Hi Guys,
I have a problem with my galvos. I can only send small values for my x and y coordinates. For my understanding of the program I use, I can use values from 0 to 65536 for each galvo. I use this repo
When I use values like 100 everything seems to work. But if I use bigger values like 15000 both axes are manipulated in a random way. So I guess something must be wrong with the values. I ripped down the program to the basic things. I already tried to send int, long, unsigned char but I don´t see any difference.
My main program:
#include "Laser.h"
int serDataIO = 0;
// Create laser instance (with laser pointer connected to digital pin 5)
Laser laser(5);
laser.init();
void Serial_Obj()
long serDataX = 0x07ff;
long serDataY = 0x0123;
long translateX = 0;
long translateY = 0;
//Initialize laser
laser.setScale(2);
laser.setOffset(0,0);
laser.on();
laser.sendto(serDataX, serDataY);
Serial_Obj();
The laser header:
// See LICENSE file for details
// Copyright 2016 Florian Link (at) gmx.de
#ifndef LASER_H
#define LASER_H
#include "Arduino.h"
#include "Basics.h"
// -- The following flags can be used to fine tune the laser timing
// defines the granularity of the line interpolation. 64 means that each line is split into steps of 64 pixels in the longer direction.
// setting smaller values will slow down the rendering but will cause more linearity in the galvo movement,
// setting bigger values will cause faster rendering, but lines will not be straight anymore.
#define LASER_QUALITY 64
// Defines how long the galvos wait for the on/off toggling of the laser pointer (in microseconds), this will depend on your laser pointer.
#define LASER_TOGGLE_DELAY 500
// Defines how long the galvos wait at the end of a line (currently only used for the 3D cube rendering, in microseconds).
#define LASER_LINE_END_DELAY 200
// Defines the delay the laser waits after reaching a given position (in microseconds).
#define LASER_END_DELAY 5
// Defines the delay after each laser movement (used when interpolating lines, in microseconds), if not defines, 0 is used
//#define LASER_MOVE_DELAY 5
// -- The following flags can be used to rotate/flip the output without changing the DAC wiring, just uncomment the desired swap/flip
// define this to swap X and Y on the DAC
#define LASER_SWAP_XY
// define this to flip along the x axis
#define LASER_FLIP_X
// define this to flip along the y axis
#define LASER_FLIP_Y
//! Encapsulates the laser movement and on/off state.
class Laser
public:
//! The laser is initialized with the laserPin,
//! which selects the digital pin that turns the laser pointer on/off.
Laser(int laserPin);
void init();
//! send the laser to the given position, scaled and translated and line clipped.
void sendto(long x, long y);
//! sends the laser to the raw position (the movement is always linearly interpolated depending on the quality,
//! to avoid too fast movements.
void sendtoRaw(long x, long y);
//! draws a line by turning the laser off, going to x1,y1, turning it on and going to x2,y2.
void drawline(long x1, long y1, long x2, long y2);
void wait(long length);
void on();
void off();
void setScale(float scale);
void setOffset(long offsetX, long offsetY);
void resetClipArea();
void setClipArea(long x, long y, long x1, long y1);
void resetMaxMove() { _maxMove = -1; _laserForceOff = false; }
void setMaxMove(long length) { _moved = 0; _maxMove = length; _laserForceOff = false; }
bool maxMoveReached() { return _laserForceOff; }
void getMaxMoveFinalPosition(long &x, long &y) { x = _maxMoveX; y = _maxMoveY; }
void setEnable3D(bool flag) { _enable3D = flag; }
void setMatrix(const Matrix3& matrix) { _matrix = matrix; }
void setZDist(long dist) { _zDist = dist; }
private:
//! send X/Y to DAC
void sendToDAC(int x, int y);
//! computes the out code for line clipping
int computeOutCode(long x, long y);
//! returns if the line should be drawn, clips line to clip area
bool clipLine(long& x0, long& y0, long& x1, long& y1);
int _laserPin;
FIXPT _quality;
long _x;
long _y;
int _state;
FIXPT _scale;
long _offsetX;
long _offsetY;
long _moved;
long _maxMove;
bool _laserForceOff;
long _maxMoveX;
long _maxMoveY;
long _oldX;
long _oldY;
long _clipXMin;
long _clipYMin;
long _clipXMax;
long _clipYMax;
bool _enable3D;
Matrix3 _matrix;
long _zDist;
#endif
I really hope you can help me. Thanks!
