Can two Bluetooth modules be paired in parallel?
Alright this might sound odd but I am hoping I can clear it up a bit. So Basically I have an arduino UNO wired to a 16 channel relay board and an HC-06 Bluetooth module attached to the UNO. I got all my pins being used including the analog pins. I have my samsung galaxy s4 permanently attached to my car, and always paired to the bluetooth. What I want to do Is be able to use my samsung galaxy s5 in my pocket to also pair up and control the relays. So that If I am out of my car I can still show people.
From what I read I can't have two devices paired at the same time? So I was wondering if I bought a second HC-06 and attached it in parallel to the other one if both could be connected? Hope this isn't to confusing. Just looking to see if it is plausible or not?
Sounds like it should work to me...give it a try ha. I don't see the issue to be honest, the HC-06 devices should ignore anything trying to input on their tx pins. Diodes may be of use in this application?
