can someone tell me what is the diffrence between this 2 relays?
http://www.aliexpress.com/item/2-5V-30A-1-Channel-Relay-Module-Optocoupler-H-L-Level-Triger-in-selling/32342340182.html - using SLA-05VDC-sl-c
http://www.aliexpress.com/item/1PCS-30A-250V-Relay-Module-High-side-Driver-SLA-05VDC-SL-A-FZ0885/32454140486.html - using SLA-05VDC-sl-a
There are obviously many differences, but one has an optocoupler.
I really thought that the main difference is the relay itself, SLA-05VDC-sl-c vs SLA-05VDC-sl-a.
I looked at the data sheet but I still didn't get, (I'm sorry that I didn't mention it but I'm a noob :o ).
So what is the difference between also the relay, and what would you recommend more.
What do you want the relay to do? What are the other constraints on your project?
Basically I want to do the following: ESP8266 - Flash NodeMCU, write lua script, and control a water heater
But in my way.
anyone?
