Can two TSIC306 sensors be used in the same sketch?
Hello All,
Uno and TSIC306
using the sensor on pin 4
Is it possible to use 2 Tsic306 temperature sensors at a time?
I am using TSIC.h and using the sketch i cannot see how it is possible?
#include "TSIC.h"       // include the library
// instantiate the library, representing the sensor
//TSIC Sensor1(4, 2);    // Signalpin, VCCpin, Sensor Type
TSIC Sensor1(4);    // only Signalpin, VCCpin unused by default
uint16_t temperature = 0;
float Temperatur_C = 0;
    Serial.begin(9600); // set up the serial port
  if (Sensor1.getTemperature(&temperature)) {
    Serial.print("uint_16: ");
    Serial.println(temperature);
    Temperatur_C = Sensor1.calc_Celsius(&temperature);
    Serial.print("Temperature: ");
    Serial.print(Temperatur_C);
    Serial.println(" °C");
  delay(1000);    // wait 1 seconds
Surely the library allows you to declare another instance of the sensor, on a different pin. Check the documentation.
Hello Jremington
You are quite rite i am just having a midweek brain fart, I have now tried the this code and it works. At first i could only get one of the two sensors to give a reading i missed this line "Temperatur_C =SensorSteam.calc_Celsius(&temperature);"
so it kept giving me only sensor 1's readings, after staring at the example i worked it out
TSIC SensorSteam(7);
(Sensor1.getTemperature(&temperature));
     if (SensorSteam.getTemperature(&temperature));
    Temperatur_C = SensorSteam.calc_Celsius(&temperature);
    Serial.print("TemperatureSTEAM: ");
thank you for your help :smiley:
