can this be done?
basically, a house light (not a lamp) connected to a dimmer switch >
a program called f.lux that dims your p.c. screen the later it gets based on geographical location, so 8 am light is bright, 8pm light starts fading 10 pm light is very dark so by 12 midnight the light is virtually turned off?
I dont need a p.c. to do this for me I just need that to happen to the light if there is a simple way to do it.
i.e. circuit board connected to the dimmer switch a light sensor that operates opposite , so when it is going dark the dimmer will also start to go dark on a standard house light that will dim it as the time gets later and later,
if something like this is beyond the arduino any recommendations?
have i missed something really obvious?
The exact setup is this my grandparents need an effect called sundowning in their house they do not go to bed at a normal time as they cant tell exactly what time it is and their minds havent switched off so they dont feel tired when they should ,
I know F.lux has this effect with your computer screen and you can work out if you cant see something it because its dark you should go to bed. I believe its some kind of conditioning, they dont have a computer screen or a tv they sit and listen to a radio but might not register the actual time even if it tells them,
to johnnt010 "That made about zero sense...
Why do you need a dimmer switch when you also want the light to be fully automated in it's brightness?
I think you need to form a better specification and think through what you are exactly trying to solve."
I dont need a dimmer switch if making the light brightness change darker can be acheived without one, just trying to find something that will work for them
you can connect the light to a PWM pin on an Arduino to dim and brighten a light.
As for sensing time, you can either use Millis() and unsigned long to manually create a timer, like this:
byte seconds = 0;
byte minute = 0;
byte hours = 0;
unsigned long previousMillis = 0;
const long oneSecond = 1000UL;
  if (millis() - previousMillis >= oneSecond) {
    seconds++;
    if (seconds > 59) {
      minute++;
      seconds = 0;
    if (minute > 59) {
      hours++;
      minute = 0;
    char currentTime[10] = "";
    snprintf(currentTime, sizeof(currentTime), "%02d:%02d:%02d", hours, minute, seconds);
    Serial.println(currentTime);
    previousMillis += oneSecond;
Then, apply it to dimming or brightening an LED. In this quick sketch I made, after every second, the led will get slightly brighter. When the counter hits 255 seconds, the led will get dimmer every second.
int led = 9; // led
int seconds = 0;
unsigned long oneSecond = 1000UL; // for timer
boolean up = true; // true/false for going up or down in counter
  Serial.begin(9600); // begin serial com so you can see timer
    if (up == true) {
      seconds++;
    else {
      seconds --;
    if (seconds >= 255) {
      up = false;
    if (seconds <= 0) {
      up = true;
    analogWrite(led, seconds);
    Serial.println(seconds);
With these two concepts in mind, mess with the numbers a little bit to fit your needs in a span of hours, in this case.
Or, use a GPS shield to check the real time and use if/else statements to brighten or dim the light. (this would still involve the use of a PWM pin).
maxxryno:
If you mean a mains voltage lamp or light then buy a suitable and safe controller. Or employ a qualified electrician. Do not mess with mains voltages.
...R
maxxryno:
dispite the almost universal misconception, a LAMP is a BULB. a FIXTURE holds the bulb and the shroud and often a switch.
many people think a lamp is the fixture because of the way people describe the use of the bulb.
[rant mode]
also interesting is that the most ignorant people get to chose the meaning of the words and how they are used. once some incorrect use becomes popular and spreads like a virus, it starts to get written by other ignorant people into the books and papers of the era. there is a tipping point were the overwhelming majority have no clue as to the correct use, only the popular use and the ivory tower scholars then re-write the dictionaries.
[watch out for anyone who offers 'overwhelming majority' as a means of authority. ]
if you want to know the actual meaning of a word, go back to the dictionary of the father of the writer. especially when you read older books or the way it is used does not make sense to you. [/rant mode]
Times of sunrise and sunset drift throughout the year. Perhaps you've noticed! What you need is a sun position calculator. Quit now if you're not an experienced programmer.
