Can someone take a look at this? My first "If" statement
Whatsup. New on Arduino. Im trying to write a sketch that reads the distance from the ultrasonic sensor and turns on an led depending on the distance.... I get this issue...
IfTestCode:21:1: error: expected unqualified-id before 'if'
if (Distance >= 70) {
IfTestCode:26:1: error: expected unqualified-id before 'else'
else {
exit status 1
Here is my code.....
const int Ledpin = 8;
#include "SR04.h"
#define TRIG_PIN 12
#define ECHO_PIN 11
SR04 sr04 = SR04(ECHO_PIN,TRIG_PIN);
long a;
pinMode(Ledpin, OUTPUT);
a=sr04.Distance();
Serial.print(a);
Serial.println("cm");
digitalWrite(LedPin, HIGH);
else {
digitalWrite(LedPin, LOW);
Move the } to the end of your code.
And also change (Distance >= 70) to either (a >= 70), or (sr04.Distance() >= 70)
Distance by itself has not been
  • Been declared anywhere in your code
  • Been assigned a value anywhere in your code
larryd:
Thank you for responding so fast Larry! Would It be possible for you to show me what you mean? I tried what you suggested with no avail. Thanks a bunch!
Show us what you changed.
larryd:
#include "SR04.h"
#define TRIG_PIN 12
#define ECHO_PIN 11
long a;
a=sr04.Distance();
Serial.print(a);
if (a >= 70) {
else {
The error I receive now is that its not recognizing the second half of the code. Here it is
In function 'void loop()':
IfTestCode:22:16: error: 'LedPin' was not declared in this scope
IfTestCode:26:16: error: 'LedPin' was not declared in this scope
exit status 1
C/C++ is case sensitive. You declared Ledpin and later use LedPin; not the same.
And, from what I can see, you're missing a final closing brace.
The last two lines of your code should be
#include "SR04.h"
#define TRIG_PIN 12
#define ECHO_PIN 11
long a;
   a = sr04.Distance();
   Serial.print(a);
if (a >= 70)
  digitalWrite(Ledpin, HIGH);
  digitalWrite(Ledpin, LOW);
Awesome. Thank you all! What an amazing community. Looking forward to sticking around here!
Also:
Use CTRL T to format the sketch.
Please use code tags.
Use the </> icon in the posting menu.
[code] Paste sketch here. [/code]
larryd:
Also:
Thanks! Will do
