Can two THINGS access the same property?
I'm wondering if it's possible to have two Things read (at the very least) the state of the same property. At a glance, it doesn't seem like something that will work but I wanted to check to see if anyone has done this before.
Thanks!
hi @bingroum
sharing properties amongst things is something we have in our roadmap, but nothing prevents you from using our API to do that.
In fact we do this all the time in our workflows and experiments :slight_smile:
Only limitation is the frequency at which you can call the API, which I believe is max once per second.
https://www.arduino.cc/reference/en/iot/api/
You can use Python, JavaScript or Go, my personal go-to is Python.
Hope you'll want to try this out because there's so much that can be done :smiley:
@ubidefeo
I'll look into it! Thanks!
