Can this be condensed
Hello,
I'm using a MOVI Shield to create my own A.I and I need it control a neopixel ring. I have combined the two codes together (the MOVI code and the Neopixel code) to allow the MOVI shield to turn the neopixel light on/off when sentences //1 and //2 are triggered. I verified the code but when I upload it I get no response form my MOVI shield. I believe this is a coding problem because when I take the Neopixel code out and upload it, it will reposnd back to me. I'm wondering if this code can be condensed and maybe that may fix the problem? I don't know. Below I have included both codes; with the neopixel and without the neopixel.
(This code is running on an Arduino Uno by the way)
Thanks in advance.
#include "MOVIShield.h"
#if defined(ARDUINO_ARCH_AVR) || defined(ARDUINO_ARCH_PIC32)
#include <SoftwareSerial.h> // This is nice and flexible but only supported on AVR and PIC32 architecture, other boards need to use Serial1
#endif
#include <Servo.h>
#include <LiquidCrystal.h>
//Eye
#ifdef __AVR__
  #include <avr/power.h>
#endif
#define PIN 6
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
//The positive wire of the Neopixel ring goes to pin 5. This will allow the A.I to toggle it on/off when we give the command.
int eyeledpositive=5;
MOVI recognizer (true);  //Get a MOVI object, true enables serial monitor interface, rx and tx for alternate communication pins on AVR architecture boards
  recognizer.init();
  recognizer.callSign(F("Baxter")); //Train callsign (may take 20 seconds)
  recognizer.addSentence(F("Turn on")); //1
  recognizer.addSentence(F("Go to Sleep")); //2
  recognizer.addSentence(F("Run system check")); //3
  recognizer.addSentence(F("Goodbye")); //4
  recognizer.addSentence(F("Are you a robot")); //5
  recognizer.train();
//Eye
  //Define LED pin as outputs
  pinMode(eyeledpositive, OUTPUT);
 #if defined (__AVR_ATtiny85__)
    if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
  #endif
  strip.begin();
  strip.setBrightness(50);
  strip.show(); // Initialize all pixels to 'off'
  int res = recognizer.poll();
//These are the answers and executable programs for the commands of the A.I
  if (res == 1) {
    recognizer.say("Hello commander. How may I be of service?");
     digitalWrite(eyeledpositive, HIGH); //Turns on Eye LED (Neopixel Ring)
        recognizer.ask();
  if (res == 2) {
    recognizer.say("Goodnight commander");
    digitalWrite(eyeledpositive, LOW); //Turns off Eye LED (Neopixel Ring)
  if (res == 3) {
    recognizer.say("Systems operating at full capacity");
  if (res ==4) {
    recognizer.say("Goodbye");
  if (res ==5) {
    recognizer.say("Pish posh");
//Eye
    // Some example procedures showing how to display to the pixels:
  colorWipe(strip.Color(255, 0, 0), 50); // Red
  colorWipe(strip.Color(0, 255, 0), 50); // Green
  colorWipe(strip.Color(0, 0, 255), 50); // Blue
//colorWipe(strip.Color(0, 0, 0, 255), 50); // White RGBW
  // Send a theater pixel chase in...
  theaterChase(strip.Color(127, 127, 127), 50); // White
  theaterChase(strip.Color(127, 0, 0), 50); // Red
  theaterChase(strip.Color(0, 0, 127), 50); // Blue
// These are functions ("mini Programs") that we are caling.
// They are defined in section d_LED_Eye_Functions.
  rainbow(20);
  rainbowCycle(20);
  theaterChaseRainbow(50);
//These are the functions that the Eye calls.
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (uint16_t i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, c);    //turn every third pixel on
      strip.show();
      delay(wait);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
        strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
      strip.show();
      delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
This code repsonds/works
#include <Servo.h>
#include "MOVIShield.h" // Include MOVI library, needs to be *before* the next #include
#endif
MOVI recognizer(true); // Get a MOVI object, true enables serial monitor interface, rx and tx can be passed as parameters for alternate communication pins on AVR architecture
  recognizer.init(); // Initialize MOVI (waits for it to boot)
  // Note: training can only be performed in setup().
  // The training functions are "lazy" and only do something if there are changes.
  // They can be commented out to save memory and startup time once training has been performed.
  recognizer.callSign("Baxter"); // Train callsign Arduino (may take 20 seconds)
  recognizer.train();                           // Train (may take 20seconds)
  //  recognizer.setThreshold(5);      // uncomment and set to a higher value (valid range 2-95) if you have a problems due to a noisy environment.
void loop() // run over and over
  signed int res=recognizer.poll(); // Get result from MOVI, 0 denotes nothing happened, negative values denote events (see docs)
 if (res == 1) {
        recognizer.ask();
  if (res == 2) {
  if (res == 3) {
  if (res ==4) {
  if (res ==5) {
The neopixel-code has a lot of delays
The function delay() does what its name says. Delay execution of any other commands.
So this means if your code executes a delay the microcontroller is unable to execute something else.
I don't know anything how the MOVI-shield works. Depending on how much "own" "intelligence" the MOVI-shield has
it might be that the delay - delays the shield.
To avoid this situation you need to re-write the code that it is using timing based on the function millis()
As a first attempt I would look up if somebody has written such a code. Maybe even Adafruit themselves.
best regards Stefan
Thanks.
I will try that.
StefanL38:
See Overview | Multi-tasking the Arduino - Part 3 | Adafruit Learning System
How would I take out the buttons and have each light effect go on automatically (one after the other) on a constant loop?
(Instead of using the button to switch the modes I want it to do it automatically). How would that be done?
Thanks
(First half of the code)
// Pattern types supported:
enum  pattern { NONE, RAINBOW_CYCLE, THEATER_CHASE, COLOR_WIPE, SCANNER, FADE };
// Patern directions supported:
enum  direction { FORWARD, REVERSE };
// NeoPattern Class - derived from the Adafruit_NeoPixel class
class NeoPatterns : public Adafruit_NeoPixel
    public:
    // Member Variables:
    pattern  ActivePattern;  // which pattern is running
    direction Direction;     // direction to run the pattern
    unsigned long Interval;   // milliseconds between updates
    unsigned long lastUpdate; // last update of position
    uint32_t Color1, Color2;  // What colors are in use
    uint16_t TotalSteps;  // total number of steps in the pattern
    uint16_t Index;  // current step within the pattern
    void (*OnComplete)();  // Callback on completion of pattern
    // Constructor - calls base-class constructor to initialize strip
    NeoPatterns(uint16_t pixels, uint8_t pin, uint8_t type, void (*callback)())
    :Adafruit_NeoPixel(pixels, pin, type)
        OnComplete = callback;
    // Update the pattern
    void Update()
        if((millis() - lastUpdate) > Interval) // time to update
            lastUpdate = millis();
            switch(ActivePattern)
                case RAINBOW_CYCLE:
                    RainbowCycleUpdate();
                case THEATER_CHASE:
                    TheaterChaseUpdate();
                case COLOR_WIPE:
                    ColorWipeUpdate();
                case SCANNER:
                    ScannerUpdate();
                case FADE:
                    FadeUpdate();
                default:
    // Increment the Index and reset at the end
    void Increment()
        if (Direction == FORWARD)
           Index++;
           if (Index >= TotalSteps)
                Index = 0;
                if (OnComplete != NULL)
                    OnComplete(); // call the comlpetion callback
        else // Direction == REVERSE
            --Index;
            if (Index <= 0)
                Index = TotalSteps-1;
    // Reverse pattern direction
    void Reverse()
            Direction = REVERSE;
            Direction = FORWARD;
            Index = 0;
    // Initialize for a RainbowCycle
    void RainbowCycle(uint8_t interval, direction dir = FORWARD)
        ActivePattern = RAINBOW_CYCLE;
        Interval = interval;
        TotalSteps = 255;
        Index = 0;
        Direction = dir;
    // Update the Rainbow Cycle Pattern
    void RainbowCycleUpdate()
        for(int i=0; i< numPixels(); i++)
            setPixelColor(i, Wheel(((i * 256 / numPixels()) + Index) & 255));
        show();
        Increment();
    // Initialize for a Theater Chase
    void TheaterChase(uint32_t color1, uint32_t color2, uint8_t interval, direction dir = FORWARD)
        ActivePattern = THEATER_CHASE;
        TotalSteps = numPixels();
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
    // Update the Theater Chase Pattern
    void TheaterChaseUpdate()
            if ((i + Index) % 3 == 0)
                setPixelColor(i, Color1);
                setPixelColor(i, Color2);
        show();
        Increment();
    // Initialize for a ColorWipe
    void ColorWipe(uint32_t color, uint8_t interval, direction dir = FORWARD)
        ActivePattern = COLOR_WIPE;
        Color1 = color;
        Index = 0;
        Direction = dir;
    // Update the Color Wipe Pattern
    void ColorWipeUpdate()
        setPixelColor(Index, Color1);
        show();
        Increment();
    // Initialize for a SCANNNER
    void Scanner(uint32_t color1, uint8_t interval)
        ActivePattern = SCANNER;
        TotalSteps = (numPixels() - 1) * 2;
        Color1 = color1;
        Index = 0;
    // Update the Scanner Pattern
    void ScannerUpdate()
        for (int i = 0; i < numPixels(); i++)
            if (i == Index)  // Scan Pixel to the right
            else if (i == TotalSteps - Index) // Scan Pixel to the left
            else // Fading tail
                 setPixelColor(i, DimColor(getPixelColor(i)));
        show();
        Increment();
    // Initialize for a Fade
    void Fade(uint32_t color1, uint32_t color2, uint16_t steps, uint8_t interval, direction dir = FORWARD)
        ActivePattern = FADE;
        TotalSteps = steps;
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
    // Update the Fade Pattern
    void FadeUpdate()
        // Calculate linear interpolation between Color1 and Color2
        // Optimise order of operations to minimize truncation error
        uint8_t red = ((Red(Color1) * (TotalSteps - Index)) + (Red(Color2) * Index)) / TotalSteps;
        uint8_t green = ((Green(Color1) * (TotalSteps - Index)) + (Green(Color2) * Index)) / TotalSteps;
        uint8_t blue = ((Blue(Color1) * (TotalSteps - Index)) + (Blue(Color2) * Index)) / TotalSteps;
        ColorSet(Color(red, green, blue));
        show();
        Increment();
    // Calculate 50% dimmed version of a color (used by ScannerUpdate)
    uint32_t DimColor(uint32_t color)
        // Shift R, G and B components one bit to the right
        uint32_t dimColor = Color(Red(color) >> 1, Green(color) >> 1, Blue(color) >> 1);
        return dimColor;
    // Set all pixels to a color (synchronously)
    void ColorSet(uint32_t color)
            setPixelColor(i, color);
        show();
    // Returns the Red component of a 32-bit color
    uint8_t Red(uint32_t color)
        return (color >> 16) & 0xFF;
    // Returns the Green component of a 32-bit color
    uint8_t Green(uint32_t color)
        return (color >> 8) & 0xFF;
    // Returns the Blue component of a 32-bit color
    uint8_t Blue(uint32_t color)
        return color & 0xFF;
        if(WheelPos < 85)
            return Color(255 - WheelPos * 3, 0, WheelPos * 3);
        else if(WheelPos < 170)
            WheelPos -= 85;
            return Color(0, WheelPos * 3, 255 - WheelPos * 3);
            WheelPos -= 170;
            return Color(WheelPos * 3, 255 - WheelPos * 3, 0);
void Ring1Complete();
void Ring2Complete();
void StickComplete();
// Define some NeoPatterns for the two rings and the stick
//  as well as some completion routines
NeoPatterns Ring1(24, 5, NEO_GRB + NEO_KHZ800, &Ring1Complete);
NeoPatterns Ring2(16, 6, NEO_GRB + NEO_KHZ800, &Ring2Complete);
NeoPatterns Stick(16, 7, NEO_GRB + NEO_KHZ800, &StickComplete);
Second half of the code
// Initialize everything and prepare to start
    // Initialize all the pixelStrips
    Ring1.begin();
    Ring2.begin();
    Stick.begin();
    // Kick off a pattern
    Ring1.TheaterChase(Ring1.Color(255,255,0), Ring1.Color(0,0,50), 100);
    Ring2.RainbowCycle(3);
    Ring2.Color1 = Ring1.Color1;
    Stick.Scanner(Ring1.Color(255,0,0), 55);
// Main loop
    // Update the rings.
    Ring1.Update();
    Ring2.Update();
    // Switch patterns on a button press:
    if (digitalRead(8) == LOW) // Button #1 pressed
        // Switch Ring1 to FADE pattern
        Ring1.ActivePattern = FADE;
        Ring1.Interval = 20;
        // Speed up the rainbow on Ring2
        Ring2.Interval = 0;
        // Set stick to all red
        Stick.ColorSet(Stick.Color(255, 0, 0));
    else if (digitalRead(9) == LOW) // Button #2 pressed
        // Switch to alternating color wipes on Rings1 and 2
        Ring1.ActivePattern = COLOR_WIPE;
        Ring2.ActivePattern = COLOR_WIPE;
        Ring2.TotalSteps = Ring2.numPixels();
        // And update tbe stick
        Stick.Update();
    else // Back to normal operation
        // Restore all pattern parameters to normal values
        Ring1.ActivePattern = THEATER_CHASE;
        Ring1.Interval = 100;
        Ring2.ActivePattern = RAINBOW_CYCLE;
        Ring2.TotalSteps = 255;
        Ring2.Interval = min(10, Ring2.Interval);
        Stick.Update();
//Completion Routines - get called on completion of a pattern
// Ring1 Completion Callback
        // Alternate color-wipe patterns with Ring2
        Ring2.Interval = 40;
        Ring1.Color1 = Ring1.Wheel(random(255));
        Ring1.Interval = 20000;
    else  // Retrn to normal
      Ring1.Reverse();
// Ring 2 Completion Callback
        // Alternate color-wipe patterns with Ring1
        Ring2.Color1 = Ring2.Wheel(random(255));
        Ring2.Interval = 20000;
        Ring2.RainbowCycle(random(0,10));
// Stick Completion Callback
    // Random color change for next scan
    Stick.Color1 = Stick.Wheel(random(255));
