Can someone tell me why Serial.print always send an one and dont count???
pinMode(behaelter1_rum, OUTPUT); // Festlegen der Pins als In - oder Output
pinMode(behaelter2_wodka, OUTPUT);
pinMode(behaelter3_tequila, OUTPUT);
pinMode(behaelter4_whiskey, OUTPUT);
pinMode(behaelter5_pfirsichlikoer, OUTPUT);
pinMode(behaelter6_batida, OUTPUT);
pinMode(behaelter7_osaft, OUTPUT);
pinMode(behaelter8_anasaft, OUTPUT);
pinMode(behaelter9_cransaft, OUTPUT);
pinMode(behaelter10_grenasaft, OUTPUT);
pinMode(behaelter11_marasaft, OUTPUT);
pinMode(behaelter12_cocossirup, OUTPUT);
pinMode(behaelter13_grenasirup, OUTPUT);
pinMode(behaelter14_cola, OUTPUT);
pinMode(behaelter15_milch, OUTPUT);
pinMode(ok, OUTPUT);
void gewicht()
gewicht_out = analogRead(gewicht_in);
int i = 0;
int sicherheit = 1;
int auswahl = 1;
int glas = 1;
int druck = 1;
int tuer = 1;
Serial.println(gewicht_out);
//Serial.println(sicherheit); // Ausgabe Analogwert
//delay(500); // Wartezeit
if(tuer >= 0 && druck >= 0 && glas >= 0)
sicherheit = 1;
digitalWrite(ok, HIGH);
Serial.println(“gewicht_out”); // Ausgabe Analogwert
delay(4000);
if(auswahl == 1 && sicherheit == 1)
if(screwdriver > 0)
  • do*
    _ digitalWrite(ventile*,HIGH);_
    _
    Serial.println(“pimmel”);_
    _
    delay(500);_
    }while(gewicht_out <= screwdriver);*
_ digitalWrite(ventile*,LOW);
++i;
Serial.println(i);
else*
++i;
Serial.println(i);
delay(3000);
if(i == 15)
i = 0;
auswahl = 0;
screwdriver[0] = ‘/0’;
}*_
You haven't even declared a variable called gewicht_out, so you can't assign a value to it or print it.
Does your code REALLY look like that?
Please use code tags.
Read this before posting a programming question
  1. Use code tags.
  2. Post ALL your code.
  3. In code tags.
  4. C escapes use a backslash () not a forward slash (/)
