Can’t compile code for ATtiny85, using Servo and QTR libraries
Hello.
Im having trouble compiling code for my ATtiny85,
I think it’s because of the libraries Im using aren’t compatible with the ATtiny85.
Does anyone know how to solve this problem or any other microcontroller I could use with this code.
#include <QTRSensors.h>
#include <Servo.h>
Servo Servo1;
Servo Servo2;
int MAX1;
int MAX2;
int MIN1;
int MIN2;
int button = 1;
int position1;
int position2;
QTRSensors qtr1;
QTRSensors qtr2;
const uint8_t SensorCount1 = 1;
uint16_t sensorValues1[SensorCount1];
const uint8_t SensorCount2 = 1;
uint16_t sensorValues2[SensorCount2];
  MAX1 = 160;
  MAX2 = 130;
  MIN1 = 100;
  MIN2 = 130;
  digitalWrite(button, INPUT);
  Servo1.attach(9);        //Setting Servo 1 to the ninth pin
  Servo2.attach(5);        //Setting Servo 2 to the fith pin
  qtr1.setTypeAnalog();        // configure the sensors 1 to A0
  qtr1.setSensorPins((const uint8_t[]){A0}, SensorCount1);
  qtr1.setEmitterPin(2);
  qtr2.setTypeAnalog();
  qtr2.setSensorPins((const uint8_t[]){A1}, SensorCount2);
  qtr2.setEmitterPin(2);
  Servo1.write(MAX1);
  Servo2.write(MIN2);
  Servo1.write(MIN1);
  Servo2.write(MAX2);
  Servo1.write(MAX1);
  Servo2.write(MIN2);
  delay(100);
  for (uint16_t i = 0; i < 400; i++)
    qtr1.calibrate();
  for (uint8_t i = 0; i < SensorCount1; i++)
    qtr2.calibrate();
    for (uint8_t i = 0; i < SensorCount2; i++)
  delay(100);
  // read raw sensor values
  qtr1.read(sensorValues1);                                     // print the sensor values as numbers from 0 to 1023, where 0 means maximum
                // reflectance and 1023 means minimum reflectance
  qtr2.read(sensorValues2);
  if( button == HIGH) {
  Servo1.write(MAX1);
  Servo2.write(MIN2);
  Servo1.write(MIN1);
  Servo2.write(MAX2);
  Servo1.write(MAX1);
  Servo2.write(MIN2);
  delay(100);
    qtr1.calibrate();
    qtr2.calibrate();
  delay(100);
    position1 = map(sensorValues1[i], qtr1.calibrationOn.minimum[i], qtr1.calibrationOn.maximum[i], 130, 160);
    position1 = min(position1, MAX1);
    position1 = max(MIN1, position1);
    position2 = map(sensorValues2[i], qtr2.calibrationOn.minimum[i], qtr2.calibrationOn.maximum[i], 130, 100);
    position2 = min(position2, MAX2);
    position2 = max(MIN2, position2);
  delay(150);
  Servo1.write(position1);
  delay(150);
  Servo2.write(position2);
  delay(250);
Error
/Users/harry/Documents/Arduino/libraries/Servo/src/avr/Servo.cpp: In function 'void __vector_3()':
/Users/harry/Documents/Arduino/libraries/Servo/src/avr/Servo.cpp:82:44: error: cannot convert 'volatile uint8_t* {aka volatile unsigned char*}' to 'volatile uint16_t* {aka volatile unsigned int*}' for argument '2' to 'void handle_interrupts(timer16_Sequence_t, volatile uint16_t*, volatile uint16_t*)'
handle_interrupts(_timer1, &TCNT1, &OCR1A);
/Users/harry/Documents/Arduino/libraries/Servo/src/avr/Servo.cpp: In function 'void initISR(timer16_Sequence_t)':
/Users/harry/Documents/Arduino/libraries/Servo/src/avr/Servo.cpp:129:5: error: 'TCCR1B' was not declared in this scope
TCCR1B = _BV(CS11); // set prescaler of 8
/Users/harry/Documents/Arduino/libraries/Servo/src/avr/Servo.cpp:129:5: note: suggested alternative: 'TCCR0B'
TCCR0B
/Users/harry/Documents/Arduino/libraries/Servo/src/avr/Servo.cpp:136:5: error: 'TIFR1' was not declared in this scope
TIFR1 |= _BV(OCF1A); // clear any pending interrupts
/Users/harry/Documents/Arduino/libraries/Servo/src/avr/Servo.cpp:136:5: note: suggested alternative: 'TIFR'
TIFR
/Users/harry/Documents/Arduino/libraries/Servo/src/avr/Servo.cpp:137:5: error: 'TIMSK1' was not declared in this scope
TIMSK1 |= _BV(OCIE1A) ; // enable the output compare interrupt
/Users/harry/Documents/Arduino/libraries/Servo/src/avr/Servo.cpp:137:5: note: suggested alternative: 'TIMSK'
TIMSK
Multiple libraries were found for "Servo.h"
Used: /Users/harry/Documents/Arduino/libraries/Servo
Not used: /Applications/Arduino.app/Contents/Java/libraries/Servo
exit status 1
Error compiling for board ATtiny25/45/85.
Link for QTR-1A libary [QTR-1A libary](https://github.com/pololu/qtr-sensors-arduino)
Solved it.
It was because of the servo library, it’s not compatible with the ATtiny85.
Instead I used Servo8Bit library GitHub - fri000/Servo8Bit: Servo library for the ATtiny45 and the ATtiny85, which is compatible.
Now my sketch is too big, so I have to find a way to condense it.
