Can the SD card Shield use in the way describe below
Hello All,
I have bought the SD Card Shield V4 with a memory card and it works very well. Please see the card in the link below.
http://www.seeedstudio.com/depot/SD-Card-Shield-V4-p-1381.html
I have a question regarding the Grove interface above the card (SDA, SCL, 5V, GND) and the (RX,TX, 5V, GND).
  1. Could please tell me where can I buy the cable connector that will be suitable for those two interfaces?
  2. Can I read the data written in the SD card memory using the (SDA, SCL, 5V, GND) interface with another Arduino board than the one use to write in the SD card memory?
If Yes does anybody has an example code?
Many Thanks
Cserge
  1. Anywhere. Use any connector you like. I use a lot of AMPMODU MTE connectors (also known as dupont connectors) but they may not be suitable for your application.
  2. Do you mean at the same time? No. You can't have two Arduinos talking to one SD card. If you have some way to synchronise them and prevent one from talking while the other is using the card, then it's possible.
MorganS,
Thank you enormously for your feed back.
Cserge
