Can there be a correlation between Emonlib current increase and RTC unsync?
I'm having this weird issue where my data Send interval gets screwed up when the monitored current goes above 27A. Basically, it keeps adding several seconds to my interval, here's an example:
Database:
Current | Time
16A | 10:00:30
16A | 10:10:30
16A | 10:20:30
16A | 12:00:30
27A | 12:10:35
27A | 12:20:40
27A | 12:30:45
27A | 13:21:05
16A | 13:31:10
16A | 13:41:10
The arduino I'm using is an MKR 1300 with RTC integrated. And here's the code for visibility: Also, by the way, the RTC library is RTCZero and the library to read current is EmonLib.
    /* INITIAL_TIME */
    const byte seconds = 0;
    const byte minutes = 0;
    const byte hours = 0;
    const byte day = 17;
    const byte month = 12;
    const byte year = 18;
    byte second_alarm = 0;
    byte minute_alarm = 0;
    byte hour_alarm = 0;
    int SEND_LOOP = 10; //5
    float totalKW;
    int time_running = 0;
    int alarm_Triggered = 0;
    int correction_var = 0;
    long seq_value = 0;
      LoRa Network agreement code (removed)
      analogReadResolution(9);
      emon1.current(1, 90.5);
      emon2.current(2, 90.3);
      emon3.current(3, 90.3);
      time_running = 0;
      rtc.begin(); // initialize RTC
      rtc.setAlarmTime(hour_alarm, minute_alarm, second_alarm);
      rtc.enableAlarm(rtc.MATCH_HHMMSS);
      rtc.attachInterrupt(triggerAlarm);
      // Set the time
      rtc.setHours(hours);
      rtc.setMinutes(minutes);
      rtc.setSeconds(seconds);
      // Set the date
      rtc.setDay(day);
      rtc.setMonth(month);
      rtc.setYear(year);
      if (alarm_Triggered == 1) {
        dataMonitor();
    void dataMonitor() {
      float totalWatt = 0;
      float Irms1 = emon1.calcIrms(600);
      if (Irms1 < 0.3) Irms1 = 0;
      float Watt1 = Irms1 * 230;
      float Irms2 = emon2.calcIrms(600);
      if (Irms2 < 0.3) Irms2 = 0;
      float Watt2 = Irms2 * 230;
      float Irms3 = emon3.calcIrms(600);
      if (Irms3 < 0.3) Irms3 = 0;
      float Watt3 = Irms3 * 230;
      totalWatt = Watt1 + Watt2 + Watt3;
      totalKW = totalKW + totalWatt / 1000;
      sendDataChecker();
      setAlarm();
      time_running = time_running + 1;
    void sendDataChecker() {
      if (time_running >= SEND_LOOP) {
        String msg = String(seq_value)+";"+String(totalKW);
        int err;
        modem.beginPacket();
        modem.print(msg);
        err = modem.endPacket(true);
        if (err > 0) {
          //message sent correctly
          time_running = 0;
          totalKW = 0;
          seq_value++;
          Serial.println("ERR");
          time_running = 0;
        if (!modem.available()) {
          //Now downlink message
          return;
          char rcv[64] {};
          int i = 0;
          while (i < 64 && modem.available()) {
            rcv[i++] = (char)modem.read();
          String data_received = rcv;
          if (data_received == "") {
            Serial.println("Null");
            //JsonObject& root = jsonBuffer.parseObject(data_received);
            correction_var = data_received.toInt();
    void setAlarm() {
      int INTERVAL = 60; //60
      second_alarm += INTERVAL;
      minute_alarm += second_alarm / 60;
      second_alarm %= 60;
      hour_alarm += minute_alarm / 60;
      minute_alarm %= 60;
      hour_alarm %= 24;
      correct();
    void correct() {
      if (correction_var == 0) {
        return;
      if (correction_var == 1) {
        rtc.setSeconds(rtc.getSeconds() + 1);
        correction_var = 0;
        return;
      if (correction_var == -1) {
        if ((rtc.getSeconds() - 1) < 1) {
          rtc.setSeconds(0);
          correction_var = 0;
          return;
          rtc.setSeconds(rtc.getSeconds() - 1);
          correction_var = 0;
          return;
      correction_var = 0;
      return;
    void triggerAlarm() {
      alarm_Triggered = 1;
Code doesn't compile for me.
I've seen that there is a modem mentioned. Given that the data is transferred wirelessly somehow, it might be that the device that is consuming 27A is interfering with the wireless signal.
