Can this done easier?
Berfore including something into a large sketch I am testing it in a simple sketch. The same here, the data that comes from a serial.read is here simulated by a charracter arry. The purpose of the if is to test if the received character contains the nu,ber 0-9 and two other charcters being the comma and dot, eg "qwerty,0123456789.\0" => ",0123456789."
The question is, can this be done easier?
   char teststring[20] = "qwerty,0123456789.\0";
  char saByte;
  bool num_keypad = false;
  for (int i; i <= 20; i++) {
    saByte = teststring[i];
    if(!num_keypad && saByte == ',' || saByte == '.'|| saByte >= '0'&& saByte <= '9'){
    Serial.print(saByte);
Perhaps this might help:
Use strchr
You don't need to include the trailing nul char, the compiler will do that for you
char teststring[20] = "qwerty,0123456789.";
consider using readByteUntil()
if the received string has a space between the cmd and value, sscanf() can be used to read the cmd into a char array and an int. i don't believe the arduino scanf handles floats
Not only you gave 2 terminating 0 at index 18 and 19 you are also reading past the end of array
Then array will be 19 char long, and element [19] will be what?
just define it without a size and all will be taken care of, including the terminating null
char teststring [] = "qwerty,0123456789.";
Hi
try this way.
String myString ;
String myResult;
  myString = teststring;
  int myStart = myString.indexOf(",");
  int myEnd = myString.indexOf(".");
  myResult = myString.substring(myStart, myEnd + 1);
  Serial.println(myResult);
What are you trying to do?
See reply #3
see this post:
https://forum.arduino.cc/t/if-on-boolean-wont-work/956326
Set the "Compiler warnings" preference to All. Then you would get some helpful warnings about mistakes:
warning: suggest parentheses around '&&' within '||' [-Wparentheses]
/Users/john/Documents/Arduino/sketch_jan25a/sketch_jan25a.ino:8:69: warning: suggest parentheses around '&&' within '||' [-Wparentheses]
That means you should put parentheses in your expression to disambiguate the order of operation:
if(!num_keypad && (saByte == ',' || saByte == '.'|| (saByte >= '0'&& saByte <= '9'))) {
warning: 'i' is used uninitialized in this function [-Wuninitialized]
You didn't assign an initial value to 'i' and it is a local variable so it doesn't automatically get set to zero. You have to explicitly initialize it:
' for (int i=0; i <= 20; i++) {`
You can save a little code by not using a variable that never changes ('num_keypad').
Here is a version of your sketch that fixes the errors and warnings and removes the unneeded variable.
  delay(200);
  const char teststring[] = "qwerty,0123456789.";
  for (size_t i = 0; i < strlen(teststring); i++)
    char saByte = teststring[i];
    if (saByte == ',' || saByte == '.' || (saByte >= '0' && saByte <= '9'))
void loop() {}
...or you could just use strchr
As in: if (strchr(",.012356789", sabyte))?
  1. I think that would average more comparisons since it has to check 1, 2, 3, 4, 5, 6, 7, and 8 as well as comparing to 0 and 9.
  2. It will produce a false positive if 'saByte' contains zero.
  1. Meh. It's serial
  2. Good point.
How do you feel about bsearch? :smiley:
undefined, but beyond the end of the current string but available if you wanted to add additional characters. If you actually did print them out, they most likely would be '\0'
