    if (i == j)
      continue;
    if (adj[i][j] <= first)
      second = first;
      first = adj[i][j];
    else if (adj[i][j] <= second &&
             adj[i][j] != first)
      second = adj[i][j];
  return second;
// function that takes as arguments:
// curr_bound -> lower bound of the root node
// curr_weight-> stores the weight of the path so far
// level-> current level while moving in the search
//     space tree
// curr_path[ ] -> where the solution is being stored which
//       would later be copied to final_path[ ]
void TSPRec(float adj[N][N], int curr_bound, int curr_weight,
            int level, int curr_path[])
  // base case is when we have reached level N which
  // means we have covered all the nodes once
  if (level == N)
    // check if there is an edge from last vertex in
    // path back to the first vertex
    if (adj[curr_path[level - 1]][curr_path[0]] != 0)
      // curr_res has the total weight of the
      // solution we got
      int curr_res = curr_weight +
                      adj[curr_path[level - 1]][curr_path[0]];
      // Update final result and final path if
      // current result is better.
      if (curr_res < final_res)
        copyToFinal(curr_path);
        final_res = curr_res;
    return;
  // for any other level iterate for all vertices to
  // build the search space tree recursively
    // Consider next vertex if it is not same (diagonal
    // entry in adjacency matrix and not visited
    // already)
    if (adj[curr_path[level - 1]][i] != 0 &&
        visited[i] == false)
      int temp = curr_bound;
      curr_weight += adj[curr_path[level - 1]][i];
      // different computation of curr_bound for
      // level 2 from the other levels
      if (level == 1)
        curr_bound -= ((firstMin(adj, curr_path[level - 1]) +
                        firstMin(adj, i)) / 2);
        curr_bound -= ((secondMin(adj, curr_path[level - 1]) +
      // curr_bound + curr_weight is the actual lower bound
      // for the node that we have arrived on
      // If current lower bound < final_res, we need to explore
      // the node further
      if (curr_bound + curr_weight < final_res)
        curr_path[level] = i;
        visited[i] = true;
        // call TSPRec for the next level
        TSPRec(adj, curr_bound, curr_weight, level + 1,
               curr_path);
      // Else we have to prune the node by resetting
      // all changes to curr_weight and curr_bound
      curr_weight -= adj[curr_path[level - 1]][i];
      curr_bound = temp;
      // Also reset the visited array
      memset(visited, false, sizeof(visited));
      for (int j = 0; j <= level - 1; j++)
        visited[curr_path[j]] = true;
// This function sets up final_path[]
void TSP(float adj[N][N])
  int curr_path[N + 1];
  // Calculate initial lower bound for the root node
  // using the formula 1/2 * (sum of first min +
  // second min) for all edges.
  // Also initialize the curr_path and visited array
  int curr_bound = 0;
  memset(curr_path, -1l, sizeof(curr_path));
  memset(visited, 0, sizeof(visited));
  // Compute initial bound
    curr_bound += (firstMin(adj, i) +
                   secondMin(adj, i));
  // Rounding off the lower bound to an integer
  curr_bound = (curr_bound & 1) ? curr_bound / 2 + 1 :
               curr_bound / 2;
  // We start at vertex 1 so the first vertex
  // in curr_path[] is 0
  visited[0] = true;
  curr_path[0] = 0;
  // Call to TSPRec for curr_weight equal to
  // 0 and level 1
  TSPRec(adj, curr_bound, 0, 1, curr_path);
// Driver code
  delay(200);
  Serial.println("Starting setup()");
  //Adjacency matrix for the given graph
  float adj[N][N] =
    {   0, 5.1, 12.5, 13.0,  7.5, 13.5,    0,    0, 24.1,    0},
    { 5.1,   0,  7.2,  9.2,    0,    0,    0,    0,    0,    0},
    {12.5, 7.2,    0,  8.0,    0,    0,    0, 21.5,    0, 33.2},
    {13.0, 9.2,  8.0,    0,  8.5,    0, 15.5, 14.1,    0,    0},
    { 7.5,   0,    0,  8.5,    0, 11.5, 10.5, 17.3,    0,    0},
    {13.5,   0,    0,    0, 11.5,    0, 11.2,    0, 11.1,    0},
    {   0,   0,    0, 15.5, 10.5, 11.2,    0,  8.9, 13.8, 12.7},
    {   0,   0, 21.5, 14.1, 17.3,    0,  8.9,    0,    0,  8.5},
    {24.1,   0,    0,    0,    0, 11.1, 13.8,    0,    0, 12.1},
    {   0,   0, 33.2,    0,    0,    0, 12.7,  8.5, 12.1,    0}
  Serial.println("Calling TSP()");
  Serial.flush();
  unsigned int startTime = micros();
  TSP(adj);
  unsigned int endTime = micros();
  Serial.print("Returned from TSP()  Execution time in microseconds:");
  Serial.println(endTime - startTime);
  Serial.flush();
  Serial.print("Minimum cost: ");
  Serial.println(final_res);
  Serial.flush();
  Serial.print("Path Taken : ");
    Serial.print(final_path[i]);
    Serial.print(' ');
  Serial.flush();
void loop() {}
