Can the Atmega32U4 be a USB host?
Hello,
I'm working on an android/arduino project. Since android USB host isn't supported before Android version 3.1, I need the arduino to act as a USB host.
I know that there is a USB host shield, although I don't understand how it functions and frankly has too many components for me to break it down and put it on my project.
So is there some way that the Atmega32U4 can be used as a host? I mean it already has onboard USB support, I don't think it would be too much of a stretch to make it work.
The 32U4 doesn't have host capability. You would need either a chip that does, or a seperate USB host IC.
You need to use bluetooth.
http://www.amarino-toolkit.net/index.php/plug-in.html
TCWORLD:
Do you have any IC's that you would recommend? Ones that could be easily used with the 32U4?
cyclegadget:
As much as I would love to, I need to use the power to also power my project, so I might as well just have the data sent through the usb as well. And as I understand it, bluetooth dealios are usually larger than a usb host chip
This maybe of no help but, maybe can figure out what they are doing on this board. http://arduino.cc/en/Main/ArduinoBoardADK
I've checked that out, It includes the MAX3421E. I could reverse engineer it I guess to see how it interfaces with the mega2560 although I still wouldn't have the code. I'm sure I could find some, although the MAX3421E seems to need a good amount of external components such as a crystal and I simply don't have the board space for it.
funkyguy4000:
I would call a crystal and a couple of caps a pretty minimal implementation for a Host controller. Some of the other components are for if you need the Host to provide power to the device. Depending on what you need to do in your application, I doubt you'll find a more minimal setup.
Keep in mind that USB isn't a simple protocol. Depending on what you plan to connect to the USB-Host, you'll have to write your own drivers and can be a tall order. The Uno / Leonardo's relatively small amount RAM is another challenge. (The Mega's 8K is a little easier.)
USB host processing and USB device processing are MUCH different. You're not going to see anything significantly simpler than the MAX3421 circuitry (significantly expensive chip + crystal + etc.)
Holy crap that chip is expensive!
Looks like i'll have to get 100 of them to get a decent price break.
Is there a library for the MAX3421E?
Looking at the datasheet, I don't understand it.
Google: max3421e arduino library
Oh wow, I thought I did. Haha guess not.
Thanks!
