Can the if--else if -- else inside while work?
#include <SPI.h>
// set pin 53 as the slave select for the digital pot:
const int slaveSelectPin = 53; //WAS 10 on Arduino uno.
const int shutdownPin = 7; // was 7 on uno.
const int wiper0writeAddr = B00000000;
const int wiper1writeAddr = B00010000;
const int tconwriteAddr = B01000000;
const int tcon_0off_1on = B11110000;
const int tcon_0on_1off = B00001111;
const int tcon_0off_1off = B00000000;
const int tcon_0on_1on = B11111111;
const int analogInPin_c = A5;  // center Vc=Vss/2 from the PAD, use for set ini V. here no use, Vc directly goes to pad.
const int analogInPin_x = A1;  // Analog input pin that the potentiometer is attached to
const int analogInPin_y = A2;  // Analog input pin that the potentiometer is attached to
const int analogOutPin_x = wiper0writeAddr; // write MCP POT
const int analogOutPin_y = wiper1writeAddr; // write MCP POT
int sensorValue_c = 0;        // value read from the PAD, Vc=Vss/2
int sensorValue_x = 0;        // value read from the PAD, Vc=Vss/2
int sensorValue_y = 0;        // value read from the PAD, Vc=Vss/2
//?int outputValue_c = 0;        // value output to the PWM (analog out)
int outputValue_x = 0;        // mid variable stored the value from 'sensorValue_c' and MAP that for use
int outputValue_y = 0;        // mid variable stored the value from 'sensorValue_c' and MAP that for use
int Vcr = 0;        // value read from the PAD, Vc=Vss/2
int Vc = 0;        // value read from the PAD, Vc=Vss/2
const int LEDpin1 = 47;
const int LEDpin2 = 46;
int count = 0;
  // set the slaveSelectPin as an output:
  pinMode (slaveSelectPin, OUTPUT);
  // set the shutdownPin as an output:
  pinMode (shutdownPin, OUTPUT);
  // start with all the pots shutdown
  digitalWrite(shutdownPin, LOW);
  // initialize SPI:
  SPI.begin();
  Serial.println("Setup complete");
  Serial.println("Starting loop");
  digitalWrite(shutdownPin, HIGH); //Turn off shutdown
  AnalogInOut(); //
  ArduinoDAC(); //
void AnalogInOut() {
  // take from some where used for testing joystick control LED,
  //need change to get date fron RC and write to MCP pots
  // read the analog in value:
  Vcr = analogRead(analogInPin_c);
  Serial.print("Vcr= ");
  Serial.println(Vcr);
  Vc = map(Vcr, 0, 1023, 165, 225);
  Serial.print("Vc = ");
  Serial.println(Vc);
  delay(10);
  Serial.print("count_ini= ");
  Serial.println(count);
  /////if (count = 0)
  while (count = 0)
    if (Vc > 188)
      digitalWrite(LEDpin1, HIGH);
      Serial.print("Vc TOO HIGH: ");
      Serial.println(Vc);
      exit(0);
      delay(10);
    else if (Vc < 165) {
      digitalWrite(LEDpin2, HIGH);
      Serial.print("Vc TOO LOW = : ");
      Serial.println(Vc);
      exit(0);
      delay(10);
    else {
      Serial.print("analogInPin_c_T00: ");
      Serial.println(analogInPin_c);
      /// digitalPotWrite(wiper0writeAddr, Vc);
      ///digitalPotWrite(wiper1writeAddr, Vc);
      digitalPotWrite(wiper0writeAddr, 100);
      digitalPotWrite(wiper1writeAddr, 220);
      count = 1;
      Serial.print("count_new= ");
    delay(15000);
  sensorValue_x = analogRead(analogInPin_x);
  sensorValue_y = analogRead(analogInPin_y);
  // map it to the range of the analog out:
  outputValue_x = map(sensorValue_x, 0, 1023, 70, 248);
  outputValue_y = map(sensorValue_y, 0, 1023, 70, 248);  // change the analog received to the value suite for PAD joystick
  //   print the results to the Serial Monitor:
  Serial.println("sensor_x =_T10 ");
  Serial.println(sensorValue_x);
  Serial.println("sensor_y = ");
  Serial.println(sensorValue_y);
  Serial.println("\t output = ");
  Serial.println(outputValue_x);
  Serial.println(outputValue_y);
  // wait 2 milliseconds before the next loop for the analog-to-digital
  // converter to settle after the last reading:
  delay(2);
void ArduinoDAC() {
  digitalPotWrite(wiper0writeAddr, outputValue_x); // Set wiper 0 to 200
  delay(5);
  digitalPotWrite(wiper1writeAddr, outputValue_y); // Set wiper 1 to 200
  delay(5);
// This function takes care of sending SPI data to the pot.
void digitalPotWrite(int address, int value) {
  /// Serial.print("wiper0 position_t30: ");////
  /// Serial.println();////
  // take the SS pin low to select the chip:
  digitalWrite(slaveSelectPin, LOW);
  //  send in the address and value via SPI:
  SPI.transfer(address);
  SPI.transfer(value);
  delay(30);
  // take the SS pin high to de-select the chip:
int digitalPotRead(int address) {
  //  send in the address via SPI:
  // send zero to read data from the address
  delay(30);
Yes
GrOnThOs:
Yes
Thank you GrOnThOs,
The code is too mess to be attached.
shortly as:
while ()
if (){
else if () {
else () {
delay(5000);
The [delay(5000);] doesn't work, I mean the sketch didn't execute this line.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html . Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Post the full code please?
What do you want your code to do?
Why are you using while()?
Thanks.. Tom.. :slight_smile:
else {
not
else () {
.  while (count = 0)
    if (Vc > 188)
      Serial.println(Vc);
      exit(0);
      delay(10);
  1. "count = 0" should be "count == 0".
  2. Why do you use exit(0) here?
GrOnThOs:
else {
not
else () {
Thank you GrOnThOs, actually there wasn't a '()' in my original code as attached. Sorry the mistake by short.
still the [delay 5000 ] didn't executed no matter put where:
else {
delay(5000);
// or
delay(5000);
Blackfin:
.  while (count = 0)
    if (Vc > 188)
      Serial.println(Vc);
      exit(0);
      delay(10);
1) "count = 0" should be "count == 0".
2) Why do you use exit(0) here?
Thank you Blackfin.
  1. the purpose to use "count == 0" is let the code just do ONE time this if section, no need loop here, there should be some other solution.
    I put "count == 0", there is error came: expected initializer before '==' token.
  2. exit(0) because if the date value is not match, I need to do some repair.
if(count == 0)?
What is your code supposed to do?
What is your code doing?
What is the application?
What model Arduino are you using?
Try "while (count >= 0)" and change "count = 1;" to "count ++;"
Thank you for reply, I just post the code, questions are:
  1. the 'while - if' section doesn't run, I put a 'delay 5000', never wait;
  2. the 'count' work as a mark, let the 'while - if' section running just once, is this OK?
  3. If I put the 'while - if' section inside the void setup, any solution to 'the digitalPotWrite didn't declared in this scope' ?
