Excuse me if this is an obvious question, but I couldn't find the answer.
When using the 2.3.2 IDE's serial monitor with test code that outputs "OK, AT, OK, 0" every 30 seconds, is there a limit or maximum number of bytes that will display before the serial monitor stops? Or is it open-ended and this data is not occupying memory/buffer?
I want to leave this open and running for days for diagnostics.
